How do i replace the cable that go through the outer tube on a homelite weed eater?
The outer tube is the one that has the bend in it. it will help if you can send me pictures showing how to replace the cable.
Posted by Joe Russell on
  • JasonMLang
    JasonMLang Aug 25, 2019
    I essentially started about a month and a 1/2 agone and i have gotten a couple of test for a whole of $2,200...this is the bestcall I made amidst pretty some time! "grateful to you for giving Maine this incredible possibility to profit from home. This similarly cash has changed my existence in such an excellent measure of courses, to the point that, bypass on you!".......GOOD LUCK Click this Below connectHERE ?????? . www.green.jobs67.com
Andrew Taylor
    Top Expert:
  • Televison & ... Master
  • 34,047 Answers
5 Related Answers
trippssmengi
Mark Tripp
  • 76 Answers
SOURCE: Homelite
Go to www.homelite.com then in the red up top click on order parts then click launch to parts catalog then scroll down to accept agreement and then you will need to enter your model # and then you can go thru the list of breakdowns and get your part # from the diagrams.
Posted on Jan 05, 2009
steve_lima
steve
  • 181 Answers
SOURCE: weed eater wont start,put straight gas in it.
if you didn't mix any oil with the fuel,you probally burnt the piston and cylinder up.the only to find out if you did is to pull the muffler off and look inside the cylinder and see if there are any scoring on the piston.if there is you need to replace the piston and cylinder assembly.most cost $100.00 or more.usually they are not worth repairing.i know this is not good news but i hope this helped,let me know.................
Posted on Jun 02, 2009
#1 Taper
Jim Parker
  • 1041 Answers
SOURCE: my homelite weed eater sx-135 the fuel filter broke of the tube
The longest, and sometimes smaller in diameter, fuel line goes from the carb. to the bottom of the tank. It should rest comfortably on the bottom of the tank. The other line should go from the primer bulb to just inside the gas tank, (about an inch).
HINT: Cut the fuel lines at an angle before inserting them into the gas tank. This will allow you to get them in much easier.
If you need further assistance, just let me know.
Jim
Posted on Jun 08, 2009
Kerry Degrand
  • 112 Answers
SOURCE: gas weed eater pull cord wont retract after pulling cord
remove the cover and the screw holding the recoil down, turning the pulley ccw should release the spring then wind rope around pulley and (hopefully yours has the slot in it) wind in the direction of the pulley teeth then, holding rope in slot put back on spring and wind cw till almost tight, and install screw. Usually you can do this without taking rope handle off. sometimes you have to remove handle. look at spring end in the middle and make sure its not broke as long as you have it apart. Its a easy fix.
Thanks for using fixya
Posted on Jul 25, 2009
Anonymous
  • 56 Answers
SOURCE: I have never been able to start my homelite mighty
First thing is to remove and clean the spark plug...remove carbon deposits or gummy residue (a shot or two of carb cleaner should do it !!). Check the gap on your plug to see if it is somewhere between .025 to .030 (if you have your manual it should tell you the proper gap space...if not google www.homelite.com and they should be able to give you the answer). Next re-attach plug to plug wire and place the plug base touching the cylinder head...pull start handle and see if you get a blue spark...if not then you've got a faulty magneto or a bad plug...if you have spark,open the throttle and pour about a teaspoonful of FRESH fuel mixture into the throat of the carburetor. Hold throttle open and pull start handle a few times...the engine should start and run for a few seconds...if it does then the problem lies in the fuel system. Check fuel filter inside tank...check fuel cap vent to make sure it is not clogged...check fuel lines (may be gunked up or de-composed) squeeze primer bulb to be sure gas is reaching carburetor and to make sure it has no holes or tears. Put fresh fuel in tank, choke set to full, and try to start...may take a number of pulls of the start handle...if it starts, you're probably OK, you may just have to re-adjust your carb a little...if not the problem is probably a trashed up or gummy carburetor...(you will have to clean it or rebuild it). good luck !!! ;-D
Posted on Jul 06, 2010
Accelerator/Throttle stuck
most cable outer cases are made up of a spring section so if you bend it there are gaps that open to show the inner cable
CRC or wd-40 are quick fixes but will disperse with time and rain
However if you use lithium grease (CRC product)or spray silicon ans spray along that outer case as you flex it there is every possibility that the problem will be solved There is the possibility that if the machine has seen a lot of use in the accelerator so ot is possible that a groove has worn inside the outer case and that is causing the problem
IT that happens to be the case , get a new cable and before fitting it , if the inner cable can be pulled out , spray the lithium grease down the inside of the outer case and then put the inner cable back in it
Nov 25, 2015 | 2011 Honda Activa
I have 88 s10 i changed speedometer an still bounces after i put a new cable in it
Did you change only the inner cable ? if so the outer cable housing may be damaged causing the inner cable to bind up , letting go then causing the cable to whip and sending the pointer hah wire. If the cable is free and no sharp bends the fault is in the speedometer head.
Aug 19, 2014 | Chevrolet 1988 Chevrolet S10/s15/sonoma...
How to access/replace the vent selector(defroster) ?
buy one
and install it.
it has clamps remove them or unsnap them and .....
access? its in the dash.
the FSM covers all HVAC work , you can get that and read it
or hope that ALLDATA.com covers R&R for the cables.
but will cover access. (huge job on some cars)
working on the dash with out and FSM invites more broken parts.
plastics.
hidden screws and such , and how to get to them are covered in the book.
here is the control panel, pasted
Removal & Installation
  1. Remove the upper console panel.
  2. Remove the instrument cluster finish panel
  3. Release the 2 fitting claws and pull out the heater control assembly.
  4. Using a screwdriver, open the claw of the cable clamp and disconnect the defroster damper control cable. NOTE Be careful not to bend the cable wire. If the cable wire bends, the heater control assembly operationally becomes worse.
