Sometimes a faulty carburetor causes the problem. I use Kroil spray in the spark plug hole AND in the carburetor intake and flood the parts with it. Pull the cord with the spark plug wire off a couple times and let sit twenty minutes. Hook up wire and pull sharply until it starts. Run and sporadically spray Kroil into the carburetor until it evens out. Kroil is found at kanolabs.com and I recommend the Kreen also...
The typical reason to lose oil into the filer box, is that the engine has been tipped up, this allows engine oil to travel down the breather tube and into the back of the box, the other reasons are, engine worn, or the engine breather itself is faulty.
SOURCE: Just bought a 10 hp troy bilt chipper used. When
As LeeatCSEb said, It's your float needle and seat not shutting off the flow of gas when your carb bowl is full. Have your needle and seat replaced. Dwain
SOURCE: Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
SOURCE: Troy Bilt Pressure Washer Model 01902 Leaking Gas from Air Filter
try banging lightly on carberator with block of wood or something to free up float and valve!!!!
SOURCE: reset oil chang warning light
The oil minder light will blink for 2 hrs and then reset itself, i believe it starts at 49 and ends at 51 and then every 50 hrs it will do the same.
SOURCE: oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
