Question about RCA Audio Players & Recorders
My RCA f2f600 has an overload problem when power up
Posted by Imran Baksh on
Rca receiver overload message
Power the unit off , Disconnect all the speakers ,power the unit back on and check to see if you get the same message, if so one or all of your speakers could be bad. This message appears when there is too much load on the output IC's,generally causes shutdown. Also try blowing the system out with canned air, And removing anything that prevents the unit from getting enough ventilation.
Feb 21, 2014 | RCA Stav-3870 Audio Video Stereo Receiver
I have a 27" RCA
a defective or overloaded power supply or horizontal output stage could create this type of problem
Jul 17, 2011 | Proton MM2701VT 27" TV
Hooked the damn thing up power my subs wonderfully for that evening, and all day today, got in this evening and nothing, checked the amp and red light, ok, fine, checked the manual, says the light protects...
probably something corssed in your speaker wiring. be sure that you did not exceed the ohmage capabilities of the amp, and that no speaker wires are crossed, or shorting out on the frame. if you have too many speakers hooked up, that can reduce the ohmage, and your not supposed to go below 2 ohms -per channel, or 4 ohms bridged mono.
Mar 13, 2011 | Pyle PLA2200 Car Audio Amplifier
Receiver Overload error message
Disconnect all speaker wires at the receiver, then turn it on and up. If it stays on, check your speaker wires one by one, then check your speakers one by one. If it still cuts out with nothing attatched, it needs serviced or replaced.
Aug 30, 2009 | RCA RT2660R Receiver
RCA Big Screen - Power turns on but then it powers off intermittently
The power supply section is having trouble.
Common possibilities are:
- Convergences amps are failing, overloading the supply
- High-voltage section (flyback transformer) is failing
(happens sooner or later, about 8 years typical))
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Feb 19, 2008 | RCA P52937 52" Rear Projection Television
Rca stereo
Sorry insufficient detail for an accurate response.....
Please post more detail...
Cheers YUBEUT
Feb 10, 2008 | Audio Players & Recorders
Rca rt2360
Possible short in output amplifier darlington transistors. Check cable connections first, but if that doesn't help, it is likely a amplifier problem
Nov 07, 2007 | RCA RT2360 System
POWER ON PROBLEM
Well, I know that u will overload it if u use any 4 ohm speakers on it. And a LOT of center channel speakers are 4 ohms. Also, it has problem working with 5.1 (optical or coaxial). If that is the case, try to run it on stereo...
Oct 11, 2005 | RCA RS2604 CD Shelf System
62 people viewed this question
Top RCA Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