  5. Using a screwdriver, open the claw of the cable clamp and disconnect the air mix damper control cable.
  6. Disconnect the connector, remove the heater control assembly. 42050_coro_g0008.gif Removal and installation of the control panel
To install:
  1. Install the inner cable end of the air mix damper control cable to the heater control lever.
  2. Install the outer cable of the air mix damper control cable to the cable clamp. NOTE Be careful not to bend the cable wire. If the cable wire bends, the heater control assembly operationally becomes worse.
  3. Operating the heater control knob and check that it properly stops at both ends of MAX. COOL and MAX. HOT and no recoil is identified.
  4. Check that the outer cable should not be disengaged (moved) from the heater control assembly when the cable is pulled.
  5. Install the inner cable end of the defroster damper control cable to the heater control lever.
  6. Install the outer cable of the defroster damper control cable to the cable clamp.
  7. Operating the heater control knob and check that it properly stops at both ends of FACE and DEF and no recoil is identified.
  8. Check that the outer cable should not be disengaged (moved) from the heater control assembly when the cable is pulled.
  9. Connect the connector, install the heater control assembly.
  10. Install the instrument cluster finish panel
  11. Install the upper console panel.
Dec 13, 2013 | 2005 Toyota Corolla
89 toyota speedometer needle sporatic
If you have a cable driven unit and it makes a sound replace the inner cable ond check for sharp bends in the outer cable. REplace it also if you find any
Mar 17, 2013 | 1989 Toyota Pickup SR5
Hi there, and thanks in advance for any help you may give. I find my Peavey Delta Blues either EATS valves or the valves come loose, though I haven't moved it so that doesn't seem likely. I put new...
DO NOT run on less than the full set of valves!!! ALSO when replacing the valves with matched pairs used the matched pairs to replace either the inner two or the outer two. If they come loose, the sockets probably have pins that are loose. Sometimes they can be tightened a little using a sharp scribe to bend them gently inward. I would consider installing tube retainers. They are made as a wire springs. Go to this site:
http://www.tubesandmore.com/
Click on "Vacuum tube Accessories"
May 25, 2011 | Peavey Delta Blues 115 30w All Tube Combo...
New lcd screen no picture! sound and call functionality ok - but no illumination at all on inner or outer lcd
wrong place to post problem but ... solved issue. Flex cable was torn slightly through at bend on keyboard side of hinge causing break in the circuit trace. Replacing the flex cable should solve this, Next time I will do that first instead of replacing lcd !
Oct 23, 2009 | Motorola Mobility Razor Behind-the-Head...
Can sirius antennas be cut and spliced back together
If your antenna cable has been cut or severed, it can be repaired without the need for a replacement.
You will need the following things:
Small 600 degree soldering iron and solder.
Liquid flux for soldering the braid.
Small sizes of heat shrink tubing.
Small heat gun.
Small pliers, cutter, and Xacto knife.
1) The first step is to use the Xacto knife to cut both ends of the antenna cable so you have a clean end.
2) Using the Xacto knife roll the cable on a board and gently cut all around the cable to cut the outer insulation. Remove about 1/2 inch of the insulation from each end.
3) Push the braid back to expose the center wire and gently roll the cable and cut the center insulation to expose about 1/10 inch of the center wire. With your small long nose pliers, bend the center wire into a small hook shape.
4) Repeat all the above steps on the other end of the wire.
5) Put a 1 inch piece of heat shrink tubing on one end ( the black piece), and a 1/4 inch piece of heat shrink (the white piece) on the center conductor. Look at the picture to see this.
5) Hook the two ends together. Gently squeeze the hooks closed and solder them together. Be very careful when soldering this. Be quick so you do not apply to much heat and cause the heat shrink tubing to shrink on the side where you do not want it to be.
6) Slide the small white heat shrink to cover the cooled solder joint you just made and use the heat gun to shrink the tubing in place.
7) Now push the braids back together to cover over the connection you just made. Try make the braid smooth together by GENTLY rolling the cable between your fingers. Carefully solder the braid. A little liquid flux on the braid prior to soldering helps the solder flow and makes it look better.
8) Slide the final piece of heat shrink tubing over the braid and shrink it with the heat gun.
Jun 12, 2009 | Sirius Satellite Radio Receiver
My sirius car antenna cable got cut by the trunk closing on it. I tried connecting the two ends and the system can not get a signal. What can I do?
Small heat gun.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 07, 2009 | Sirius Satellite Radio Receiver
Arcing Picture tube
get a different tech from a different store to come out, needs to replace convergence ic's good luck
please mark the post with a fixya
Feb 16, 2008 | Toshiba 65HDX82 65" Rear Projection...
Color is not good around outer edges of picture
When the colors are off around the edges on a regular picture tube TV, it usually means that the degaussing thermistor's solder joints have cracked loose. Another possible cause is that a strong magnet, such as in a stereo speaker, was brought very close to the picture tube and has magnetized the tube. Resoldering the solder joints on the degaussing thermistor and demagnetizing the picture tube should put the color back to normal.
Aug 17, 2007 | Toshiba 32AF45 32" TV
Televison & Video Logo
387 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
