SOURCE: cant connect to internet despite
Want to browse wap in your phone or want to connect with pc as a modem and use internet in pc?
SOURCE: SAMSUNG G600 USB CONNECTION PROBLEM
http://www.nodevice.com/driver/company/Samsung.html
this is a driver link installed it the driver and try to connect it and installed the software also from the cd
at firsst you installed the cd software after then you installed the driver
SOURCE: need a 8 digit unlock code for a samsung t459 t mobile cell phone
This is an unlocking website. Please visit the website to get a clear picture
http://www.mobileunlocksolutions.com/
SOURCE: I have C5212 Samsung Mobile Phone. I am connecting
there are times when the pc suite comes bundle with phone does not work;windows vista usually have this problem ;download the lastest version,here is the link
http://downloadcenter.samsung.com/content/SW/200902/20090227100255781/New_PC_STUDIO_1.0.0_IA1.exe
and check out
let me know if this is helpful
Testimonial: "Thanks. "
SOURCE: my mobile phone samsung c3010
i have samsung c3010s mobile phone i wanted to use it as modem for internet but xp not recognized my usb port .what i have to do plese told me .....................?
2. Connect Your Samsung with a working Internet connection ( via )USB Cable
3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet
2.2 How do you want to connect to the Internet: Set up my connection manually
2.3 Select Connect using a dial-up modem
2.4 Select Modem-Samsung Mobile Modem
2.5 Type an ISP name according to your preference (could be anything)
2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )
2.7 Leave Username, Password and Confirm Password fields blank
2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio.
