Question about Vizio Televison & Video
I have a vizio e65-e1. It is unbearably dim. Sound works. Backlight is on. Picture is there. Just so dark you have to be 1 inch away to see it. Went through settings and set backlight to 100 but didnt change a thing. Ive got the back off and nothing visibly burnt or swollen. Where do i go from here? Please advise.
Posted by JC Bear on
Ed Cole
    Habit-Forming:
    New Friend:
  • 123 Answers
There are strips of led's that control the brightness of your picture. Check the driver board and also check to see if all led's are lit. Go to shopjimmy.com for parts and how to.
Posted on Aug 18, 2019
5 Related Answers
Anonymous
SOURCE: how do i get my backlight to turn on.
The screen is messed up. You have to buy a new screen for about $70
Posted on Mar 17, 2008
Anonymous
SOURCE: Display backlight problem
i have the same problem, i thought it completely blacked out, but i realized it was just the main backlight. i can see it if i hold a flashlight to it, but i tried everything to fix it, and ive had no luck.
Posted on Jun 24, 2008
Jason Morris
  • 362 Answers
SOURCE: Sony Bravia LCD KDL32M3000 picture going dark
Sounds like it may be the backlight ballast on the inverter. Hopefully you are still under warranty, Call customer support even if you are out of warranty and explain problem. In English: 1-800-222-7669 or 1-888-772-7669
Hours: Mon-Fri 8:00AM-12:00AM (Midnight) / Sat-Sun 9:00AM-8:00PM EST
In Spanish: 1-800-222-7669 - Follow the (English) voice path for your product, and then select the option for Spanish support
Hours: Mon-Fri 9:00AM-10:00PM / Sat 10:30AM-7:15PM EST
If they can't help let me know and we can diagnose the problem together. Let me know if this helps and please rate this solution. LOne99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 17, 2009
Anonymous
  • 56 Answers
SOURCE: vizio p42 very dark screen backlight off
There is no back light in plasma TV, Base on the description, the Z Sustainer board is bad. Replace the board will fix the problem.
Posted on Feb 17, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: Toshiba 22LV505 TV-DVD:
Check the DC filter caps in the power supply first. Check the 24vdc (or 18vdc for this 22" model) to see if it goes away when the screen goes black.
There are main AC fuse, backlight inverter fuses, T-CON fuses.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 08, 2010
FIGURE OUT WHERE TO START DIAGNOSES
https://www.youtube.com/watch?v=sDwZQIZB... try this video 1st.sounds like your problem.
Jul 07, 2016 | Vizio E701I-A3 70-inch LED-backlit LCD TV...
No picture, sound works good
Sounds like a backlight fault. Dim the lights in the room and turn on the set. Shine a bright flashlight on the screen, you should see a faint picture. If you do, you have a backlight problem
Oct 28, 2013 | Vizio Televison & Video
Vizio xvt3d554sv
it is s problem witg ccfl backlight , the amazon link is just example, you must get the corect length of tube, and size
Oct 13, 2013 | Televison & Video
I have had my 55" Vision for a year and a half. Today I was watching a movie and the picture went dark and audio stayed on. If I turned the TV off and then back on it would light up with no Vision logo...
Sounds like you have a backlight problem. To verify this, turn on the set and dim the lights in the room. Take a bright flashlight and shine it on the screen. If you see a faint picture, you either have a back inverter or a bad backlight bulb.
Sep 02, 2013 | Vizio GV42L 42 in. LCD Television
VX37L Screen Suddenly Went Blank, Now No Image, Sound Only on Cable Input, VIZIO Logo Lights Up
turn on the set, grab a bright flash light and dim the lights in the room. Shine the flash light on the screen, if you see a faint picture on the screen, you are dealing with a backlight problem. There are several things that can cause this. One, a bad backlight inverter, two, faulty 24vdc power supply, three, bad main board, or a bad faulty backlamp.
May 10, 2013 | Vizio VX37L Television
Vizio vo47L 47" LCD. No
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
More specifically on #1 and #2 - capacitors either bulging, leaking, or exploded.
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
[email protected]#$
Feb 04, 2011 | Vizio VO47L 47 in. LCD TV
Vizio HDMI HDTVmodel VW48LHDTV10A TV sound went out and the picture got dark from outside of the screen
The inverter board is common on this set to go out, once dark then you can use a flashlight to determine that it is bad, 2 in away from screen and you should see the picture in background, the sound is something else, it will be located on the main video board, look for bad caps bulging out.
Jan 23, 2011 | Vizio VW42LF 42 in. LCD HDTV
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
Dark screen
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
Mar 25, 2008 | Vizio L37 Television
Televison & Video Logo
24 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
