Question about Garden
Where can I find a baumr-ag sx45 0.325 chainsaw cog
Posted by Bernie vandermey on
5 Related Answers
drallim
  • 4088 Answers
SOURCE: i have a Baumr-ag sx62 chainsaw I put a new chain
Loosen the chain tension adjustment screw a few turns so that the tang from the adjuster will drop into the large hole at the rear of the bar. You may need to jiggle the bar in and out a little to engage the tang. Once you do, the cover should drop into place securely. With the attachment nut(s) slightly loose, adjust the chain so that it doesn't droop from the lower side of the bar, yet still turns fairly freely by hand. Tighten the fasteners on the side plate and recheck the chain tension. Hope this helps!
Posted on Feb 27, 2010
Testimonial: " thankyou for the advice, i had already discovered that i had the chain lock on, but it's re-assuring that i had reassembled it correctly. Thank you"
dan quinlan
  • 9 Answers
SOURCE: my Baumr Ag sx62 leaks bar oil.
The white plastic thing you talk about is spare impeler for the chain oil pump, but you should find it is a different thread which will slow down the oil flow, well it did for me. i have owned one of these saws for three years now and it still goes like a freight train. before you put them to use you must make sure the carby is set right. because if its running to lean or not enough oil in the fuel, Yes it will seize every time. All you have to have is a little bit of an understanding in small engine mechanics. Yes they do leak a little oil, just fill it when you want to use it. a chainsaw should use one tank of fuel to one tank of oil, no more than two tanks of fuel to one tank of oil.
Posted on Aug 24, 2010
Brian Manuel
  • 354 Answers
SOURCE: Hi, just bought a baumr
I would say online
Posted on Feb 15, 2011
John Mewburn
SOURCE: where can i get parts [coil] for a BAUMR SX 72 CHAINSAW REGARDS R
Should you wish to purchase the part, simply make a purchase by logging in to our website www.agrmachinery.com.au (www dot agrmachinery dot com dot au) to get it dispatched asap.
- Click on the *Parts Finder* drop down menu box on the upper right area on the page.
- Select your item from the list displayed
- Select your model if prompted
- Examine the Exploded Parts Diagram to identify which part number you need
- Match the part number up with the list below to find the product code for the part you need
Posted on May 02, 2012
Bill Boyd
  • 53781 Answers
SOURCE: I need an engine rebuild kit for a SX66 Baumr ag chainsaw is there such a kit? Corrie
if you can't find one , be aware that the piston and ring will be generic fit for that cc engine so go to a mower shop with the bits and see if you can get alternate parts
for example I have homelite piston and ring in a husqvarna trimmer for the last 5 years and still starts and runs ok
as long as the bore size is the same and the wrist pin fits in the piston
Posted on Jul 11, 2016
Spring fell out of my baumrag 750 sxi and no longer self propelled just need to now where spring goes
Contact them direct and ask them for a schematic. It is a too obscure Australian company with nothing helpful online.
Baumr-AG is a brand name Mills created in 2008 to sell tools online. It works. Mills's company, which started in 2006, pulled in $26 million last year. "With chainsaws, people think Germany.
http://www.baumr-ag.com.au/about-us
Jul 23, 2018 | Garden
Hello. I just bought a Baumer AG SX75 Chainsaw and have just taken it out of box. Believe a plastic piece is locking brake. Advise
read the user manual first as it will show any parts used for transport that have to be removed The user manual shows that the chainsaw comes supplied with plastic spacers (BB) underneath the chain drive cover and over or around the chain drive cover studs (CC)
Those spacers are for shipping purposes only and must be discarded before mounting the chain bar
The manual that I got that from can be downloaded as a baumr AG chainsaw manual pdf from www.datastreamserver.com>bau
The last baumr product( impact drill) that I purchased included the user manual in the box
Apr 05, 2018 | Garden
I have a baumr ag pro. i need a cylinder base gasket. where do i get one from baumr sx72.thanks,steve..
Try www.chainsawspairs.com.au it looks to me there are not any UK suppliers. Good luck.
Jun 09, 2016 | Garden
Oil Pump & Worm gear drive for Baumr-ag SX 72 72cc Chainsaw
Cant find much on your machine as its an obscure make and model. This brings with it the ease of sourcing parts, sometimes its better to stick with known brands for this reason.
I managed to find this, it might be worth comparing it to the one on your machine. Hope it helps.
http://www.chainsawspares.com.au/oil-pump-and-worm-drive-for-baumr-ag-sx25-25cc-cha
Mar 30, 2016 | Garden
I need a service centre for my Baumr SX 72 chainsaw in the Geelong?
Try reading
http://www.productreview.com.au/r/baumr-ag-62cc-professional/549822.html
Where I have a bit of a problem is that this question about a chainsaw is headed 'Problem with Video Cameras'. Maybe Fixya's fault.
May 29, 2014 | Video Cameras
My baumr ag sx 82 chainsaw cuts out like its choking and does not rev that well
check the spark arrestor screen in the muffler. if its plugged up then the saw can't exhaust and will bog down
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Sep 22, 2013 | Garden
Need spare part for baumr-ag professional pole pruner saw
Need a new pull starter mechanism/kit for Baumr - AG PNHT 4500 Professional Pole Pruner Saw
Feb 05, 2013 | Garden
Where do i find pull start parts for the baumr-ag 62
Email [email protected] This is the main seller of Baumer-AG machinery on ebay .. I know that he has a fair assortment of parts as I had to change my startr when it fell to bits.
Regards, Bob.
Aug 09, 2010 | Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
