Question about Kenmore Refrigerators
What is code er 1f on kenmore elite refrigerator.
Posted by Jerry kidd on
Chris Walker
    Top Expert:
  • Kenmore Master
  • 1,551 Answers
Posted on Aug 18, 2019
5 Related Answers
Anonymous
SOURCE: I have a Kenmore Elite Trio Refrigerator. The
I have the same problem what is the solution
Posted on Dec 22, 2009
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: what does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jun 30, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore Elite 79577563600 is showing Er 1F.
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#@%
Posted on Sep 23, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore Elite Refrigerator, Model No.
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: my trouble codes are Er FF on my kenmore elite
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
What is 1F code on kenmore elite refrigerator
The Er IF error code indicates that the main control board detects that the ice compartment cooling fan is not working. This will cause a lack of cooling in the ice compartment and will normally result in no ice production. This is something that a service technician will usually need to correct.
Apr 17, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error message Er 1F
Maybe this will help. i would check fan first and see if ice has built up in fan.
https://www.youtube.com/watch?v=a4MdwuoN3jc
May 26, 2017 | Kenmore Refrigerators
Managemylife
That error comes from a failing fan due to ice build up which directly affects your ice maker.
Feb 26, 2014 | Kenmore Refrigerators
I have the Kenmore Elite Model # 795.79773.901 and I keep getting Er 1F. What does that mean and what do I do to fix it?
Hi and welcome to FixYa, I am Kelly
I hate to just paste a link to the answer but this answer is quite thorough:
http://www.managemylife.com/mmh/questions/116713-getting-er-lf-fault-code-kenmore-elite-refrigerator
If you have frost build up in the freezer compartment it can impede operation of the fan. Frost build up is usually a secondary symptom of an automatic defrost system problem. i.e it is not defrosting... due to a failure of one of the following:
-defrost heater
-defrost thermostat
-defrost control
Hold the door light switch depressed and see if the light goes out and that the fan is running.
If the fan has failed the part number is around $60.00 usually. There are AC and DC fans in this unit.
Your parts can be found here:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-79579773901/0583/0161000/F1104078/00002?blt=06&prst=0&shdMod=79579773901
Thanks for choosing FixYa,
Kelly
Jul 21, 2011 | Kenmore Side by Side Refrigerator
I have a Kenmore Elite Refrigerator, Model No. 795.77573600. The ice and water dispenser give the error message Er 1F. In searching online it appears that this problem is related to the ice compartment...
Aug 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Kenmore Elite 79577563600 is showing Er 1F. What does that mean? I cannot adjust temp or ice or anything.
Apr 07, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
181 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
gbob59
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
