Question about Keurig Coffee Makers & Espresso Machines
Keurig K-Compact Won't Turn On
Got a Keurig Compact for my dorm room, won't turn on. Tried different outlets, nothing. Filled the tank and tried different outlets, nothing. Held the button down and lifted the handle, nothing. I just want some ramen. Help?
Posted by Alyssa Causey on
5 Related Answers
Anonymous
SOURCE: Hoover steam vac will not turn on.
did you drop the handle on the floor? sounds like you may have a loose prong on the on/off switch take it apart and look to see
Posted on Oct 06, 2007
SOURCE: My Keurig will not turn
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards
Posted on Apr 15, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My keurig won't even turn
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Posted on Sep 03, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: The machine won't turn on
heatman101
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My Keurig B60 won't turn on. Tried different
heatman101
Posted on Sep 07, 2011
1helpful
My Juki HZL-E80 won't turn on
no, the light bulb won't cause the machine not to work, check the
power cord to see if it's plugged into the machine correctly, if it is
then the machine needs to be checked to see if it's the power
cord or the on off switch or the machine it's self
My Keurig # B70 won't turn on
Try another outlet, check fuses, or breaker box.
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Kenmore 1.8 cu. ft. Compact Refrigerator stopped running and won't turn back on?
It is really hard to say why it shut down, but my best advice is to make a service appt. asap to have the problem looked at.
3helpful
Won't even turn on. Was flashing cup size lights on left & right and I turned it off and later tried to turn it on and it won't turn on.
heatman101
My Keurig B60 won't turn on. Tried different plugs. What now?
heatman101
5helpful
2answers
My keurig won't even turn on. We unplugged and replugged but still nothing. The outlet does work, so don't know what to do. Is there a fuse or something simple that I could try. The Keurig is about...
heatman101
The machine won't turn on at all. Tried t in several functioning outlets and it won't power up. Only 6 months old. Keurig B60
heatman101
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Delonghi TRD0715T Safe Heat Oil-Filled Radiator will not work, won't turn on its new just taken out of the box
Ditto same problem. Took it out of the box, plugged it in the electric outlet and did not turn on.
I tried atleast 5 different electric outlets to make sure nothing is wrong with the outlet. Tried changing the timer settings. No use.
Returned it to Lowe's.
Coffee Makers & Espresso Machines Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Pierre Laplante
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
