SOURCE: The battery is fully charged
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
SOURCE: Midland LXT320/420 WALKIE-TALKIE . My battery
My dear,
Do you want to replace your battery ? If so, please specify
SOURCE: Motorola Walkie-Talkie will not turn on.
The same thing happened to me, all you have to do is put it on charge for 20 mins, then take it out, keep on pressing the on button, leave again for 5 mins and then click the on button and it should turn on. It just needs a boot or a jumpstart if you have not used it for a long time like me :) Hope this helps
