I understand how to do a department key for the sale of a gift card. How do I handle when a sale is made and a gift card is used to pay for the sale (redeeming a gift card)
SOURCE: Casio CE-T100 Cash Register
Hi.
You might have compulsory amount tend turned on.
If you press SUBTOTAL, then type in the amount on the display (no decimal point), then press ca/amt, does it work? If not, then you may have mucked up the cash button settings. Does it work if you use another payment type like CREDIT CARD?
SOURCE: Sharp electronic cash register XE-A203 - keeps printing receipt
I don't have this particular cash register, But I took a look at the manual and I recommend the following:
A. Turn the cash register off.
B. Unplug it.
C. Remove the batteries.
D. Wait at least five minutes.
E. Initialize the cash register. This procedure was copied from thwe manual:
In order to operate the cash register properly, you must initialize it before operating for the first time. Follow this
procedure.
1. Insert the manager (MA) key into the mode switch and turn it to the REG position.
2. Insert the plug of the AC power cord into the AC outlet. The buzzer will sound
three times.
IMPORTANT: This operation must be performed without batteries installed.
3. The cash register has now been initialized. The register display will show
"0.00" and then “NO BATTERY”.
If the buzzer does not sound when the plug is inserted, the initialization has not been done
successfully. (This will occur when the voltage is high because you operated the cash register
before starting initialization.) Wait at least one minute after pulling out the plug and insert the plug
again.
F. Download trhe manual from here:
http://www.ormsson.is/skjol//skrifstofutaeki/xe-a203,213,303_manual.pdf
And proceed to program your sales tax (or VAT), departments, clerks, etc.
Go to a website called:
www.retrevo.com
You can download manuals there.
also you can go to Casio.com and get a manual also
SOURCE: I can't add a name to a department key on a Casio TE-2200 cash registetr
Make sure you are using the text layout in the manual if the text is not inputting correctly. Also, don't forget to use the double zero button when changing between text input and placement to the keyboard.
If anyone needs a Casio TE-2200 or TE-2400 manual, C-tech collective have it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio5.php
