We tried to turn off TV, picture went darkthenlight that shows power is on/off started blinking - we tried turn tv back but only blinking light-unpluged tv right away but now the tv does not turn on
It is 70 inch Sharp tv
Posted by Elvira Ramirez on
Ed Cole
    Habit-Forming:
    New Friend:
  • 123 Answers
Check the power relay. Check power supply voltages.
Posted on Aug 18, 2019
5 Related Answers
Anonymous
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
Anonymous
  • 790 Answers
SOURCE: Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Posted on Oct 02, 2007
tomcat2008
SOURCE: HD61G787
Its the lamp
Posted on May 03, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: toshiba 46H84 tv turned off light blinking
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
ASTAR LTV-3201 will not show picture anymore
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance.
Dec 27, 2008 | Astar LTV-3201 32 in. LCD Television
JVC TV WENT OFF. TURNED IT ON AND THE LAMP LIGHT STARTED BLINKING
If the Fan is clogged up with dirt set will not run fan must be working.
Dec 01, 2008 | JVC AV-30W776 30" TV
No Picture - Sound
I just had this problem fixed. In my case, it was because the insulation on the CRTs was cracked, and when it would warm up, the shielding would separate and would let 5000 volts arc across the main board. This, obviously, damaged the board. The tech didn't catch the arcing right away, so they replaced the main board twice before they used a high-temp RTV to patch the insulation.
The power-cycling was a result of the damaged board.
The point of this story is that the broken part may be a symptom of the real problem.
I hope this helps someone!
May 29, 2008 | Samsung HCN653W 65" Rear Projection...
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
