Question about Samsung Audio Players & Recorders
Samsung tv hook up where for exteral speakers model UN32J4000AF
Posted by bill vanyken on
Franco Dosil
    Top Expert:
  • Samsung Master
  • 10,535 Answers
Hi Bill, your Samsung TV, has digital audio output by fiber optic, to be able to connect powered speakers, they must have that type of input
You can connect this output to an amplifier with Digital Fiber Optic input and thus have the audio in the amplifier speakers
Another option is to use a converter of Digital Audio input (Optical Fiber or Coax) and Audio output by RCA
I send you the link of the D / A converter
I hope you can listen to your TV by external speakers
Greetings Franco Dosil
Hola Bill, tu TV Samsung, tiene salida de audio digital por Fibra ?ptica, para poder conectar parlantes potenciados, estos deber?n contar con ese tipo de entrada
Puedes conectar esta salida a un amplificador con entrada Digital de Fibra ?ptica y as? tener el audio en los parlantes del amplificador
Otra opci?n es utilizar un conversor de entrada de Audio Digital(Fibra ?ptica o Coaxil) y salida de Audio por RCA
Te envi? el link del conversor D/A
Espero puedas escuchar tu TV por los parlantes externos
Saludos Franco Dosil
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_MX&CttFileID=6033976&CDCttType=UM&ModelType=N&ModelName=UN32J4000AF&VPath=UM/201510/20151030153502738/J4000-ZX-BF_BN68-07180Y-00ENG-0728.pdf&OriginYN=N
https://www.ad-net.com.tw/product/2-port-rca-audio-1-stereo-fiber-optical-converter
Posted on Aug 12, 2019
My remote has stopped working
Try some new batteries - they do wear out.
Aug 03, 2017 | Televison & Video
Cant get any sound from the speakers new samsung 4k tv with optical chord hooked up
The Samsung does not have an optical audio IN to the TV. It only has an optical audio OUT. Meaning the audio would leave the TV to a receiver or sound bar instead of the TV speakers. Optical audio is for surround sound systems. I hope this helps.
Apr 05, 2016 | Samsung Televison & Video
Hook mz506 surround sound to my Samsung tv
Typically surround sound is run through a receiver or stereo. The sound from the tv is carried to the receiver by cables (hdmi or Audio-Video connected to input area of receiver). Then the speakers are connected to the output area of the receiver.
If you are not using a receiver, then the speakers must be able to connect directly to the tv and you have to see what kind of cabling your tv supports.
Jan 27, 2015 | Logitech X-540 Multimedia Surround Sound...
Can JBL Creature 2 speakers work on a Samsung smart tv
Do you happen to have the model of the TV? My Samsung only has two digital optical outputs. If your'e plugging in JBLs, you may only have an analogue input which won't work.
Mar 16, 2014 | JBL CREATURE II Computer Speakers
No sound from my tv speakers. mute is off and exteral speakers are off. There is only TV and cable box on. I can see the volume going up and down, but there is no sound 52 bravia w series
  1. hook up your cable box to another TV check it.
  2. reset the TV by press and hold the [^] on the remote and press [power] on the TV.
  3. Do software update.
  4. replaced the main board,
Apr 26, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a Sony DVD-SLV-271P to hook up to a Samsung TV. I have five wires coming out of the DVD player and need help
yellow is video, red is speaker, white is speaker, you should only have to hook up the three to the back of TV.
Apr 07, 2010 | Audio Players & Recorders
Trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Aug 25, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
HOW DO I HOOK IT UP TO MY NEW RCA FLATSCREEN TV?
how do you hook up x-530 speakers to a samsung tv
Jun 01, 2008 | Logitech X-530 Computer Speakers
Hooking up TV Guardian with Samsung HT-SK5
Just purchased system, didn't come with any speakers, but when hooked up to tv get picture and no sound unless I put headphones in.
Jan 07, 2008 | Samsung HT-SK5 System
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
