Question about Furniture
I have a EMS-9 S massage chair. I broke the part of the left handle that you lift to recline the chair. Where do I get s replacement part. I can’t recline the chair
Posted by cindigriffis on
Kirk Whiteside
    New Friend:
  • 24 Answers
Check on eBay.com specify what parts you need
Posted on Aug 17, 2019
4 Related Answers
Azrael SRL
  • 11800 Answers
SOURCE: My EMS 9 massage chair
The massaging is done by small motors with eccentric weights attached to the shafts. Those motors are controlled thru a very simple control board that in your case appears to have failed.
To fix the chair you will have to access the board and find out why it has failed - at least a basic experience in electronics is required, to perform the tests on the relays and triacs used to control the motors. If you don't posses this experience then all you can do is to check that the power cable, the remote cable and the motors cables that plug in the board are firmly inserted - for everything else you will have to call a pro.
Posted on Sep 14, 2011
Golden Tech
  • 14 Answers
SOURCE: My Golden Technologies Comforter Series
With Golden Technologies chairs, there is a self diagnostic system. There are LED lights at the transformer and the hand control. If you do have have lights at the transformer, it may be a power issue or a bad transformer. If you have lights at the transformer but not the hand control, it is the hand control. Since you state you ahve lights on the hand control, it is probably a motor issue.
The best thing you can do is call the store which sold you the chair or call Golden directly at 1-800-624-6374. While they do not sell directly to the public, they can point you to a local dealer who can help with the repair.
Posted on Sep 19, 2011
Bill Boyd
  • 53814 Answers
SOURCE: Trying to locate a distributor/repair person who has a MH194V-0 (2 1/2" x 3") circuit board for a human touch EMS-12 massage chair
3ways you can get this information
1-- go to a retailer of the chair and find out where it can be repaired --that will get you an authorized service agent
2-- call the manufacturer direct for a list of authorized service agents
3--- go google and type in-- manufacturer of ems 12 massage chair-- and click on the distributor / service agents tab and call them direct on the phone
Posted on Nov 14, 2016
Testimonial: "Have done all three suggestions previously and have not been helped. Looking for outside the box help. Thanks"
Nov 14, 2016 | Furniture
My air med us8000 massage chair will not fit through the doorway. Can the unit be made to remain reclined after shut off or can the arms be removed?
Most large recliners have removable backs. You must lift the rear shirt and look for the release latches. There will probably be an electrical connector or two as well if the device is a massage chair. Once you remove the back, then you can turn the chair on its side and then it should fit through most doorways.
Jan 02, 2016 | Furniture
I have a interactive health massage chair model ems-9-s. when you turn the power switch on the back rollers run for 10 seconds or so and it stops. The power light is on in the controller but nothing will...
Hope it is still under warranty. Need new board and possibly more. My parents bought a similar chair and it failed with many issues to fix. Tech replaced all the electronics. Good luck.
Nov 27, 2013 | Interactive Health Ijoy 130 Human Touch...
Interactive health chair model EMS-9, blowing fuses constantly
You should check the size of the fuse . It may be to low a watt. try a stronger fuse.
Apr 29, 2009 | Interactive Health Ht 135 Massage Chair
I own a Interactive Health Massage Chair Model# EMS.12 also called A Get Way Chair and the Rollers stopped working when using chair yesterday and now they pertrude outward and chair does not go back on at...
We found a repairman!!
Our 10 yr old EMS-9 Interactive Health chair just stopped working about 6 mos ago. After getting no help at all from Interactive Health, except to buy a new chair (!), we finally found a man who fixed it. It was a pinched wire in the remote. A simple fix. He tried to charge us only $20.00! (We gave him much more, it was worth it) We love this chair! You would think that the company would be more forthcoming with repair options if they want people to recommend their products. Anyway, hope this helps someone else too. If you want to contact the person we found to fix it you may email us at [email protected] and I'll gladly pass it along to you.
Jan 02, 2009 | Interactive Health Ijoy 130 Human Touch...
Furniture Logo
171 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
