Question about Pets - Others
I adopted a 3year old sonoran desert tortoise who refuses his burrow. He will hang out under a couple of bushes or tonight he was just tucked up along the side of my home. No shelter at all.
I have tried putting him in his burrow at night after he is a sleep but that has not worked. I have had him 3 weeks
Posted by Kristina on
Glenn
    Master:
  • 591 Answers
Animals have their own preferences. Let him do what he is comfortable doing, and stop trying to force him to do something he does not want to do, and is obviously uncomfortable with.
Posted on Aug 19, 2019
5 Related Answers
Anonymous
SOURCE: Problem with BUSH 6685 VPL
No, I guess the tube is somehow broken. I had the TV exchanged.
Posted on Jun 29, 2007
eagle338
eagle338
  • 4889 Answers
SOURCE: cooling
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • If yu can hear some sound of a fan then the compressor is working..As for the other devices you have check for open circuits..Report what you found so that we can trouble shoot..
    Posted on Oct 23, 2007
    steve shroder
    • 141 Answers
    SOURCE: 1320n marks along left side of paper
    repetitive defects are caused by either a ding on the drum in the toner, a scratch or dirty transfer roller, or scratched or dirty heat roller in the fuser, Last but not least is dirty exit roller. the first step to any print quality defect is to cahnge the toner cartridge. Good Luck!
    Posted on Sep 17, 2008
    Anonymous
    • 66 Answers
    SOURCE: water pools under carpet on passenger side with a/c on
    check your condensation drip tube on passenger of firewall it is most likely clogged with sand preventing the water from draining out
    Posted on Jun 29, 2009
    Gil D
    Gil Domanillo
    • 217 Answers
    SOURCE: my iphone hanged up!
    1. Turn on your iPhone (in my case it would only get as far as displaying the Apple logo
    2. Hold the power and home buttons down (the iPhone will power off after 10 seconds, but keep holding those buttons down)
    3. After the iPhone powers off, release the power button (but keep holding the home button down)
    4. After a couple more seconds, you should hear that magical “ding dong” that means the iPhone is coming back alive, and that Windows has detected it. You may even see a little “New hardware” popup in Windows. It is now safe to release the home button, and your iPhone is in DFU mode.
    5. Now iTunes will see it as a DFU’ed iPod and should ask you to automatically restore its firmware.
    6. iTunes has to download the new firmware, and it takes a while, so go make a sandwich.
    7.jailbreak your iphone and unlock.
    8.here's how to jailbreak your iphone:http://www.iclarified.com/entries/index.php?caid=2&scid=11&seid=2
    9.here's how to unlock your iphone:http://www.iclarified.com/entries/index.php?caid=2&scid=11&seid=1
    Posted on Jul 25, 2009
    How often should the control arm bushings be replaced on a Audi TT 2001?
    depends on the road conditions traveled and driver attitude
    most bushes will last over 100,000 klm or 100,000 miles but a wheel alignment will be a good guide as to control arm problems
    Many shops insist on tire rotation but smart operators refuse this because tire wear is an indication of alignment, control arm bush problems and shocky failures that tire rotation masks
    however have an accredited suspension shop professional put it on a hoist ( wheels hanging down0 and check for torn rubbers in the bushes
    also check the rear bushes at the same time as rear tire alignment is critical to good front alignment
    Apr 23, 2018 | Audi Cars & Trucks
    Otters river
    River otters can be found all across the United States except for in the desert and the Florida Keys. They live in both freshwater and slightly salty, brackish habitats. As their name suggests, they inhabit rivers, but they also inhabit lakes, as well. River otters choose their habitat based on how much food and shelter they can find. As a result, their habitat can change depending on the season. For example, they will move from temporarily flooded marshes to cypress swamps that have permanent ponds. They make their dens in bank burrows, under trees and stumps, or in thick vegetation.
    An image of what they look like is attached.
    Screenshot
    Feb 08, 2018 | Homework
    I have a insta - set clock radio model 44200 just open pkg noticed next to electrical cord hole there a small hole and there a 7 inch thin wire hanging out of hole is this extra wire they forgot to cut is...
    That's the radio antenna. Just tuck it under the unit or along the back of the shelf or whatever if you get adequate reception. If you don't then you might try fussing with it--taping it up the wall, draping it over a book, that kind of stuff.
    Oct 17, 2013 | Equity Time USA Audio Players & Recorders
    What shelter/enviroment does a tortoise need. Please help me I need this information for a school project. Please you guys are my only hope!!!! HELP!!!!!!!!
    That depends on the type of tortoise. A tortoise five centimeters in length obviously requires a different environment from a tortoise two meters in length.
    Take a look at https://en.wikipedia.org/wiki/Tortoise
    Jul 26, 2013 | Silver Tone Tortoise Shape Metal...
    I have a conon PIXMA MP170 dn i dont know how to hange the ink cartridge...I cant find where the old one is either
    plug it in with the printer turned on lift up the scaner unit and the print cartridge will slide along to the left simply pull back on the top of the cartridge to remove you will not see it with the unit turned off as it tucks in under the right hand side of the caseing
    Jul 19, 2008 | Canon Office Equipment & Supplies
    Compressor shutsoff
    Does it only shut off at 110F or will it work ok under that temp?
    Aug 14, 2007 | Goldstar R5050 Air Conditioner
    Bush id tv
    Dear Sir, unfortunately tonight you will not be able to watch this TV set. Please try with an alternative solution. This job definitely requires a professional technician Best regards, Arpi
    Jun 17, 2007 | Bush 5693D 24" TV
    Pets - Others Logo
    165 people viewed this question
    Top Pets - Others Experts
    Tom Chichester
    Ruth summersides
    Kardoc
    Are you a Pets - Other Expert? Answer questions, earn points and help others
