Plumbing Logo
S
Sheri Landes Posted on Aug 15, 2019
I have a mq3-45. How do you test the psi on the bladder tank? Or how do you know if it is bad?
ronandchi
Level 1:
New Friend:
  • Contributor 36 Answers
  • Posted on Aug 21, 2019
ronandchi
Contributor
Level 1:
New Friend:
Answers
36
Questions
0
Helped
11207
Points
44
First turn the well off. Then run the water until it stops. Then check the pressure. It should have 2 psi less than when the pump turns on. If you have a 30-50 switch it would be 28 psi, 40-60 is 38 psi. Look under the switch cover and it will tell you what it is. If you charge the tank up (which has to be empty) and air comes out of the faucet, the bladder is blown.
1 Related Answer
Anonymous
  • Posted on Sep 08, 2009
SOURCE: Cabin pump, primed fine only goes to28psi and keeps running
Sounds like the injector nozzle is plugged. This nozzle is directly inside the influent line on single line jets and down in the well on two-line jets. I'm assuming you have it primed correctly. If this happened suddenly the it'd definitely the injector nozzle. It it was a gradual process over time then I would say it's either a badly worn nozzle or worn impeller.
I have a 1/2 horsepower Utilitech pump hooked to a 36 gallon utilitech tank and need to know the cut in PSI
For normal house service cut-in is usually 20 psi, cut-out 40 psi. The pressure switch can usually be adjusted to 50 psi. For any more check the pump specs. Usually you can google that.
Aug 18, 2015 • Plumbing
Pump not holding presure
If you have a bladder - type water pressure tank, it probably needs to be purged of air and then pre-charged to 18 psi. There may be directions on the side of the tank. Turn the water Pump off. Drain the tank of water. Check the pressure of the tank at the air valve on top of the tank. The pre-charged pressure of the bladder is set to 2 psi below the lower pressure set by the pressure switch, so in your case, the low end pressure is 20 psi. Therefore, the pre-charge pressure of the tank is 18 psi. If you set the pressure switch to operate at 30 -50 psi, then the pre-charge pressure would be 28psi., etc. Once the pre-charge pressure is set, turn the pump back on. ( don't forget to close the drain valve). The system should cycle normally. A tire gauge works to check the tank pressure. An air compressor may be used to charge the tank, but be careful not to over- inflate the bladder. A tire air pump may also be used. Hope this helps....
My sand point well the water stops and starts again
You probably need to purge the pressure tank.
Well Pressure Tank Installation Instructions
Pressure tanks lose their Pre Charge pressure and have to be serviced. The well Pump needs to OFF. The Pressure tank needs to be emptied of water. There should be an air valve on the tank. Check the pressure .If this is a Bladder tank and Water comes out of the air valve- then the bladder is broken and the tank needs to be replaced. The Pre Charge pressure is set to 2 psi Below the cut-in pressure set by the pressure switch. If your system operates at 20-40 psi, The Pre Charge pressure will be 18 psi. Hope this helps.....
Culligan AC-30 Tank not Filling and Recharge only produces minimal water.
You should change filters and membrane and then proceed. Replace both filters not one. You mat to buy new RO unit that you can find filters on line ie store (less than you are going to pay for Culligan) PROCEDURE FOR RECHARGING REVERSE OSMOSIS BLADDER TANK WITH AIR
When you turn on the faucet you notice low water pressure from the storage tank and only a quick burst of water come out of the system, and it dies down to trickles. Is the tank defective, i.e., bladder has hole and not functioning properly? Perhaps.
If you have the above problem and the tank is heavy (full), then try to relief the pressure from the air valve on the tank side. Is water coming out? If the answer is yes, then the bladder has hole and is defective, and tank replacement is due. If air comes out then it is possible that the air needs to be recharged.
Notes on bladder tank, please continue reading:
RO Tank useful life is 5-7 years. If the tank has been serving you for that long it is possible that the bladder had a hole and that tank replacement is due. If the tank is not that old, it is worth it to evaluate it for air pressure. In an empty tank, air pressure should be 7-10 psi. In a full/heavy tank, air pressure should be 30-40 psi. To be accurate, air pressure should be 2/3 of incoming water pressure. When the tank is full, and if feed water pressure to the RO system is 60 psi, then a full tank should have 40 psi. The RO tank has a bladder inside, and this bladder separates air from water. On the lower side of the tank is the air valve which is connected to the compressed air chamber. The top water inlet/outlet port (where the tank valve is mounted) is connected to the pure water chamber. So, when you turn on the faucet, the compressed air would squeeze or compress the bladder to force the water out of the tank.
You do not want to believe the tank is useless and want to do extra testing? If your answer is yes, please continue reading.
