Question about LG Refrigerators
The door within door lg fridge should only open when a button on handle is pressed. However, it takes several tries to secure the door within door to open fridge proper.
Posted by Nancy King Macht on
David Spradling
    Top Expert:
  • LG Master
  • 11,320 Answers
Replace handle spring is bad
Posted on Oct 10, 2019
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: Driver side exterior door handle pulls the locking
Take the door panel off the inside of the door. (Should involve screws at the bottom, plus bolts through the interior handle. Then pull out at the bottom, and lift upward Google for expedition door panel removal for more specifics if needed).
It sounds like the exterior handle linkage is binding against the lock button linkage. Actually looking in while pulling the handle would confirm. You then should be able to just bend the rods a bit to move them apart.
Posted on Mar 10, 2009
Anonymous
SOURCE: 2002 Volvo S60 AWD Fuel door won't open
It more than likely may be the fuel pump. My girlfriend recently had the same problem with her S60 I came across a recall for the fuel pump. I took it by the dealers and they took care of it free of charge. The only negative thing I guess is that they kept it for a few days.
Posted on May 20, 2009
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: HAVE AN LG FRIDGE MODEL LRFC22750. THE LIGHT
EFFECTIVE FROM(SERIAL NO.) from 704MR***** to 801MR***** Subject Lamp Cover Melting Improvement (LG 3D Basic) / 2nd No. Loc No. Before Change After Change Note K-Code Remark Part No DESC./SPEC. Part No DESC./SPEC. 1 501A 6871JK1011A PCB Assembly,Main /
6871JK1011D PCB Assembly,Main /
WINNER1 DISPENSER ENERGY STAR '08 C 3 Change Relay SPEC. 2 503F 3111JJ1001X Case Assembly,Display /
WINNER1 BASIC BRAND ABQ33905315 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 3 503F ABQ33905304 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 4 409B 6912JK2002C Lamp,Incandescent /
60W 120VAC 0.40A 480LM - WHITE 6912JK2002E Lamp,Incandescent /
C 3 60W to 40W
Posted on Jun 12, 2009
Anonymous
SOURCE: 2001 Ford Explorer Sport
Common problem on 2001 Ford Explores. The reason why your door handle doesn't unlock the door(can't be unlocked by remote either)is due to a broken spring located on the backside of the door handel INSIDE the door. True that your one(or two) of your small exterior springs on your door handle are broken(will cause your handle to flap) but this IS NOT YOUR PROBLEM. The door locks will work if there is a bit of tension holding the handle bracket up. I know it's hard to explain without pics. but here's the ONLY WAY TO FIX THIS. It's not that hard.......... Remove the door panel, only a few screws and a few more holding trim around exit handle then, pull out "snap in" clips on bottom. With a flashlight you'll see back side of door handle. To get to that area you'll have to remove one bolt holding a window frame. Do that(with window in up position) then slide down rail, out of your way. Now, get back to handle. With your light aimed at the backside of handle left slowly the door handle as normal, and you'll realize(while looking at the mechanism) that tension(pulling down of bracket) needs to occur in order for locks(manual and remote)to work properly. Trust me.....you'll figure it out. Once you do, get a spring(pen spring, 30 cent hardware store spring, any small spring!) and hook one end to bracket and the other end to ANYTHING(OUT OF THE WAY) below the door handle thus, causing SLIGHT tension. Try your locks...THEY WILL WORK! YEAH! Replace that one window frame bolt(try your window...just the make sure), replace door panel and your done. TOTAL COST: 30 cents or FREE(if you have a small spring) Ford dealers will charge $150 to $285! Yikes!
Posted on Jun 14, 2009
m22loud
  • 136 Answers
SOURCE: when pressing the remote button on my freelander
sequence for freelander lock unlock, to lock 1press = door lock , 2press = door dead lock , to unlock 1 press = driver door unlock, 2 press = passenger doors unlock, also rear window can be operated from fob to do so press and hold unlock button for 3 or more seconds and rear window will roll down.neat feature.hope this helps please feel free to contact me on fb( marcus loud)
Posted on Aug 13, 2009
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
My keyless entry for my 2008 Volvo s 40 won't work. I've tried replacing the battery but it still doesn't work. Anything I may can do before spending money on a new key.?
How are you trying to open the door , button on key fob ? With this system you can pull up on the drivers handle an it activates Antennas in the external side door handles (C30/C70 front doors, S40/V50 rear doors)
  • Antennas in the passenger compartment and cargo compartment
  • An antenna in the rear bumper
  • Quick lock motors in the lock units in the side doors
  • The remote keyless entry (RKE) receiver receives a signal from the key
  • The switch in the clutch pedal (manual transmissions) or a signal from the brake pedal switch via the central electronic module (CEM) (automatic transmissions)
  • Key-in switch.
  • Switch in door handle and lock button on handle .
