Question about The Computers & Internet
How do you replace The drive cable? - The Computers & Internet
Posted by Annette on
  • Patrik Parker Jul 27, 2019
    Hi Annette , I want to help you with your question, but I need more information from you. Please Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7
Best way to replace speedometer cable
most cable drives for speedos are replaced by removing the cable from the drive end ( not the instrument end) and pulling the inner cable out
if the inner cable is damaged , check for kinks and squashed sections of the outer cable case as these will affect the new inner cable
Nov 21, 2015 | 1987 Honda GL 1200 Interstate Gold Wing
Replace hard drive motherboard
Before you start replacing drive you need to ask yourself if you are trying to replace a bad hard drive and just want to start with a clean install of the O.S. OR are you replacing your hard drive with a bigger one and wish to keep your installed programs, data and documents. If you want to keep your data and documents you need to know how to save the Files and folders on your computer to a CD, DVD or a USB hard drive. Just replacing the hardware involves unplugging all cables from computer after shutting it down. Then opening the case and unplugging the cables from the hard drive and then remove the screw(s) retaining the hard drive. Remove the old hard drive from the case and replace it with the new one, replace screws and plug cables back up watching that that the connectors are correctly aligned with the key(s) on the hard drive's sockets. Replacing the Hard drive also involves installing the O.S. and all your programs and applications on the new hard drive. You can find a lot of information in the internet about this.
Oct 21, 2013 | Gateway SX2855 Case
My external hdd has is not detecting
Seagate is a company that manufactures external hard drives.
These hard drives can be used to house large files or even to backup an entire hard drive.
When your Seagate external hard drive is not working properly, you might ready to send it into the company for repair.
Before you send it away, you can troubleshoot the problem and potentially save yourself a lot of time and grief.
Look over the power cable going from the wall outlet to the back of the Seagate hard drive. Make sure that there aren't any breaks or tears in the electrical wiring.
If there are breaks, replace the power cord.
Look over the power cable and make sure that it is plugged into the wall outlet in your home as well as plugged into the back of the hard drive.
Plug the power cable directly into the wall outlet or into a surge protector.
Do not plug the power cable into an extension cord.
Seagate Data Cable
Disconnect all of the USB devices that are plugged into your computer's USB ports except for your mouse and your keyboard.
Disconnect the Seagate external hard drive from your computer.
Unplug the power cable from the back of the Seagate external hard drive and restart your computer.
Wait until your computer has fully booted and then plug the power cable back into the hard drive.
Look over the USB data cable to make sure that there are breaks or tears in the cable.
Look over the ends of the cable where they meet the computer and the hard drive.
Make sure the pins are straight.
Replace the cable if needed.
Plug the data cable into the back of the hard drive.
Plug the data cable into your computer.
Hope this helps.
Nov 23, 2012 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Replace dvd drive how to
Hi Kim,
Considering your PC is IDE powered,make sure also your replacement is an IDE powered DVD drive.
  • Open the cover pressing on the sides and sliding it backwards.
  • Locate the DVD drive.
  • Disconnect the power and the IDE Interface cables[wide greyish 40 pin cable] from the drive.
  • Disconnect the Sound card cable which is the smallest of the cables.
  • Pull the drive backwards and upwards to remove it.
  • Now fit the replacement.
  • Connect the drive's power, IDE Interface and the Sound card cables back.
  • Cover it back and turn it on.
Hope this helps.Thanks!
Please rate this answer.
Nov 04, 2011 | IBM Lenovo ThinkCentre® M52 PC Desktop
I am replacing the hard drive in my gateway 5220
Just buy a IDE cable longer than the one you have got
Jan 10, 2010 | Gateway GT5220 PC Desktop
395 Service Engine Error
Hello kieran,
This might help you. I found this on one printer forum.
From the manual:
Fuser Drive and Contact Cam System Service Check
Error Code 993: Indicates the cam sensor has not been activated.
The sensor activates when the fuser drive motor turns the cam disk.
If the fuser drive motor does not turn on, or the drive parts are not
operating, go to A.
If the fuser drive motor turns and appears to be operating properly,
and the cam is turning, go to B.
and the cam is not turning, go to C.
A The fuser drive system is not operating properly.
FRU Action
1 Fuser Assembly
Fuser Drive Motor
Fuser Motor/Paper
Feed Motor Carriage
Unit Motor Cable
Engine Board
Check the fuser assembly internal drive gears
for binding, or broken or worn teeth. If a
problem exists, repair or replace the fuser
assembly.
Remove the fuser drive motor from the stay
assembly, leaving the motor cable connected
to the motor. Turn the printer on, but do not
allow the motor to touch other areas of the
printer. Verify the motor turns during POR. If it
does, the problem is most likely in the motor
mounting stay assembly. Go to step 2.
Check the motor for shorts between the case
and each motor winding. If a short is found,
replace the motor.
Note: Damage to the engine board may result
from a shorted motor.
Check the motor for open windings. If found,
replace the motor.
Check continuity of the fuser motor/paper feed
motor/carriage unit motor cable.
• If incorrect, replace the cable.
• If correct, replace the engine board.
2 Motor Mounting Stay
Assembly
(Fuser Drive Parts)
Check the fuser drive gears, gears C3-1, C3-
2, the clutch spring, motor drive gear, gear C2
and C4 for signs of chipped gear teeth, worn
parts, or improper operation. If problems are
found, repair as necessary.
