Question about Freezers
Can 2 chest freezers be plugged into a 100' extension cord and freeze properly?
2 chest freezers plugged in a multi plug that is plugged into. 100' extension cord? Will this work properly?
  • J Rosado Aug 14, 2019
    years*** yields
J Rosado
  • 1,202 Answers
Use an oversized AWG cord, e.g. #12, #10 AWG to avoid voltage drop in the cord. I guess each unit needs 5 amps for total of 10 amps when both run at once.
With a 14 Gage cord (0.5 ohm @ 200' wire) and with both units starting up at same time, the current (amps) draw is 60 amps (6x running current) and 1800 watts, the 1800 watts consumed by the cord, this power dissipated as heat. The 1800 divided by the 60 ( watts/amps = volts) years a voltage drop of 30 volts, at start up of the two compressor motors if at 5 amps flc (full load current). This scenario with a 14 gage, 100' cord is problem bound so a thicker wire cord is needed to keep voltage drops within 10% of the load's rated voltage. Use a 10 or 12 Gage cord or two separate cords.
Posted on Aug 14, 2019
5 Related Answers
Anonymous
SOURCE: new chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Posted on Aug 24, 2008
Anonymous
  • 163 Answers
SOURCE: freezer not freezing
Hi!!!you have a seal system problem..
Posted on Jan 04, 2009
nnesmith
harold nesmith
  • 162 Answers
SOURCE: Outside of chest freezer gets hot
it is normal for outside to get hot. that is where the condensor coils are located. if unit is working don't worry.
Posted on Jul 26, 2009
geoff hunter
  • 4793 Answers
SOURCE: My Norfrost chest freezer has stopped working will
which means that it is operating manualy...could be the thermostat needs replacing...
Posted on Mar 03, 2010
Keith Turner
SOURCE: i recently bought a norfrost chest freezer model
Can't help I'm afraid, but we have exactly the same problem with exactly the same model. Ours did work for nearly 2 years, but recently only works with the boost button pressed in. I suspect the thermostat is not working as the boost button over-rides the thermostat to give max cooling. Your freezer is new so get it exchanged; it certainly doesn't need to be full to work!
Posted on Feb 26, 2011
I have a Kenmore 5 cu ft freezer that won't come on. I've checked the plug in and it works fine. Where would I start looking for the problem????
If, by plug in you mean the socket, then you need to check the fuse in the power plug next.
At the very lease there should be some light on the unit that illuminate even if it does not FREEZE.
If the compressor comes on wait to see if there is any drop in temperature. then it is possible the fuse was faulty.
see below links for more information on possible causes
How to fix Kenmore chest freezer model 255 19502010
Kenmore 5 cu ft 142 liter Chest Freezer 14512 Page 11 Recent Questions...
Jul 18, 2015 | Kenmore 5 cu. ft. / 142 liter Chest...
QWhy won't magic chef 6 cubic chest freeze freeze anything after I defrosted it?
Try plugging something else in the outlet. A lamp would work to make sure you did not trip a circut breaker when you plugged back in after defrost.
Apr 23, 2014 | Magic Chef 5 cu. ft. / 142 liter Chest...
Fast freeze light on all the time is this right new belling 100 ltr chest freezer
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
Feb 02, 2013 | Magic Chef Chest Freezer MCCF5WBX
The freezer is cold, but, ice is melting. Its running and the run and power lights are lit up. I removed ice(very little) around the top edge to make sure the door closes shut. It was just fine last n
All I can offer for advice is to ask if it is on an extension cord. Is the freezer plug in good shape and not blistered? Make sure that the cord is a heavy enough gauge to carry the current needed to run the compressor. An extension cord can break down over time and cause the compressor to overheat or fail. Wish I could be more help. Good luck!
May 02, 2012 | Magic Chef Chest Freezer MCCF5WBX
My chest freezer shut off (the outside light was
Try to plug somthing that you know it works ,in that outlet ,and if it doesn't work or goes on and off , the problem is in the outlet, but if works without trouble ,the problem could be in the freezer plug , the cord or the cord conections to the freezer.
Sep 13, 2009 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
Problem with Maytag Chest Freezer model MQC1557aew.
First make sure than the condensing coil in the freezer is clean of dust and dirt(it is behind the grill vent in the bottom side of the freezer where the compresor is) If it is clough brush the dirt off after you unplugit.When is clean wait a few minutes ,5, and plugg it back at the GFI outlet and see if work If still tripped the outlet you may have to replace it.
Apr 04, 2009 | Maytag 14.8 cu. ft. / 419 liter Chest...
Freezer not freezing!
try plugging the electric cord into a receptical
Feb 18, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Freezers Logo
150 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
