Question about Kitchen Appliances - Others
How can I get the to control rod turner for the ice maker in the back of my freezer? Kenmore Side by Side. 795.5101
I have a Kenmore fridge: 795.5101. The ice maker only crushes ice. I've taken out the ice bucket and as I look to the back of the freezer, I see a square hole. In there, I see a pin like item with a plastic square that is loose as well as a soft foamy square that has a black cylinder attached. I'm trying to figure out how to get the case off so I can place that thing back on. Suggestions?
Posted by Eddie on
5 Related Answers
Anonymous
  • 26 Answers
SOURCE: Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Posted on Mar 18, 2008
David Coomer
  • 1073 Answers
SOURCE: Ice maker is not working
if you keep your hands out of the little beam slot on the paddel that is located on the left of the freezer and push it in the beam should shoot across to the reciever on the right and the light should stay on constant, that is if you have the switch on the right side turned on.
if it is turned on and the paddel is depressed and the light is still blinking the you need a beam kit part number 4389102
Posted on Apr 12, 2008
Anonymous
  • 505 Answers
SOURCE: LG ice maker will not dispense cubes without crushing them
,first if you still have ice buildup get your hair dryer and heat it up and melt it,then remove the front off the icemaker,you have a cube size dial,turn it down and it will reduce the amount of water that goes into the icemaker,if that does no work go on ebay and pickup a univeral icemaker for around $50,hope this helped
Posted on Oct 31, 2008
Anonymous
  • 111 Answers
SOURCE: GE GSS25LGM Ice maker not dispensing ice
You have one of three things wrong. The auger motor is frozen up, the ice bucket is broken or you need to dump out any ice, run warm water through the entire ice bucket, dry it out and try again with fresh cubes. My guess is the auger motor is frozen. You can buy a vinyl boot that covers the auger motor to prevent moisture buildup and freezing from GE Parts at 1-800-626-2002
Posted on Dec 16, 2008
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Maytag Plus MSD2556AEW - frozen puddle on freezer floor
Here I am going to give you a lot of information. Because of the leaking your defrost condensate drain is most likely the reason. All on the page below may not be for your situation and some refrigerators do this over a period of time and the the water has no were to go but the freezer during defrost. Click on link below, Thanks, Sea Breeze
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Posted on Aug 17, 2009
Testimonial: "Thanks Sea Breeze! The photos do show a bit of a different arrangement than what is on the back of my fridge but I'll try what you suggested."
Kenmore fridge model 596 - 79213014 2 yrs old accumulates ice at the bottom freezer. The fridge has built it ice maker but we did not opt for that option. Can anyone pls advise how tofix the problem?
IS THERE A CONTAINER FOR THE ICE TO COLLECT IN UNDER THE ICEMAKER??? IF NOT YOU WILL NEED TO GET OR ORDER ONE..
NEXT THERE IS A WIRE LEVER ON THE RIGHT SIDE OF THE ICE MAKER. WHEN THE ICE PUSHED THAT LEVER UP IT WILL QUIT MAKING ICE. WITH YOUR HAND GENTLY LIFT THE LEVER UP UNTIL IT STAYS LOCKED IN THE UP POSITION... ONCE IT IS IN THE UP POSITION ... IT WILL NOT PRODUCE ANY ICE.
Dec 29, 2014 | Kenmore Refrigerators
Kenmore refrigerator side by side. EnergyStar sticker says model series 56541-56551. Freezer side cold; fridge side between 50 and 60 degrees. I unplugged for at least 2 days for ice to melt. Fan at...
If there is ice built up on back inside freezer wall, you have a defrost problem. Either defrost heater, defrost thermostat, or defrost control (timer or Board) is bad.
Sep 05, 2017 | Kenmore Refrigerators
Water is leaking from the Ice maker on top of the
the water valve on the back of the fridge has malfunctioned.
Jul 21, 2010 | Kenmore 57029 Side by Side Refrigerator
Ice maker crushes even when it is in the cube
If you pull out your ice bucket and look on the bottom you will see a long brass colored rod. Now, if you look inside your freezer section. you will see the slot the rod enters each and every time you insert your ice maker bucket. In the down position (normal) it produces crushed ice, When you switch the lever in the front for ice cubes, there is a plunger that lifts the rod and produces the combination that only allows ice cubes to come out. I would first check the plunger behind the panel and see if it is free.If it is not free it can cause the ice to be crushed...
Jun 06, 2010 | LG LSC26905TT Side by Side Refrigerator
21' bottom freezer kenmore refrigerator-no ice maker-the fridge is super cold and freezes all my vegetables and fruit. We have cleaned the coils, cleaned the fridge, and it just keeps freezing. Fridge is...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 02, 2009 | Kenmore 21.0 cu. ft. Bottom Freezer...
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge Leaking
the icemaker can overfill causing water to run over into the freezer
the fill cup on the back of the icemaker could be frozen letting the water overflow into the freezer
if the fill cup is not frozen then you need a modlue for the ice maker if it is whirlpool built, if ge or frigidaire design then replace the icemaker
May 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore ice maker
If the ice ejector (the plastic part) is pointed down and not pointed between 10 and 3 o' clock the ice maker motor has failed or somethin is binding. Replacing the ice maker is probably the best bet.
Aug 14, 2007 | Kenmore 57029 Side by Side Refrigerator
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Kitchen Appliances - Others Logo
144 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
