Photography Logo
Question about Photography
INNOVA DIGITAL PICTURE FRAME MODEL VF581FM MANUAL AND REMOTE CONTROL
Posted by FRANK BARBARITO on
Tony Parsons
  • Photography Master
  • 6,397 Answers
Yes - what about them ?
Posted on Aug 15, 2019
5 Related Answers
Anonymous
  • 75 Answers
SOURCE: was given digital picture frame
It depends on how big the existing pictures are. It has a 14MB internal memory, but it says about 12MB for storage. You can buy memory card to insert into the frame but it will not display internal memory once you insert a new memory card. If you bought a 512MB card, you could put hundreds to thousands of pictures in JPG format. You can hook the frame to your computer or directly to a digital camera. From the computer it takes a few seconds to convert the pictures. The frame will show up on your PC as a mass storage device and you will be able to delete photos as well.
I hope this helps
Posted on Dec 05, 2008
Anonymous
  • 10594 Answers
SOURCE: user manual
Download user manual of IDF1030 click Polaroid Support.
Posted on Dec 30, 2008
leepania
Pania Lee
  • 1099 Answers
SOURCE: Lost remote control for SV811 digital frame. Where can I purcha
Call the sales line: UK: 08000281422
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Oct 16, 2009
Anonymous
SOURCE: IQ Digital Photo Picture Frame - Need Engish Operating Manual
http://www.gentec-intl.com/GentecInc/commodity/3101/manualE.pdf
Posted on Oct 20, 2009
Anonymous
SOURCE: not all pictures display on my 8'' Innova digital picture frame
I received this as a gift and I have the same problem.
Posted on Jan 07, 2010
1helpful
I need a remote control for a digital picture frame ADS7000PF
You could buy another frame and use the remote for both. Amazon has used for as low as 37.50 and new for 45.
Nov 18, 2014 • Photography
How to remove battery digital picture frame
I believe the only battery you have to replace is in the Remote Control ? The picture frame itself does not have a battery .. only the A/C connection.
To Install or Replace the Remote Control Battery :
1. Hold the Remote Control with the control buttons facing downward.
2. While pressing down on the ridged area of the battery cover, pull the tray out.
3. Place a "CR2025" Lithium battery on the tray with the positive "+" end facing toward you.
4. Close the tray.
Hope this helps.
How to replace the battery in the remote control:
1. Hold the remote control with the buttons facing down.
2. Push and hold the small release tab while pulling the battery tray out.
3. Replace the "CR2025" Lithium battery on the tray with the positive (+) side facing up.
4. Push the tray back in until it clicks into place.
You can download the manual here:
http://www.robholland.com/blog/wp-content/uploads/2011/01/User-Guide-for-Pandigital-PAN7000DW.pdf
Remote control for Smart Parts 11" digital frame (SKU SP11008) doesn't work. Have changed battery, but cannot get any type of connection between remote and frame. Received as gift over a year ago, but did...
We have to check the remote control first. After that check the digital picture frame.
Follow the instructions below please;
We must be sure the remote control is working;For this control:
1. Take a digital photo of this remote control while pressing the remote control button.
2. If it is working then the picture must shows the led lamp of remote control as firing.
3. If the picture does not show that it is firing, then, you should control batteries of the remote control.
4.Check the battery and the battery polarity of the remote control.
5.If it is firing. You should control Digital Picture Frame.
6. If the battery of the digital picture frame does have enough energy or not. If battery is low then you shoud use it from the closer distance.
7. I do not think that the Digital Picture Frame is out of order.
Regards.
Unable to bring up the setup screen for display option
can't get the frame to cut off and start back up to show the setup program
1helpful
Remote control won't work with the SmartParts Digital photo frame 15". We have changed battery. We have followed instructions on verifying that it is remitting a signal using a digitial camera - it is...
We finally asked the store about our problem. The salesperson finally just gave us a different remote control. Now it works fantastic. I find that the SmartParts Customer did not return our call nor answer our e-mail. So much for their customer service!
2helpful
Need a remote for a sv811 frame
I contacted Kodak at 1.800.235.6325 option 14 and the part number for the remote control is 3F9766 @ $2.52. You need to contact the support number to order it.
Will my photo frame read SDHC cards
You don't mention the make and model of your frame. You need to check your manual or just punch up your frame model on the net and check. Many frames DO NOT read a card above 2gb so you are wise to check before you buy one.
1helpful
Unable to operate remote of Pandigital picture frame
remove the memory card and see if the remote works wit hthe built in memory pics. if it doesnt pic up your card you will just have to try another card. The frames dont read cards larger than 1 Gb very well either - reguardless of how many pics are on the card.
Top Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Photography Expert? Answer questions, earn points and help others
