Question about Hardware & Accessories
Can the you email me manual for vigoro 2 zone timer model 15622-HDC
Posted by william cheng on
5 Related Answers
paj42
  • 1116 Answers
SOURCE: I have lost the manual to a kenmore sewing machine
I am not familiar with this particular model. Can you find the foot type from this guide - http://www.sewingmachinesplus.com/sewing-feet.php
I could not find a manual online for this machine. Sears may be able to help on this.
Posted on Feb 24, 2010
Anonymous
SOURCE: I need a manual for a Vigoro Water Timer model
i can email it
[email protected]
Posted on Jun 24, 2010
Anonymous
SOURCE: I have 2 Vigoro 196-036
It comes out of the holes because the water goes in the holes. That might sound dumb but Vigoro designed these only to be in dry conditions, such as attached to the water line. I used them for sprinklers, but the water poured into the timer so bad it shorted it out in a week. I did find a vigoro timer with no holes and a sealed unit, and they work great. But I can't find them anymore.
Posted on Sep 28, 2010
Anabel
SOURCE: vigoro 196-036 water timer manual
Here is theinstruction:1. Install the battery2.Use left attor to decrease and right arrow to increase numbers < > to set current time to nearest hour at the time, noting AM and PM3. Repeat above instructions to set "start time: to desired time for day to begin watering4. Use left and right arro <> buttons to set "how often" (watering frequency) to select an hour/day increment (8 hours=3 times per day, 2 days=every other day).5. Use left and right buttons < > to set "how long" (watering duration) to select a min. or hr increment.6Activate the watering program by pressing the Program on/off buttin: a horizontal bar will be displayed to signify the program is on. Press the program on/off again to disable the programTo avoid accidentally changing the current program, the arrow button will be "locked out" or inaccessible if "program on" is selected.To create a new program, press Program on/off if necessary to disable current program.
Posted on Jul 12, 2011
Anonymous
SOURCE: We have a Vigoro Two
The timer is no good.
1) Clean battery terminals and make sure battery polarity is correct.
2) If you bought timer at Home Depot, call:
Internet Customer Service Center at 1-800-435-4654
3) If you live near Home Depot, then buy new timer and return defect timer in new package.
4) Here's what Home Depot customers say about this timer: the product will fail after 4 months, only worked one season, failed right out of box, new batteries did not restore functionality, etc. Only two good reviews.
Take a moment and vote on fixya answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Aug 27, 2011
Need to known how to set the timer do not have a manual we have the VIGORO deluxe water timer, they are about two years old.
I do not know how to set the timer, but can offer possible source for manual.
VIGORO timers can be same as Melnor:
Match up image with your timer and then download manual.
Water timers last 1 or 2 seasons. There is no repair for broken water timers.
http://www.melnor.com/instructions.php
Take a moment and rate answer for accuracy:
Sep 12, 2011 | Hardware & Accessories
How do I get free instruction for Water Timer Vigoro Duo- Deluxe Water timer # on front top lefte is 225-379 # on back is 0708
The vigoro duo delux might be same as Melnor 3100
Open following links:
http://www.melnor.com/instructions/3100_InstructionSheet.pdf
Take a moment and rate answer:
Sep 02, 2011 | Hardware & Accessories
We have a Vigoro Two Zone Water Timer. The timer started beeping and flashing that the batteries are low. We put new batteries in and it is still beeping and flashing low battery. What do we do now?
Aug 26, 2011 | Hardware & Accessories
I have 2 Vigoro 196-036 watering timers. Why does water come out of the three holes near the battery compartment on one of them?
Aug 25, 2010 | Hardware & Accessories
I need a manual for a Vigoro Water Timer model 196-036 does anyone know where I can get one? Thanks
SEND ME A FAX TO 972 233 0768 AND I WILL FAX MY COPY TO YOU. SORRY MY SCANNER IS BROKEN.
May 13, 2010 | Garden
My vigoro water timer i bought at home depot will not stay on manual off/om or on its program. I have installed the new 9 volt battery correctly since i can program ok but it shuts off in a short time...
I have a Vigoro 271-687 in which has worked well except when i change the batteries it wont reset and will not work do you have any solutions to this problem i really like this product just dont understand the prob
Jul 01, 2009 | Garden
Hardware & Accessories Logo
212 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
