Question about JVC Audio Players & Recorders
JVC RX-R75. The power outlet indicator is out. Is there a fix for this? I also read, if it’s out I should cut out some diodes. Is this true?
Posted by Rob Johnston on
4 Related Answers
robotek
Graeme Ross
  • 1512 Answers
SOURCE: Unknown outlet for JVC RX-5020VBK
John, are you still needing help with your problem??
robotek
Posted on Jul 02, 2008
bbl242003
Bruce lee
  • 1637 Answers
SOURCE: jvc receiver rx-555 display bulbs
Please refer to the locations in my comments for your service manual to change out your diodes. Your going to need soldering experience to do this and careful for the high electricity with the capacitors.
Posted on Jan 16, 2011
Demonic-2011
Demonic-2011
  • 512 Answers
SOURCE: JVC rx 817vtn
From experience, a protection circuit has cut in, most likely due to a short in one of the DC output voltage rails on the PSU, thus giving the result of red standby LED, then green, then back to red. If the standby LED is not flashing/blinking, chances are you won't see any error codes.
This unit consists of several surface-mounted components, transistors, diodes, capacitors and resistors (many of which are miniature and often glued to the PCB) - this could become very costly, just in replacing modules as opposed to individual parts and spending hours fault-tracing looking for the problem which could cost a lot more in terms of labour.
I would recommend that you get a second opinion - take it to a service centre, obtain a quote for the estimated cost of repair (and fault diagnosis at the same time) - then you can make a decision after that.
It's up to you but before spending ANY money on it, throwing it out, or selling it somewhere as is, or whatever, get that second opinion from an authorized service workshop first. See how you go. *Nothing is impossible to fix, some things are complex.*
Posted on Aug 24, 2013
Testimonial: "I found a blown fuse near the back of the amp, I believe it would be the one for the 2 plug ins in the back. Going to try a fresh one and see how that goes. I only wanted this for a garage stereo so I may just chalk it up to a lost gamble. "
windshiel97756
Vincent Smith
SOURCE: I need help with the schematic diagram of a JVC RX-5THPBK power amplifier
Have you checked into SAM'S FOTOFAX or other searchers, or do you have schematic and need interp. of it?
Posted on Aug 03, 2016
Testimonial: "i do not have the schematic. i would love to have the schematics of that AV amplifier."
Where can buy jvc Rx-r75 remote control and if there any other model that would fix
http://www.jvc.newremotecontrol.com/catalog_item.php?catnum=RM-SR75U&refnum=RX-R75
May 16, 2017 | JVC Audio Players & Recorders
Iplugged my jvc rx-7010vbk 120v reciever into a 220v outlet, does it have a power supply fuse that would burn out or is the whole power supply shot, what parts do i need to fix it
more than likely the whole board is shot
fuses only control current flow and break when that is exceeded
It is the voltage that does the damage that same as when you put 12 volts through a 6 volt bulb
Jul 08, 2016 | JVC Audio Players & Recorders
I have a jvc rx-518v amplifier with a burned out resistor on the imput board (r474) and diode (d474). They are severely overheated and the identifiers are gone, but the rest appears functioning. Any clue...
R474 should be a 18Ohm 2 watt metal oxide resistor part no. QRG022J-180AF
See page 2-9
and D474 is a zener diode part no. MTZ12JC see page 2-8.
The service manual can be downloaded from
JVC RX 518 VBK SM Service Manual free download schematics eeprom repair...
scroll down and select Get Manual link.
Aug 24, 2014 | Televison & Video
JVC rx 817vtn
Aug 24, 2013 | JVC Audio Players & Recorders
I spilled a liquid in my jvc rx-502ov receiver and a message reads dsp micom ng what do i do?
You fried the poor thing to put it mildly, Get a different one end cut down on your partying ,(GUY) Unless you have money to burn
Dec 05, 2012 | JVC Rx 5020v Stereo Receiver
Jvc receiver rx-555 display bulbs blown and diodes appear burned. How can diodes be replaced?
Jan 12, 2011 | JVC Audio Players & Recorders
JVC RX-318 keeps blowing fuses
could be several things, speaker wires touching,shorted output transistors, a shorted rectifier diode,bad filter caps in the power supply,those are the most common
Jan 06, 2009 | JVC RX-318 Receiver
robotek
May 27, 2008 | JVC RX-5020VBK Receiver
77 people viewed this question
Top JVC Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
