Question about Kenwood Audio Players & Recorders
How do I change the input from analog to digital or optical on my Kenwood Kraft-v7772d? Thanks
Posted by Shulman jonathan on
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: Digital Audio moved from TV/SAT to DVD/LD
Using the remote control, push the left arrow until display shows Coax1 (or 2, depending on your setup), then push the up arrow to set it to TV/SAT.
Conversely, depending on your setup, you can push the left arrow to display Comp1 (or2) then push the up arrow to set the correct video setting-- DVD/LD I assume.
Posted on Aug 05, 2008
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: kenwood vr-5900 no sound
Check you settings on the receiver. get into the menu of the unit and check the "Audio" settings. if you can choose by specific input, select "Digital" otherwise, select "Auto" that should correct the problem. If you still have a problem, post a comment and I can help you troubleshoot some more.
Posted on Jul 26, 2009
Rifaa
Rifaa-ath Razei
  • 99 Answers
SOURCE: Kenwood KRF 7775D not working with Digital Inputs
First of all my nick is Rifaa.
Secondly do you still have the amp
Posted on Sep 08, 2009
Anonymous
  • 8546 Answers
SOURCE: want to use Yamaha rx-797 reciever with bose 901
I don't know why the comment from Yamaha about Tape Monitor killing digital inputs is relevant.
According to the manal I downloaded, THIS stereo receiver doesn't have digital inputs.
As to using 901's and 301's...
You will need a separate Power Amp for either the 901's or the 301's. Sorry, but you can't share the amp with the Active-Equalized signal and non-901's.
I use 901's and 301's in MY 7.1 rig with a separate amp for the 901 and NOT using a Tape Monitor, but a preamp out feed for the front channels.
Posted on Feb 16, 2010
Anonymous
SOURCE: Multi room will not play
I have a Marantz 7.1 AV receiver (sr5500) and I run a 5.1 set up for home theatre and use the 2 extra channels to run a pair of outdoor stereo speakers... When I first set it up I also found I could not get a digital signal output, only analog, after reading the manual(!) I discovered that it can only output an analog signal...so I have used the phono outputs on my blu-ray player into the CD input of the AV amp and play CDs outside through this and it also outputs the optical digital signal into the AV amp through the DVD input...my iPod also plays through a dock and it's analog output to the speakers outside through another (CD-R) anolog input on the amp... Hope this helps
Posted on Feb 10, 2011
Can I run my Kenwood-ke205 equalizer,witch is AV while using digital optical as my input sound source on my vr-507?
Here is the receiver manual
https://manual.kenwood.com/files/B60-5027-00.pdf
The problem you have is, you cannot insert an Analog external signal modifier into a Digital audio chain (Optical or S/PDIF).
Your receiver does not have an Equalizer send/receive loop.
The only way you could do this, is to take the Tape Record Out to the Equalizer's input, then the EQ output to the Tape Playback In. Then to hear the effect of the EQ, you would have to switch the receiver to Tape monitor.
https://www.manualslib.com/manual/775182/Kenwood-Ke-205.html?page=6#manual
Kenwood KR-V8070 accept digital signals, trying to hook up to cable box?
The Kenwood KR-V8070 has no digital audio inputs; it only has analog inputs. You can see the manual's diagram of the rear input/outputs starting on page 4 at ManualsLib: https://www.manualslib.com/manual/287040/Kenwood-Kr-V8070.html?page=4#manual . If you need to connect a device that doesn't have an analog audio output, you will need an analog to digital audio converter. This is one version: https://www.amazon.com/SANOXY-Analog-Digital-Converter-Adapter/dp/B005F20756 . You will need to supply all of the audio cables separately.
The later KRF-V8070D does have coaxial and optical digital audio inputs. I hope this helps.
I have a kenwood VR405. I am useing a samsung blu ray and a cox cable box. both components are running directly into the samsung flat screen via HDMI. I am backfeeding digital audio to the VR405 via...
Josh, define the 'backfeeding' of the digital audio from the two HD components into Video 1. Those are ANALOG inputs on the VR405. You have two coaxial- and one optical-digital audio input you could/should be using.
I'm surprised you're getting ANY audio (much less digital audio) from the BD and Cable Boxes unless you also have an analog audio path coming in from (what?) the TV.
http://img.inkfrog.com/click_nelarge1.orig.php?image=100_2147.JPG&username=gceparts&aid=773763271
2answers
I have audio cables going from HD 61g887 jvc tv, to my phillips surround sound system under aux but it is not giving me sound?
hi
you didn't mentioned the model number of your surround sound system, for a better solution its important. any why try the following.
if you are connected the analog audio output of your tv to the system using RCA cable, then go to the setup of the surround sound system and change the input assignment setting from digital to analog.
If your connected the digital output of your tv to the digital input of your surround system using optical cable then, goto the setup of your surround system and change the input assignment to digital (optical) input.
if u need any further assistance fell free to contact through fixya
2helpful
2answers
I am using a JVC RX6000 video audio receiver, and i hooked 5.1 BMB brand home surround speakers to it, and connected my ASUS media player that has optical output and used optical cable to connect to the...
This is a common problem. Each input will default to analog. Even though you have plugged an optical cable into the inputs of the Receiver, you have to change that input to digital.
For example, if you connect a CD player RCA cables to the Receiver. The receiver will recognize the Analog signal at the CD input. If you unplug the Analog RCA Cables and plug in the Digital optical, the receiver will still be at it's normal default input for the CD player which is Analog. You then have to switch the input, using either the remote or it may be able to be done with the buttons on the front.
As soon as it is changed to Digital, you will get nice sound.
Hope this helps,
Happy New Year,
Mark
1helpful
Only the radio output works but no sound if connected to TV or DVD player ?
you will probably have to set the correct input on the reciever, those two inputs will be able to recieve a digital input i,e coax or optical or the traditional analog (red and white ) jack.. the reciever might not know which type of cable your using for the tv and the video input..
Can't change FM input mode! Stuck at analog...
Tuner is only analog. As for the Video 1 input you need to go into the menu and change it to the digital port you want to use (optical, coaxial or HDMI) you can set only one input to each digital input port.
2answers
Kenwood vr-5900 no sound
1helpful
2answers
Kenwood vrs-6100 receivers optical digital
You want to receive the optical signal from the TV's built in decoder / receiver to play through your Kenwood? Maybe you need to select the digital input. The manual says:
Use the INPUT SELECTOR key (or Input Selector keys)
to select DVD, VIDEO or FRONT AUX.
2 Press the INPUT MODE key.
Each press switches the setting as follows:
1 "F-AUTO": Auto detect
("AUTO DETECT" indicator lights up)
2 "D-MANUAL": Fixed to digital input
("DIGITAL" indicator lights up)
3 "ANALOG": Fixed to analog input *
("AUTO DETECT", "DIGITAL" indicator goes off)
Also check your TV to make sure it is outputting to the optical jack.
Top Kenwood Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
David Shaub
Morne Olivier
Morne Olivier
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
