Washing Machines Logo
Question about Electrolux Washing Machines
Why is it stuck on sensing mode when trying to begin a cycle?
Posted by Pat McCulligan on
5 Related Answers
Anonymous
SOURCE: Electrolux XL8KG Front Loader Washing Maching
I've found that a similar thing on my Zanussi appears when the filter on the output is clogged. Removing muck and hair from the filter usually solves the problem
Posted on Nov 20, 2008
Anonymous
  • 18 Answers
SOURCE: Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
Posted on Dec 27, 2008
Anonymous
SOURCE: Dryer stuck in sensing mode
hello
i have a hoover mega load condencer dryer HNC 375 T
after switching on the filter sensor light flashes
cleaned all filters but still the same
can anyone help
Posted on Jan 19, 2009
Anonymous
SOURCE: K-more elite dishwasher stuck in sensing mode; won't move to wash
Where did you find the sequence to clear the flashing clean light?
Posted on Apr 14, 2009
Anonymous
  • 52 Answers
SOURCE: quiet partner II is stuck in cancel/drain mode...
you need a new cycle selector ...or "timer "....
Posted on Jul 25, 2009
My Kenmore top loading clothes washer stays on sensing and goes no further.
When Kenmore HE Washer is stuck on Sensing Cycle and not proceed to the Wash cycle, most likely one of these 3 parts malfunction: Failed Water Inlet Valve or Inlet Valve Tap is in OFF position. Shift Actuator not able to change position, before Wash cycle. Control Board malfunctioned.
3 Top Reasons Why Kenmore HE Washer Is Stuck On Sensing
Videos as well, it is a known issue
https://www.google.com/search?q=Kenmore+top+loading+clothes+washer+stays+on+sensing
Dishwasher continues to wash.
the timer motor run contacts are stuck together
1helpful
Duet dryer on sensing mode>what does that mean
The "Sensing Mode" occurs when the dryer is trying to detecting the dampness of the clothes in the dryer to determine if they are dry or not.
If the dryer is "stuck" in sensing mode - there is a problem that should be checked.
Dishwasher turns on, begins to sense, proceeds but no water
replace inlet valve after you check and make sure nothind is under basket example fork hung under float
GE Profile WPGT9150 will not start cycle
You have a bad transmition.
Please rate this solution
1helpful
Water continues to fill machine but the wash cycle never begins
The pressure switch is stuck and not sensing the correct amount of water
Top Electrolux Washing Machines Experts
David Shaub
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
