SOURCE: Air Temperature Sensor
most of times it is located on the big breather hose after the air filter
SOURCE: need to locate are temperature sensor
Should be located in air intale hose / tube between air filter and throttle body. Hope this helps Good Luck
SOURCE: Air charge temperature sensor replacement
There are two of them. I mean sensors. One of them is IAT and another is Mass Air sensor ! But which one , where I don't know. Somebody help please !!!
SOURCE: Climate control air conditioner stops working due to incorrect ambient air temperature
Same car, same problem. Press MODE, FRONT and REAR buttons together to reset tempreture. You probably need to replace the sensor GM part number 15047946 it is in the front grill email me for a picture. [email protected]
SOURCE: sensor locations
air intake look at snorkel it could be part of mass air flow check intake for eng coolant
