Question about Home
Cad drawing dwg for dual flush toilet - Home
Posted by Ronald Lippert on
5 Related Answers
Anonymous
  • 265 Answers
SOURCE: Convert CAD (DWG) to Visio Drawings
You can import graphics files of different formats to start a new Visio drawing by using the Open command on the File menu.
The following graphics file formats are supported:
  • AutoCAD Drawing File Format (.dwg, .dxf)
  • Compressed Enhanced Metafile (.emz)
  • Enhanced Metafile (.emf)
  • Graphics Interchange Format (.gif)
  • JPEG File Interchange Format (.jpg)
  • Portable Network Graphics (.png)
  • Scalable Vector Graphics Drawing (.svg, .svgz)
  • Tag Image File Format (.tif, .tiff)
  • Windows Bitmap (.bmp, .dib)
  • Windows Metafile (.wmf)
Note File formats may vary slightly between language versions. You may not get exactly the same results if you import files created in different language versions.
  1. On the File menu, click Open.
  2. In the Files of type box, click the file format of the file you want to import.
If you don't see the file format listed, Visio doesn't have a file filter for that format. Try saving the document in a format Visio can open.
Posted on Dec 29, 2007
dmftrucker
daniel hendrickson
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
Colin Hagey
  • 11 Answers
SOURCE: Pegusas toilet.
I have the same problem .... I took it apart and found that there is not any screws, nuts bolts, washers .... what it is (was) is a piece of lead (like a sinker on the end of a fishing line) attached to the end of the cable, yes the cable, that hooks into the handle and into the top of the flush mechanism - that yellow plastic tube )the cable goes through it) I was able to take it apart and repair the end of the lead weight with a split shot sinker BB - is the size I used. I also had to deform and cut some of the sinker away since the hole it sits in, is small. When I went to Home Depot to buy/get a repolacement unit, one store told me to call the manufaturer -- Foremost and gave me the number, I lost that piece of paper now that I have time to call again, I was left on hold for 10 minutes the first time. 1-888-256-7551 http://www.foremostcanada.com/warranty.php
I just called and pressed a few buttons, waited 2 minutes, got a live person, she asked me what was wrong, I told her that my handle was just spinning, she asked for my model number 131-926 (found on the inside back of the toilet) when I purchased it (make this up, within this year ... and yes you have the receipt - she never asked for it, just that I had one!) she took my address down and gave me a client number .... tada!
Posted on Dec 16, 2009
Randy Marshall
  • 349 Answers
SOURCE: how do i set the flush levels for a glacier bay
http://www.homedepot.com/catalog/pdfimages/f9/f9b2dcf2-bfa0-4622-94d9-7b326c22eb1e.pdf
Go to page 5 & 6 and it will guide you through setting levels.
Posted on May 23, 2010
woobie dog
woobie dog
  • 1273 Answers
SOURCE: How can we stop our
Remove the lid from the tank. Verify that the tank is full. Shut off the water to the tank, at the wall. Wait 5 minutes. If the level has fallen in the tank, the flapper valve in the bottom of the tank is the culprit. If the tank remained full, the issue is with either the fill valve assembly or the overflow tube.
--W/D--
Posted on Jan 16, 2011
.dwg file corrupt?
Different solutions you may find out here:-
http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/dwg/444-%E2%80%8Berror-cannot-open-file-open-cad-drawing-dwg-format - a lot of different opinions might be your saving.
BAK files are very important, explanation below:
Consider what AutoCAD does during a QSAVE (assuming "create BAK" is enabled)
1. It writes the contents of the editor to a temp file.
2. It renames the current drawing from .DWG to .BAK
3. It renames the temp file to the correct file name with a .DWG extension.
I don't see how you have had problems with BAK files since it's simply a copy of your last save. In fact, if you QSAVE twice in a row, then your BAK = the DWG.
OR
Third party software DWG Viewer Tool
But demo version for free:- http://www.dwg.viewertool.com/
Nov 06, 2014 | Autodesk AutoCAD Computers & Internet
Uberhaus dual flush toilet keeps running
The flapper may not be seating properly after a flush. Even though you say the toilets are brand new, something may be askew in the flushing assembly or may have been affected during installation
May 27, 2013 | Home
Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
May 16, 2010 | Toto Aquia II Dual Flush Toilet
How do you lock a dwg file so it cannot be edited?
A COUPLE OF SUGGESTION
Now you can protect your works with this DWGLock software, the entities in the send out drawings can NOT be copied nor changed. However, recipients can open up the drawing, add lines and markups. Only the drawing owner allows extracting the drawing, if they need to, enclosing the added part with the native drawing. This is ideal solution for the collaboration needs and contractors.
It is a stand-alone application, no AutoCAD required; Supports AutoCAD R2.9 thru 2009 drawings. about $330.
CADLock, Inc. continues to create innovative solutions that enable you to maintain control of your intellectual property and share it with those who need it. We invite you to download and evaluate CADVault® for AutoCAD® to find out how digital rights management can work for you. THIS MAYBE PRICY also
Acme CAD Converter Acme CAD Converter is a dwg/dxf/dwf format conversion software for batch and vector files. It can conveniently convert DXF,DWF and DWG files into BMP, GIF,JPEG, DXF, DWG, SVG , PDF, HPGL etc., and also enable the conversion between DXF and DWG file versions (R2.5-R2005).
Apr 01, 2009 | Autodesk Map 3D 2006
My Inkjet 2800 won't print DWG. (CAD) files. I have no problem with other files; word, excel, photos ... When I try a CAD file, the printer shows "printer error."
Does the printer show you Printer error with number and letters following it? Prior to printing, check the 'print preview' to see how the layout of the printing is showing. If the CAD drawing is not adjusted to fit on the paper in the printer, you may from time to time get a printer error.
Feb 03, 2009 | Computers & Internet
Dec 28, 2007 | Computers & Internet
Home Logo
164 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
