Yes, disconnect the pistons and make sure the gears are in forward. You can lift (tilt) the lower unit up. I also suggest taking the pistons and tie them in an up position otherwise one or both pistons can extend. This is not a big problem, just you will need to cycle the pistons in to get them to align so you can reattach them.
SOURCE: mercruiser lower unite in nutural lock how to fix
Unhook the cable connection from the shift lever at the lower.Try to shift by hand with a cresent wrench,(small,and don't force).Sounds like you've a keeper dropped off in the lower.It's easy enough to pull the lower apart,but better have someone there that knows the unit or buy a repair manual for that lower.
Testimonial: "thanks for the input"
can u post pic of pump there are all diferent types but most are flat head screw take screw out fill with oil
Pacifica 2006-2008
Brake Calipers
Print I hope this helps,Good luck
Removal & Installation
NOTE
Using a brake pedal holding tool, depress the brake pedal past its first inch of travel and hold it in this position. This will isolate the master cylinder from the hydraulic brake system and will not allow brake fluid to drain out of the reservoir while the brake lines are open.
Fig. Brake hose banjo fitting (1), caliper guide pin bolt (2), caliper adapter (3), caliper (4), copper seal washers (5) and banjo bolt (6)
