Tablets & eReaders Logo
Question about Tablets & eReaders
How do i install ios.10 on a ipad 2?
I looked for the software update,but it says ios.9.5.3 is up to date but i want to install ios.10 so how do i do that?
Posted by Lexie on
  • Patrik Parker Jul 26, 2019
    Hi Lexie , I want to help you with your question, but I need more information from you. CPlease Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7
5 Related Answers
Jim Thomson
  • 1099 Answers
SOURCE: how to install ios5 on ipad2
Plug it into your computer and open up itunes under devices click on your ipad and then click on check for update.
Posted on Jan 31, 2012
peggyw1
  • 6 Answers
SOURCE: how can i get my ipad 2 out of recovery mode
I assume you did reboot. After that I would try to update again.
:) Hope this works for you.
Posted on Oct 01, 2014
Abby Carter
  • 268 Answers
SOURCE: Just upgraded iPad 3 to iOS 8.1.1. Now everything freezes up. iPad won't even turn off at all. Is there anyway to reverse an update?
Sorry for the update problem. I am glad to tell you that I found an article that collects the common iOS 8 update problems. Hope it works. The Most Common iOS 8 Problems and Solutions iMobie Guide
Posted on Nov 25, 2014
SOURCE: Can I update my iPad 1 IOS past 5.1.1
I am afraid that you have to take Chrises advice and upgrade if you are going to use the iPad for newer things.
enjoy your coffee,
kolbrun
Posted on Feb 02, 2015
RudeRude
  • 526 Answers
SOURCE: Hi Jim Hicks. How do I delete a Profile on Facebok More. profile name. On my iPad 2. Software iOS 9.3.5
get away from apple and go for android and get off f/b or they'll use all your info....glad l could help....
Posted on Apr 03, 2018
I need to upgrade my IPad and IPhone to IOS 10
The easiest way for most people to update iOS 10 to iPhone is over the air, directly on their device. It's fast, efficient and simple to do.
1.Click Settings, then tap on General
2.Tap on Software Update.
3.Tap on Download and Install.
4.Enter your Passcode, if prompted.
5.Tap Agree to the Terms and Conditions. Tap Agree again to confirm.
6.Tap Install Now to begin the update.
http://www.leawo.org/tutorial/how-to-update-ios-9-2-to-iphone.html
2helpful
2answers
How to upgrade my iPad
If you mean update your iPad to iOS 10, there are two ways for you: update over the air or with iTunes. Here is a detailed post:
How to Install iOS 10 on iPhone iPad
3answers
My Apple iPad 2 won't update. It's running iOS 9.
It may be too full. Check how much free space you have. Try to have approximately 3GB free. Delete things that are easy to replace like apps, or music you can download again.
3helpful
2answers
Is it possible to upgrade my iPad to iOS 7.0 ?
Yes!
Most people are now on iOS 8.4
So.... do you mean back grade? from 8 to 7
iOS 9 will be released in a few days!
https://www.apple.com/ios/
It can be downloaded & installed directly to your iPhone/iPad
Or... as I prefer.....
use my computer running iTunes to firstly Backup the iDevice (using it's USB charge cable)
ITUNES will at this time indicate that there is an update available for your iPad.
Choose to "download only" the new iOS.
If you have other things to do!
Disconnect while the download takes it's time downloading.
Then come back later and plug in USB cable and "Install" the updated iOS.
How to Update iOS Software on an iPad
How can I up date my IPad?
Depends, When you have an iPad first generation, you can't update to iOS 6. All other iPads can upgrade to iOS 8.0.
In the few years your iPad is around, the processors are much faster. There is more internal memory and so on. Please to avoid you can't upgrade your next iPad, don't buy a second or third generation.
If you have a newer iPad than the first generation, just goto settings, general, an then the second line from the top says software update. Press that one. Your iPad will look if any update is available, and suggest to download and install it.
But the best way to upgrade, is connecting the iPad to iTunes and click on the name of the iPad on the left side in the menu, then click on upgrade.
How to update ios on ipad 2
Yes, you can. The easiest way is to update the iOS system in the Settings app. Also you can resort to iTunes to do that. Follow the instruction below.
If you can't update iPhone iOS software wirelessly throug WiFi connection, you could give iTunes a try. As the all-inclusive iOS device manager center, iTunes provides multiple effective assistances for you, including: backing up iOS devices, restoring iOS devices, transferring iOS data files, and updating iOS devices. You could follow the below steps to learn how to update iPhone software with iTunes in detail:
  1. Install the latest version of iTunes on your computer.
  2. Connect your iPhone to your computer via the USB cable.
  3. Open iTunes and select your device.
  4. Click "Summary > Check for Update".
  5. Once iTunes detects the available update, click "Download and Update".
  6. If asked, enter your passcode. Then iTunes would start to update iPhone iOS software. When it's finished, disconnect your iPhone with computer.
For more methods, check: How to Update iPhone
Please post the solution. Why is there no "software update" on my IPad 2?
There are two ways to upgrade the iOS version of your iPad
- via connecting the device to iTunes on a computer
- or directly from within the device, but only since iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update)
just go to: settings - general - software update
- so in your case try an update with a computer with iTunes installed:
- procedure with iTunes connected:
  • Connect your iOS device to your computer using an USB cable. Wait for iTunes to open and connect to your device.
  • Click on device button to the left of the iTunes Store button in the top right corner in iTunes.
  • Hold down on the option key (Mac) or the shift key (Windows) and click the "Check for Update" button in the Summary pane. Browse to the .ipsw file you downloaded and select it.
  • Do not disconnect your device until the update has finished.
  • If necessary, restore your device from the previous backup and sync with iTunes.
Install iOS 7 0 4 update on iPhone or iPad Tutorial please-post-solution-no-software-qrl052hdp2kg0kvuqxssgusw-5-0.jpg please-post-solution-no-software-qrl052hdp2kg0kvuqxssgusw-5-2.jpg please-post-solution-no-software-qrl052hdp2kg0kvuqxssgusw-5-5.jpg
Top Tablets & eReaders Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