TOOLS NEEDED FOR TESTING:
1. An air compressor or air pump (like a bicycle tire air pump)
2. An air pressure gauge that is able to read less than 10 psi, and
3. Adjustable wrench.
STEPS:
1. Shut off the water supply to the RO system
2. Turn on the faucet to allow water to run until it stops.
3. Check to see if there is still water in the storage tank by lifting the tank. If the tank feels heavy, that means you need to recharge the tank and continue the following steps. If the tank feels light, that means you don't need to charge your storage tank at this moment.
4. Locate the air valve on the side of the tank. It looks like the air valve on tires.
5. Use air compressor or air pump to pump air into the tank. Keep the faucet on while pumping air, so that all water inside the tank can be purged out.
6. After all water has been drained from the tank, use an air pressure gauge to check the tank pressure.
7. The tank should have 7 psi of pressure when it's empty. Add or purge air if necessary.
8. Turn the feed water valve back on, and turn off the faucet to allow refilling of the tank.
9. finished.
What if the tank does not hold pressure and you see the same problem again? Bladder is out and you need to replace the tank.
1helpful
My 3/4 hp shuts off and on roughly every 2 or 3 seconds when using. i pumped some air into the pressure tank and it worked much better. but i pumped in a little more and now its every second. i'm...
The switch is not the problem. The problem is the pressure tank. I am assuming you have a captive air tank with a bladder in it. The air pressure in the tank needs to be 2 lbs below the turn on pressure. Heres how to acheive that. Look at the pressure gauge on the pump and determine what pressure the pump is turning on. Next, turn the pump off and drain the pressure tank, then shut off the water to the whole house. If the pressure tank does not drain all the way, then you have a problem with the bladder in the tank. Once the tank is drained put the required amount of air in the tank. (if the pump turned on at 30 psi, then put 28 psi in the tank and if the pump turned on at 20, then put 18 psi in the tank) Check it with a tire gauge to confirm. Now turn the pump back on and see how it does. If done properly, your problem should be fixed. If it is a bad bladder, you will have to buy a new pressure tank.
3helpful
When adding air to a pressure water pump ,i
Sounds like the bladder is gone or inproper air pressure in water storage tank.
Bladder goes bad check it out with step 1
1-
One way to check for sure with everything hooked up. The air valve on top of the tank if pressed you will get water out of the valve which should be only air. This will let you know it should replaced.
If Tank bladder is low in air and not water coming out.
2-If it checks ok put an air gauge to tank to check the air pressure, with a standard 40 gal tank you will have 28 psi of air in tank for it to function properly.
May 21, 2010 • Plumbing
1helpful
Why is the pump cutting in so much
Check your water pressure tank air pressure, turn off pump, drain off all water pressure and using a air pressure gauge check pressure at the schrader valve on the water pressure tank. It should be 2 lbs below pump cut-in pressure, they come factory charged at 30 PSI...works for most residential systems. Most likely you have a bad bladder in pressure tank.
Other possibles are a broken line between pump and pressure switch/pressure tank or bad pressure switch.If you have a pressure gauge on the water system(should have one near pressure switch) see if it is cycling at the right points if it is the switch is good. If pressure is dropping with NO water uasge in house you have a leak.
Most likely a bad pressure tank bladder is the problem.
7helpful
3answers
Flotec 42 gallon water tank - short cycling and changing water stream...do I need a new tank or could it be another problem?
These holding tanks are pre charged with air which in turn pressurizes the water. The tank has a bladder and an air valve on top. The pre charge ,over time, loses pressure, and the tank has to be pressurized again.
  • The well pump needs to be turned off.
  • The water has to be drained from the tank
  • Air is put into the tank from the air valve on top of the tank, and is measured with a tire air gauge.
  • The pre charge pressure is set to two psi below the pump cut in pressure.
  • In other words if your pump kicks on at 30 psi, the pre charge pressure is set at 28 psi. If the pump kicks in at 20 psi, the pre charge is set at 18psi, etc.
  • After you pressurize the tank, turn water back on.
  • If water comes out of air valve on top of tank, then the bladder is ruptured and you need a new tank.
  • Hope this helps!
2answers
Air tank (underneath house) does not push water out of spigot in sinke or refridgerator.
You need to test the air pressure with the tank totally empty, remove the tube that is going into the tank and open the tank valve to release all water, if water is in tank and does not come out your bladder is finished and you will need a new tank, if you are able to get all the water out then you need to test PSI again and it needs to be between 7-10 psi, this way when the bladder fills up again with water that pressure will be the ideal 40-50 psi.
Fresh Water Systems | http://www.freshwatersystems.com | 1.877.335.3339
Top Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Plumbing Expert? Answer questions, earn points and help others