Check the cam gears and solenoid for proper
operation and signs of broken or worn gear
teeth or damaged parts. If found, repair or
replace the motor mounting stay assembly.
B The fuser drive system is operating properly and the cam disk is
turning.
FRU Action
1 Cam Sensor (PH16)
Engine Board (M4)
SN Cable
Be sure the cam sensor is mounted correctly
and locked into place.
Check the following voltages on the cam
sensor:
Pin # Signal Voltage Voltage
Voltage Disc in Disc Out
1 (Orange) +5 V dc +5 V dc +5 V dc
2 (Brown) -CCSENS +5 V dc 0 V dc
3 (Green) GND 0 V dc 0 V dc
Note: The voltage on pin 2 should vary, as the
cam turns from approximately 0 V to +5 V dc.
• If the voltage on Pin 1 is incorrect, check
the cable. If incorrect, replace the cable.
• If the cable is good, replace the following
FRU's in the order shown:
1.Cam sensor
2.Engine board
3.SN cable
C The fuser drive system is operating properly and the cam disk is
not turning.
FRU Action
1 ContactCam
Solenoid
CRF Cable
Engine Board
Check the solenoid for proper operation,
making sure it picks during POR cycle.
Disconnect the solenoid and check the
resistance on the solenoid cable. It should
measure approximately 65 ohms. If incorrect,
replace the solenoid.
Check the voltages on the solenoid cable
connector.
Check the following voltages on the contact
cam solenoid cable connector:
Voltage Static Picked
1 (Red) +24 V dc +24 V dc +24 V dc
2 (Black) -SL2ON +24 V dc 0 V - +24 V dc
Note: All voltages are approximate.
continuity of the CRF cable to the cam
solenoid.
Assembly
Check the clutch spring, clutch boss, clutch
disk and gear C4 for signs of wear, broken
teeth or binds. Repair or replace the motor
mounting stay assembly if a problem is found.
Normaly the fuser is not turning - check the cleaner pad is not jammed in too tight. Then replace the fuser drive block 12G1348.
Jul 29, 2009 | Lexmark C510 Laser Printer
Error message 993, what is this?
that is a fuser drive error on printers. it is the part that fixes the ink to the paper.
i have a check for you but is not an easy fix.
if fuser drive is gone will cost approx £12 to replace.
operating, go to A.
FRU Action
1 Fuser Assembly
Fuser Drive Motor
Fuser Motor/Paper
Feed Motor Carriage
Unit Motor Cable
Engine Board
assembly.
replace the motor.
replace the motor.
Assembly
(Fuser Drive Parts)
turning.
FRU Action
1 Cam Sensor (PH16)
Engine Board (M4)
SN Cable
sensor:
1.Cam sensor
2.Engine board
3.SN cable
not turning.
FRU Action
1 ContactCam
Solenoid
CRF Cable
Engine Board
connector.
solenoid.
Assembly
Feb 25, 2009 | Ricoh Aficio GX3050N Printer
Gx3050n error code 993 what is this?
operating, go to A.
FRU Action
1 Fuser Assembly
Fuser Drive Motor
Fuser Motor/Paper
Feed Motor Carriage
Unit Motor Cable
Engine Board
assembly.
replace the motor.
replace the motor.
Assembly
(Fuser Drive Parts)
turning.
FRU Action
1 Cam Sensor (PH16)
Engine Board (M4)
SN Cable
sensor:
1.Cam sensor
2.Engine board
3.SN cable
not turning.
FRU Action
1 ContactCam
Solenoid
CRF Cable
Engine Board
connector.
solenoid.
Assembly
Feb 25, 2009 | Ricoh Aficio CL1000N Printer
Replace speedometer calbe
Replace the Speedometer Cable
1 - Remove the old speedometer cable from your car, first take off the doghouse and then the engine cover.
2 - Remove the screw underneath the dashboard and take down the steering column. This will give you access to the back of your speedometer.
3 - Take off the drive shaft bolt, and "O" ring, insert the speedometer cable through the firewall.
4 - Remove speedometer cable securing clamps from the engine compartment and on the transmission.
5 - Release the drive shaft nut from the "right angle" adapter (The nut is attached to the back of the transfer case).
Installing the Speedometer Cable
1 - Place the square end of the speedometer cable into the adapter and secure the drive shaft nut.
2 - Pull the speedometer cable through the firewall to the rear of the speedometer.
3 - Secure the "O" ring and attach the speedometer cable to the rear of the speedometer/odometer. It should be engaged in the speedometer's square hold. Tighten the drive shaft nut again.
4 - Replace the clamps that will secure the speedometer cable onto the transmission and in the engine compartment. Replace the engine cover.
5 - Drive your car slowly to be sure your speedometer is working properly. If it is, replace the doghouse. If you're stilling having problems, take the car to your mechanic.
Parts & tools -
Speedometer cable
Wrench
Screwdrivers
Good Luck.
Jul 01, 2008 | 2001 Honda Accord
Computers & Internet Logo
21 people viewed this question
Top The Computers & Internet Experts
Mike 'H'
Mike 'H'
Level 1 Expert
myxelpyxel
Dakshinamurthy...
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
