Question about Manitowoc Kitchen Appliances - Others
Is it plugged into a new or older outlet,and is it plugged in by itself,with no other appliances effecting its power
Posted on Aug 15, 2019
SOURCE: ice cube cycle time very high
i suspect a defective liquid line or pump down seleonid coil. just make sure you hear the "click" when it starts up if not the selenoid coils could be defective. also verify that the condenser fan is running,because if not you are short-cycling on high head pressure. please contact if you need any additional info
Posted on Jun 13, 2008
SOURCE: How Do I maintenance a manitowoc series 150 ice machine
find the filter remove clean with water, coils should be shiney. This should fix the problem
Posted on Jul 23, 2010
SOURCE: i have a model qd0452a manitowoc and it will not
Very unusual for one of these to not stop. There is a magnetic proximity switch located on the bottom right side of the water curtain that serves to both cancel a harvest/drop and to shut the unit down on a full bin. When a drop occurs the control board sees a open and then close of the switch and restarts a freeze mode. If the ice drops and the bin is full the curtain is blocked by the ice behind it from closing again and the unit shuts down on a full bin indication. If the curtain does not open and close after 3 hours it would lock the unit out. Therefore I assume that the switch and the board are working. Most likely you either have the unit on a non-Manitowoc bin or are missing a deflector plate in the Manitowoc bin and the ice is falling out of a service door.
Posted on Dec 11, 2010
SOURCE: manitowoc series 100 makes ice but wil not go into
I'm not sure what you mean by a series 100. Manitowoc series are by the model number first letter. B-series, Q-series, J-series, etc. A 100 lb Q-series would be the most recent. If memory serves they started with A, C, E, G, B, J, S, and are now on Q. You can get most of the service books on their website here.
http://www.manitowocice.com/?xhtml=xhtml/mii/us/en/general/productdownloads_service.html&xsl=productdownloads.xsl
Sorry I cant be of more help without a complete model number.
Posted on Jan 04, 2011
SOURCE: My Manitowoc Ice machine is making ice slowly and
You're bridge thickness is set to high, lower the bridge on the sensor located when you open the front door behind the water curtain on the top. If the sensor is scaled badly replace it.
Posted on Feb 14, 2011
Sep 07, 2016 | Manitowoc QM30A Self Contained 65Lb...
Aug 25, 2015 | Kitchen Appliances - Others
Sep 24, 2014 | Manitowoc Indigo Ice Machine - Full Dice,...
Aug 05, 2014 | Manitowoc Compact Undercounter Ice Machine...
Jan 17, 2014 | Manitowoc QY0135W-251 Half Dice Water...
Nov 02, 2013 | Manitowoc Kitchen Appliances - Others
Nov 08, 2012 | Manitowoc 1400 Modular Ice Machine Sd1492n
156 people viewed this question
