Question about Freezers
Trying to find out what my cavalier cedar chest is worth? And how old it is? Still has paperwork stapled on inside of lid..
Posted by Keith wells on
2 Related Answers
MOTORWIZJ
Jay Finke
  • 1389 Answers
SOURCE: i have a 13 cuft
I WOULD TAKE THE LID OFF AND REPAIR IT, USE SILICONE,ALCOHOL TO CLEAN BOTH SURFACES, AND SOME SMALL POP RIVETS.. GO TO ACE HARDWARE AND ASK ONE OF THE GUYS FOR THIS STUFF, ASK HIM FOR RECOMMEND REPAIR TECHNIQUES PICTURES OR THE LID IN THE BACK OF YOUR TRUCK, SO HE CAN SEE IT .. CUZ FLAT OUT YOU AINT GOING TO FIND A LID, AND IF YOU DO DON'T BE SURPRISED IF ITS 200$ OR MORE .. JAY THE PUMP REPAIR GUY FLORIDA
Posted on Jul 28, 2011
Kami
  • 307 Answers
SOURCE: chest freezer ice is building up on the inside lid
Air might be getting in. The lid gasket may need to be replaced. If so, you could do it yourself, with a gasket ordered online or purchased in a home improvement store.The lid may not fit properly. There could be too much food inside, packed against it.
Posted on Oct 16, 2018
What is date of lane cedar chest style 481939 serial no.145280
According to Lane, your cedar chest was made 8/25/14.
Usually Lane cedar chests have serial numbers that are stamped or applied to the bottom of the chests.
You can read the serial number BACKWARDS to determine the production date.
For example: serial number 753150 would have been produced on 05/13/57.
Some chests may also have an extra digit which denotes the plant location.
For example: serial number 2557121 would have been produced on 12/17/55 in plant #2.
Oct 06, 2016 | Freezers
Ice on the inside walls of chest freezer
Check the seal around the lid sits firmly on the rim, give it a good defrost before restocking. Make sure all else is working and clean, particularly any condenser grilles / fans.
Mar 23, 2014 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Chest freezer ice is building up on the inside lid
These ideas ****. Question was, what causes ice to build up in the chest freezer.
Jul 03, 2012 | Kenmore 5 cu. ft. / 142 liter Chest...
Lid on chest freezer will not securely close Model #FCM 7DAA WH Serial #RTI63278 Mfg 81998
Remove lid, squeeze hinge back into shape and refit, adjusting screws in rear of hinge bracket as you do.
May 19, 2012 | GE Freezers
I have a woods chest style deep freeze and the lid is very cold on the outside, but the sides are room temperature and the freezer works fine. Why is the lid cold and how can I fix it
Yes, the freezer temperature means the lid gets very cold. Every time you open it some moisture condenses in the lid and the outside ambient also affects it. The insulation may be beginning to break down and the ice is forming inside. It is not a major problem however and many freezers go on for years with freezing lids!
Apr 18, 2012 | Woods Chest Freezer C1501W3
I have a 13 cuft chest freezer,the lid on the inside is coming off,i cant seem to find a new lid for this.
Jul 28, 2011 | Kenmore 12.8 cu. ft. / 362 liter Chest...
I am defrosting my chest freezer and have the lid open and water is continuing to drip out of the lid. Why?
condensation has frozen inside your lid and now is defrosting and driping out. Reason : there is a air leak in the lid
Jan 09, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
Chest freezer lid repair
if your freezer has the sping etc in each of the hinges, then yes take them off. If your freezer has a torshon bar type spring, DO NOT take the hinges off, as you will not get it back together
i have always replaced liners with the door attached. The lid of the freezer is going to bow out of shape when you remove all the screws and take the old lining off, so you need to replace the lining and leave the screws loose so you can realine the door bit by bit.
it is a bastard of a job, and i wish you all the best.
May 01, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Kenmore 12 Chest Freezer - Needs New Lid
searspartsdirect.com
All you need is the model number
It gives you a list of all parts you can buy to replace what's broken, as for the frost try placing a sheet of plastic over the insulation, under the the plastic cover to keep moisture and humidity out of the insulation.
Apr 25, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
155 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
