Question about Vizio Televison & Video
Vizio tv picture is fine but getting no sound
Posted by Marla Sattler on
Franco Dosil
    Top Expert:
  • Vizio Master
  • 10,535 Answers
Hi Maria, indicate the model of your Vizio TV
See if it has a headphone output, if it has one, connect headphones and check for sound
If there is no sound, you may have a problem on the main board
Try going to the sound settings and settings and check that the speakers are enabled, if not, activate them, if they are activated, consult a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Maria, indica el modelo de tu TV Vizio
Fijate si tiene salida de auriculares, si la tiene, conecta unos auriculares y comprueba si hay sonido
Si no hay sonido, puedes tener un problema en la placa principal
Prueba ir a la configuracion y ajustes de sonido y comprueba que los altavoces esten habilitados, sino lo estan, activalos, si estan activados, consulta un servicio tecnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
Posted on Aug 15, 2019
5 Related Answers
Anonymous
SOURCE: Buzzing sound on Vizio Plasma TV
hums when certain appliaces are used washer microwave skill saws
Posted on Feb 02, 2009
Anonymous
SOURCE: Sound but no picture on Vizio WS42L TV
did you ever get it resolve? I am having the same problem. my tv is a year and and 1 week old. I am so upset.
Posted on Jul 27, 2009
hvdshgvdr
SOURCE: Vizio 42" tv has no picture but sound. What is
the problem is in your 42 tv bec.of your dirt tv ok
Posted on Apr 10, 2011
SD Tech
SD Tech
  • 14553 Answers
SOURCE: vizio 32" HD flat scene tv no picture no sound will not turn off
if no picture no sound how can it turn off--you mean a light is still on? Let me also know age of set and if any odd things before it failed like had to turn on several times etc.
Posted on Apr 24, 2012
SD Tech
SD Tech
  • 14553 Answers
SOURCE: 42 lcd hdtv vizio has sound but no picture
common problem with no common or single answer===time for a repair shop or a tech.
Posted on Sep 04, 2012
My vizio model# E480-B2 was working fine one day and the next when I turned it on I have no picture.. Perfect sound ! Does anyone have any ideas?
Hi , The link below is a YouTube page full of videos showing how to fix a Vizio television NO picture GOOD sound, I hope this helps....... CHEERS..
Vizio Tv With No Picture Good Sound YouTube
May 09, 2016 | Vizio Televison & Video
How to fix vizio tv that turns on but no picture
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen ... Was working fine and now blank ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little research and fixed it. ... vizio E701i-A3E ...
Vizio LED TV Repair - TV Has Backlights but no Image on ...
? 5:06
https://www.youtube.com/watch?v=fSCf1xxLjNA
Aug 27, 2015 - Uploaded by ShopJimmy.com
Basic Troubleshooting Help if your Vizio LED TV has a blank screen and no ... It is on an UPS but turned off ...
Dec 10, 2015 | Vizio M3D650SV 65 inch Class Theater 3D...
47" Vizio LCD Smart TV, left half of picture is black & other half works fine. Sound works fine.
when i start tv 1minit picture show 1minit after no picture but sound have
Nov 18, 2013 | Televison & Video
Black screen with sound
My 47" LCD Smart T.V. was working fine last night. I got up this morning and I have sound but no picture. The VIZIO icon lights up as usual but I get no picture, only sound. From the time I turned it on, nothing appeared on the screen. I have already tried unplugging it for a while and still nothing.
Oct 24, 2012 | Vizio VO47L 47 in. LCD TV
VIZIO l37hdtv10A, NO SOUND, PICTURE WORKS FINE
if you have headphone connection on tv then try with it.if headphones work that means speakers are faulty.if it doesnt then try with external speakers connection if your tv have one.mostely speakers gets faulty
Jun 11, 2010 | Vizio L37 Television
Picture went out on TV
you need to change the sustainer boards and TV will be good as new.
Apr 05, 2009 | V, Inc. Vizio P4 Plasma Television
P50 VIZIO WHEN ON HDTV I GET SNOW
it's probably the Time Warner cable box that have issue and not the TV. Try using a DVD player and test the same input, it should work fine.
Nov 15, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio sp42a
your tv is having a problem of more than one component .to get rid of the problem u should rectify your vif horizontal and vertical sections
Sep 24, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
TV problem
any luck? might 37" vizio just had this problem, all of a sudden no picture sound just fine, I call vizio and they say could be motherboard, do I bother fixing this, or just get a new one?
Nov 16, 2007 | Vizio L37 Television
Televison & Video Logo
15 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
