Question about Radio Communications
I think the problem is you may have to hold the power button in for a few seconds so that the buds know that YOU want them on and not your pocket! It's a common practice these days to do that so that the device doesn't drain unexpectedly. The manual should tell you how to do this.
Posted on Nov 10, 2019
SOURCE: Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
Posted on Feb 09, 2008
SOURCE: Problems pairing my Just Wireless Blue BT-35K2
If you can get the headset into pairing mode, and your phone into detection mode and it's still not pairing, try removing the battery while powered on. Replace the battery and retry, and it should work.
Posted on Jun 27, 2009
SOURCE: Only One Ear Works!?!?!?
get on there site and warranty them. they will replace them for you. www.skullcandy.com/warranty
Posted on Aug 10, 2009
SOURCE: skullcandy earbuds one earbud not working
It is likely that your right stereo channel has either been severed somehow or there is a severe short in one of the cables. What you can try to do to test this theory is first turn on your music. Then wiggle the cable at the very base of the right earbud. If nothing happens wiggle the cord right where it connects to the stereo jack. If still nothing happens run your fingers along the right earbud audio cable bending and twisting it. If at any point you hear music again then you likely have a short. If it is near the earbud then it is going to be difficult to fix since these earbudfs have a large gauard. If the short is at the stereo jack then the fix is simple. A standard 1/8" stereo jack can be purchased from any electronics or audio store. You can then fairly easily seperate teh old stereo jack and solder this new one in place. Search the internet for tutorials on how to do this if need be. Even if you do not get any kind of sound when wiggling it at the base of the jack this is the most likely culprit since this is where most of the stress on the headphones occur. Be wary though, if you do attempt a stereo jack repair you will void whatever kind of warranty your earbuds may have so check before you try. But, in teh end you may end up saving a 60-100 dollar set of earbuds for 5-8 dollars. Hope this helped.
Posted on Sep 19, 2009
SOURCE: i have a just wireless bt-37k. Doesnt want to go in pair mode
In the OFF mode, press and hold large button for 9 seconds until LED alternatly flash blue, red. After that you need to enter passkey 0000.
Posted on Dec 26, 2009
May 02, 2016 | Radio Communications
Jul 31, 2014 | iLive IHB603B Micro Bluetooth Stereo...
Dec 26, 2010 | Jabra BT150 Wireless Headset
Aug 28, 2010 | Jabra (BT620SA125S) Wireless Headset
Aug 19, 2009 | TDK Audio Players & Recorders
Jul 21, 2009 | Cell Phones
Jun 26, 2009 | Cell Phones
Jan 07, 2009 | Motorola Mobility H700 Wireless Headset
Nov 05, 2008 | Insignia Bluetooth Wireless Headphones...
291 people viewed this question