    If a door handle is pulled outward, a switch closes that wakes up the system and activates the antennas in the handles on the side where the handle has been pulled out. If a valid key is within a radius of approx. 1.5 metres from the handle, the relevant door will open and the vehicle will unlock one or several doors. Which doors are unlocked depends on the settings for the system. The vehicle can also be unlocked if the handle is affected on the tailgate.
  • Jan 29, 2015 | Volvo Cars & Trucks
    How to program remote for viper 650xv?
    You can find a copy of the manual at the link below or try this:
    1. Open driver's door - leave it open (door trigger must be connected on the alarm).
    2. Turn ignition key on.
    3. Within 5 seconds, press the valet/programming button once and release.
    4. Press valet/programming button again and hold it down.
    5. With valet/programming button held down, you should hear the siren chirp within a few seconds. After the chirp, press the lock button on your new remote.
    6. After pressing the remote's lock button, you should hear a short blast from the siren. Now release the valet/programming button.
    Viper 650XV Installation Manual
    May 13, 2014 | Basic Remote Vehicle Alarm System
    My lg fridge is giving me an error code of FF what is this mean
    Your LG refrig is in Demo Mode.
    1.- disconnect power supply and reconnect
    If the error continue
    1.- Open the door of refrig.
    2.- Press button "Refrigerat" while press "Ice P" button 15 seconds
    If the error continue try again
    Is important for people who share their knowledge, know your comments.
    If the answer is helpful, rate my answers
    Sep 22, 2011 | LG Microwave Ovens
    Mercedes c class 2001 elegance, key fob not working everytime its pressed. I have had the batteries checked and they are still working fine, any advice as to what is causing this?
    Most likely needs to be re matched to the car.
    Two bits of info off the net for you
    C CLASS (1993-1997), E CLASS (1995-1997), SLK (1996-)
    Procedure
    1. Point the remote control at the receiver - this should be located in the driver's door handle or next to the boot lock button.
    2. Press the lock/unlock button.
    3. Within 30 seconds manually lock or unlock the vehicle using the passenger's door lock or the boot lock.
    Alternative method
    Procedure
    3. Within 30 seconds, switch the ignition ON.
    Alternative method
    Procedure
    3. Within 30 seconds, turn the ignition switch to position II.
    and
    1. Place key in ignition lock and turn to position 2 [all ignition lights on]
    2: Turn key to off position and remove from ignition.
    3. Within 10 seconds:
    3a: press the Close [Lock] button and hold it down
    3b: while the Close button is still depressed simultaneously press the Open [Unlock] button. Press and release the Open button 5 times [still holding the Close button down]
    3c: Release both the Close and the Open buttons at the same time, and immediately push any of the two Open buttons once [i.e. either the Open doors or the Open Tailgate]
    This information is for the resetting of a previously synchronised key to match the security system after batteries have been removed or replaced. This information does not work with new keys which it seems must be taken to a person with a key synchronisation device [or a super-ripoff-expensive MB dealer]
    hope this helps
    Aug 13, 2011 | 2002 Jaguar X-Type
    Lg fridge code er ff does not cool in fridge
    ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
    Jun 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
    Fisher Paykel fridge door handle loose
    Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
    Nov 07, 2008 | Refrigerators
    Battery died now power sliding doors and rear hatch not operating
    1) Unlock all doors from driver's door while it is open. The driver's door is the only door to remain open during this process! 2) Turn the key from OFF to RUN 8 times within 10 seconds, with the eighth turn ending in RUN. All the doors will lock and unlock if program is successful. 3) Turn key OFF and remove key from ignition. Within 20 seconds, press any button on the remote. (Press sliding door or rear hatch and it will open!) 4) If door locks do not respond, wait several seconds and press button again. If doors still fail to respond, try repeating steps (1-3).
    Jun 16, 2008 | 2005 Ford Freestar
    Door not opening LG front loader washing machine
    Try: Program the select knob at 6 o'clock position. Speed at 9 o'clock. Press pre-wash and the power button together for 4 to 5 seconds. Hopefully it will unlock.
    Sep 24, 2007 | Washing Machines
    No water or ice through door
    sounds like the dispenser assembly is not sensing that the trap door is opening fully, so it wont send power to the auger motor or fill valve. If you are pretty handy, you can disassemble the door and take out the dispenser assembly and try to take the assembly apart and correct the throw on the trap door. Otherwise, I'm afraid you need a new dispenser to the tune of about $250 parts and $225 trip and labor. Good luck!
    Nov 07, 2006 | Sub-Zero 690 Side by Side Refrigerator
    Refrigerators Logo
    177 people viewed this question
    Top LG Refrigerators Experts
    John Tripp
    John Tripp
    Colin Stickland
    Colin Stickland
    Are you a LG Refrigerator Expert? Answer questions, earn points and help others
