Do I use grease on the shaft of wtw6200sw0 washer. And is there anywhere else?
Posted by Lori A Micheletti on
Jimmy
    Scholar:
  • 61 Answers
Hi Lori, you shouldn't have to grease anything on that machine. What is the problem with the washer that you think you have to grease it? If it's squeaking while it's in the spin cycle,it has a leaking tub bearing and the bearings need to be replaced. You should call your local repair company to check it out and give you a price quote. Hope that helps.
Posted on Aug 10, 2019
I have a Sears Kenmore washer (Model # 11092281100). I replaced the motor coupler, and I checked the alignment of everything before reconnecting the motor clamps/clips. It seemed like the motor shaft was...
It could be the grease. It could run without noise if it was not installed all the way. Here is a link for properly installing Motor coupler video Now if everything looks right it is probally just the grease.
Nov 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My washer model number wtw6200sw0 keeps giving me an f1 error code. what do i do?
Primary Control Failure
F then 1 flashes when there is a primary control failure. Replace
the machine/motor control assembly. See Accessing &
Removing the Electronic Assemblies, page 14.
WTW6200SW0
Tech Sheet
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 10, 2010 | Whirlpool Washing Machines
Kenmore 80 Series washer leaves brown grease marks
Remove the agitator and check the shaft seal underneath the plastic drive block at the top of the shaft. Move the shaft in different directions to check the condition of the top bearing. If none or very slight, replace the seal at the top of the shaft supporting post. Clean any grease that is outside of the seal when you are done. Be sure to not damage the seal surface on the shaft when removing/replacing the seal and pre-grease the new seal's inner lip before installing.
Nov 15, 2009 | Kenmore 22422 Top Load Washer
Fairly new ge washer spitts out grease/oil from under agitater
Remove the agitator and inspect the upper shaft bearing condition by trying to push the shaft in various directions. It should not be possible to observe movement in a good bearing. If the bearing looks good, then replace the rubber seal just under the plastic block on the shaft top. You must be very careful not to damage the shaft where the seal lip rides. If the bearing is loose, the machine must be torn down to remove the shaft from the supporting post.
Aug 15, 2009 | Washing Machines
I AM REPLACING THE BASKET ASSEMBLY ON MY KENMORE FRONT LOAD WASHE
The shaft on the spin basket assembly is not lubricated. The shaft is inserted through the sealed bearings located in the rear outer tub shell. Placing any grease on the shaft would end up in your wash and damage your clothes.
Apr 03, 2009 | Kenmore 42822 Front Load Washer
Sears Kenmore washer shaft grease?
Yes auto parts,home depot or appliances store you can use all purpose grease good luck .
Oct 31, 2017 | Kenmore Washing Machines
Maytag washer tub seal bearing kit - grease?
how do i change bearings and shaft ona maytag washer model# mvwb300wq0
Jun 17, 2008 | Washing Machines
Replacement grease for drum shaft seal
you really dont have to use any at all unless you have removed all of it.Remember 99% of these bearings are self lubricating.
May 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Grease spots on clothes
Your drum support bracket grease shaft seal (which will require a new Lip Seal Kit #12002022) is dead and potentialy the two shaft bearing are at risk. Parts cost retail approx. $100 or so. Labor, Lookout...
I'm fighting this issue for the second time.......
Bill B.
May 20, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
