Question about Radio Communications
Your antenna should not make any difference with power or receiving. Is the scanner mobile or in a room? Hard to imagine the connector being broken. You could test the antenna or even the BNC connector on the scanner. Try another antenna. If you wiggle it, does it start receiving? You may have a short in the BNC to the receiver. Other than that, look to power issues.
Posted on Oct 04, 2019
SOURCE: Actiontec GT704-WG wireless connection not working
you say it suddenly stopped working, if you can connect to the router via ethernet cable then try to access the router's web utility page and make sure your router is in mixed or G-only. If you can't still connect to the router through wireless then try restarting the Wireless Zero Configuration from windows. This is how it's made: Go to control panel and double-click "administrative tools", then double-click "services". You will see a list, scroll down to Wireless Zero Configuration and click "stop", you'll see a progress bar. After that click "start", you'll see another progress bar. Now try connecting to your router via wireless connection. If you still can't connect then repair the connection by right-clicking the wireless icon at the bottom right corner. Keep repairing until you connect.
Hope this works!
Posted on Feb 17, 2008
SOURCE: Cannot Get Antenna To Pick-Up Signal
how do i connect my xm roady sa10035 to my car cd player?
Posted on Feb 02, 2009
SOURCE: no fm radio stations tune in
Not much it can be really. If it is picking up A.M. no problem then it is not a connection problem. It is a fault in the radio itself. F.M. frequency is the easiest to pick up so get the radio checked as it has to be internal.
Posted on Aug 04, 2009
SOURCE: The RSX BOSE radio stopped working.
If you disconnect the bose radio, it loses it's programing.. Needs to be taken to a GM dealer and vin coded. as for the volume knob, it's digital.. if it's not working it wont be a connection issue, it's likely a flaw on the board. The best place to get that fixed is United radio in NY. 1-800-448-0944
Posted on Aug 07, 2009
SOURCE: Receive "Antenna Fail" on receiver
Same problem on my CX-7. I've had antenna replaced one so far. It takes about 30 minutes in the cold (usually on at night on my commute home) to get signal. I agree, during the summer months, everything works fine.
Posted on Dec 11, 2009
Jul 28, 2013 | Radio Communications
Oct 09, 2012 | Ritron PX80A, ,JBX-151,RTX-450,PATRIOT,...
Jul 12, 2012 | Whistler MC100 2-Way Radio
May 20, 2012 | Sirius Satellite Radio Receiver
Feb 08, 2011 | Radio Shack Pro-2018 Scanner
Jun 23, 2009 | Shure Beta 58A Professional Microphone
Jun 14, 2009 | Garmin GPS III
Dec 28, 2008 | Pyramid PDVD79 CD Player
Mar 06, 2008 | Whistler WGPX-550 GPS Receiver
Nov 30, 2007 | 3300 Radar Detector
135 people viewed this question
