Question about Polaroid Televison & Video
What size ccfl bulbs do i need for my Polaroid TLA 01511C TV?
Posted by Valerie Blake on
5 Related Answers
Anonymous
SOURCE: DirecTV Remote Control of Polaroid TLA-01511C
These worked for me
Polaroid 10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341, 11498, 11523, 11991, 11992
Posted on Dec 10, 2007
Anonymous
  • 19 Answers
SOURCE: manual for TLA-01511C
olsonde,
Here is your product info. Please let me know if I can help you in any other way! If not, I would appreciate you rating this as "FixYa".
http://www.polaroid.com/CES/SupportProductDetail.jsp?prod_code=PT261&folder_id=0
-DRebel
Posted on Apr 03, 2009
Anonymous
SOURCE: polaroid TLA-01511C
Tried to use my TV as a computer monitor. When tries to boot up, will go to "No Signal". All hooked up correct. Is ther something I need to do tobe able to use the monitor with my computer. I have a Dell Desk Top Computer.
Posted on Jul 18, 2009
Anonymous
SOURCE: I have 3 Polaroid TLA-01511C 15 in. LCD Televisions
I replaced three capacitors on my power supply board and the unit started working again, There was two 680uf 10v caps and one 1500uf 10v cap bad.
Posted on Nov 29, 2009
Chi Chu
  • 8457 Answers
SOURCE: My Polaroid TLA-01511C has sound but no
Replaced the LCD inverter backlight board is dead.After U replaced this LCD inverter board.U will get ur picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board.It a long board shape.
Posted on Feb 21, 2010
Sound no picture Polaroid 15.4 TLA-01511c
If you take a good look at the screen when it goes dark can you make out anything maybe some bright scenes on the channel you were watching or if you press the menu key, you can see a very dim display, you might need the back light assembly or something related to it.
Jan 09, 2010 | Televison & Video
Problems with Polaroid TLA-01511C 15 in. LCD Television
It needs a video board replaced most likely. You can find by searching on google for your model. Might cost more than set is worth. Think about new model as they are really cheap in that small size.
Feb 04, 2018 | Polaroid TLA-01511C 15 in. LCD Television
Manual for TLA-01511C
olsonde,
-DRebel
Apr 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Polaroid TLA-04641C no sound
You should go into the menu SOUND section of your tv. Look for the TV Speaker choice option.
This will have to be turned on to get sound from the tv.
Feb 23, 2009 | Polaroid TLA-01511C 15 in. LCD Television
How do i find the AUX on the Polaroid TLA-01511C? I want to run a DVD player and it needs to be set up on the AUX. If I run a scan on the channels it does not pick up the AUX
I would recommend using the S-video connection for the DVD to the TLA-01511C TV's S-video. Then, press the input button and go down to the S-video option and you should be good to go - it worked for me. Hope this helps you!
Dec 21, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Polaroid TLA-04011C
Check the powersupply/inverter board for bad capacitors. Also check the CCFL bulbs in the top and bottom for poor solder connection - replace if necessary.
Nov 08, 2008 | Polaroid TLA-01911C TV
Will Not Find A Signal Polaroid HD 15" TV - Model TLA-01511C
same (tla-01911c) issue when trying to watch over the air brodcast try rescanning the channels that normally works for me
i got direct tv basic set on my S-video input so i only need over the air when the sat is down (i.e: storms, wind, snow, ...)
May 15, 2008 | Polaroid TLA-01911C TV
Televison & Video Logo
Top Polaroid Televison & Video Experts
Paul Bade
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
