Question about Westinghouse Televison & Video
Code for 24in Westinghouse tv - Westinghouse Televison & Video
Posted by Joe Kingston on
Westinghouse tv, remotes do not work on it
Each tv remote has a code list....you must find the code that corresponds withe the Brand of tv and enter the code then ALL the buttons will function properly
Mar 06, 2014 | Westinghouse Televison & Video
WESTINGHOUSE LD-4655VX CODE FOR XFINITY REMOTE
The Westinghouse LD-4655VX TV has code compatibility with Sony TVs (http://westinghouseelectronics.com/wp-content/uploads/2012/06/Remote_Codes_2012.pdf). I accidentally discovered that the Sony TV remote RM-YD040 works with my he Westinghouse LD-4655VX (because I have both TV sets).
Feb 02, 2012 | Televison & Video
I have a 47" Westinghouse
Is your HDMI cable connected? Also, you should make sure that your "input" that will show on your tv when you press that button on your tv remote, shows HDMI Line1 or Line 2 (try both lines if you are not sure which line your tv is set up for.)
I needed my Sony TV code when I first set up my set, I got it from a tech from my cable AT&T uverse provider. Westinghouse may be able to give you that code as well.
Jun 09, 2011 | Westinghouse Televison & Video
Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Apr 17, 2011 | Westinghouse 16093 Remote Control
Hello! I wanted to give you a few more codes that you may not have tried. I also wanted to give you the instructions to the power scan, which will scan the TV for the correct code. I hoep this helps!
Codes:
500
795
719
Power Scan:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
White Westinghouse sk26h240s remote codes
Goto this page:
http://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/grayokselect.pdf
follow the instructions for "Searching For your Code " This worked for my White-Westinghouse (though it takes about 20 repetitions to hit the code!)
Hope this helps
Nate Wells [email protected]
Jan 10, 2009 | Televison & Video
Directv remote code needed
Follow these steps:
http://support.directv.com/app/answers/detail/a_id/3188/~/white-remote-control-programming-steps
When it asks you to enter the code for your tv use 10178
It works like a charm!
May 01, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Remote control code for westinghouse sk-19h210s television
I just tried a Sony code for my Westinghouse tv after reading other sites, and it worked. The code that worked for me was 10000
Oct 21, 2007 | Televison & Video
Televison & Video Logo
88 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
