Cameras Logo
Question about Olympus Cameras
My olympus sp-600uz camera made a loud pop sound shortly after I opened the flash. Now it has no power at all. I probably know the answer but would welcome qny helpful info or ez fix short of taking it to a shop
Posted by scot bennett on
5 Related Answers
Anonymous
  • 173 Answers
SOURCE: lcd backlight blown, poss. capacitor?
the flash capacitor witch stays charged for days even when your camera off has very high voltage on it and probably arched over into more that just blowing your lcd screen.
only thing I would do is junk it or buy one on ebay with minor problems and start repalcing boards, get some fine jewlers philips screwdrives and small flat, and be very careful. I wouldnt try to replace any surface mounted componets.
Posted on Jan 18, 2008
Anonymous
  • 319 Answers
SOURCE: Maytag Range MER5875QAS Problem
You may have a serious electrical problem. Or you may need a new element.
Please provide more info as to the source/location of the smoke.
Brian
Posted on Jan 19, 2008
fixyathing
jhun T
  • 341 Answers
SOURCE: 'Shutter' not opening.
it won't open if the it is set to "preview" mode...just check or else it's stuck
Posted on Aug 19, 2009
Anonymous
  • 11967 Answers
SOURCE: Zoom Error with my Olympus SP-550uz
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 04, 2010
Anonymous
  • 691 Answers
SOURCE: Hi Ive got an Olympus SP-550UZ digital Camera
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty. "Zoom error" is repairable
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Feb 21, 2010
Date stamp for Olympus SP-600UZ
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
1helpful
3helpful
Need manuel for model SP-600UZ
You may download a PDF manual and/or order a printed manual from here.
Need set up software for my olympus sp-600uz
You can download the Olympus ib software HERE.
2answers
I need a user manual for a sp-600uz Olympus digital camera. I would like to get the physical booklet. I'm pretty camera illiterate.when I bought the camera it didn't come with a manual.
I wasn't able to find a location of which you can order the booklet, but I was able to find a link on Olympus' site. I hope this helps, and if it does please go ahead and rate my answer! Thank you and have a good day!
Click here for the manual!
May 03, 2011 • Cameras
How do I get my windows xp pc to recognize olympus sp 600uz when connected via usb?
After you connect the camera make sure you power up the camera and sometimes you have to choose usb mode. If that does not work, go to my computer and choose removable drive and you can access your pictures that way too.
2helpful
2answers
I need to find a users manual for the Olympus SP-600UZ Digital camera.
You can download the user manual for this camera from this link, just click HERE.
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
David Shaub
Are you an Olympus Camera Expert? Answer questions, earn points and help others
