Question about Hitachi Televison & Video
Hi,I have hitachi cle-996 tv, it gives pink light instead of red color and not working, what is the solution ?
Usually when we off the tv it gives a red color but now gave a pink color and not opening !!!!
Posted by Ramzi Al Banna on
Tom Chichester
    Top Expert:
  • Hitachi Master
  • 56,126 Answers
Could be a failing power supply
Posted on Aug 15, 2019
5 Related Answers
bluegreenash
Gareth Cockram
  • 661 Answers
SOURCE: hitachi cle-990
not sure your model number is correct please check here is a manual for the 42 CL plasma TV http://www.hitachiserviceeu.com/scripts/userguide.php/CL42PD2100_EN.pdf if it is a different set please check the model number, this should have a 42 in it (as it is 42")
Posted on Sep 27, 2007
chrispurs1
chris pursloe
  • 372 Answers
SOURCE: hitachi remote CLE-967
Hi.
I wrote an article on how to repair remote controls.
You will find it here.
http://www.ehow.com/how_2094701_tvvcrcabledvd-remote-control-quick-easy.html
Chris.
Posted on Nov 21, 2007
Anonymous
SOURCE: HITACHI Projection TV 53FDX20B having too much red color
my hitachi projection big screen tv 57SWX20B has a draping affect across top of screen why?
Posted on Dec 31, 2007
Anonymous
SOURCE: tuneing in my tv
Hi There
Came to this site with the same problem - finding no answers I went back and tried again
Hope this isn't too late for you. Press the 'MENU' button - you'll get the picture sound etc - keep your finger on it and you get 'INSTALLATION' at the bottom in white!
Hey presto! use the <&> to get into the sub menu and away you go!
Hope this was some help
(P.S. use the menu button on the front of the set if the remote button fails to bring up the installation option = it is behind a flap between the on/off button and the indicator lamp under the screen)
Posted on Jun 28, 2008
Anonymous
SOURCE: manual tuning of Hitachi cle-942 tv
Select the channel to tune & press "CH" this is the key to the right of zero on the CLE-942 remote, Now you can tune the selected channel. You also need this key to sort/move channels after running auto tune.
Posted on Aug 29, 2009
Hitachi cle 1018A tv remote replacement remote
For replacement of Hitachi TV remote controls under warranty, including CLE-1018A (for TV model DF4000DV and perhaps others), you need to contact Tempo Australia, phone 02 9975 2199 or 1300 886 649 (you may need to stay on the line for more than 15 minutes before you can talk to someone). Hopefully they can also advise you on purchase of a remote control if you are not making a warranty claim.
Dec 23, 2013 | Hitachi Televison & Video
What causes my picture to go pink all of the sudden ?
Examine the screen with set on and color set to zero--stand back and look= is screen pink to red color?
If so it may be a common issue on this Hitachi.
Usually it is an adjustment inside the set of the red screen control needing to be turned just slightly down---these are known for the red control "drifting" just slightly from time to time--answer is based on model number indicated here.
May 31, 2012 | Hitachi 46F510 46" Projection HDTV
My hitachi CLE-993 is not working on my TV but there is a red light on the remote every time I press any key...What should I do??? Please help...Thanks
I am also facing the similar problem with CLE 999, LCD is not functioning !!!
Anybody knows to rectify, pls. provide solution.
Rgds, PK
Jul 22, 2011 | Televison & Video
Manual tuning of Hitachi cle-942 tv
Aug 20, 2009 | Hitachi HL01453 Remote Control
Hitachi CLE-976 problem.
The CLE-976 was no a cellular phone but a remote control for a Plasma TV. I contacted Hitachi Australia who put me into contact with a company that sell spares.
Thanks
Aug 04, 2009 | Sprint Hitachi P300 Cellular Phone
Color correction
You can try complaining to Hitachi, but they won't admit to a problem. A new light engine is necessary as this is what they describe as "a technical issue" with this type of TV.
It will cost upwards of $600.00. Good luck, the more complaints they get, the better. I would never recommend a Hitachi to a friend (or enemy) after the treatment I recieved from the customer service reps.
May 13, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Color adjustment issues.
Do you have a red, and or pink, or blue spot in the middle?
Jan 21, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Pink picture
Pink may be a register value being changed in the TV's computer. The laptop method is usually the only way to change that. Make sure that you use a goos surge supressor with cable connectors. If the picture is really a Red blob (It could be Blue or Green though.) in the center, it may need a light engine. That is an expensive repair by a qualified tech.
Sep 15, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Pink Screen
There is a service bulletin for this problem - you need to reintialize the memory settings in the service menu - I have a pdf file showing how to do this.
Sep 09, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
32 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
