Question about GPS
My voice texting has changed to Google, tap to speak and I've lost my texting keyboard. I don't want it this way. I want it like it used to be
Posted by Becky Swartzendruber on
5 Related Answers
marvinduran
  • 39 Answers
SOURCE: street turn
you can only change to the voices available in your device.
Posted on Dec 15, 2009
HarryHarley
Harry
  • 343 Answers
SOURCE: I can't select text language and keyboard language
For Garmin anyway: Make sure you have latest software first.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This may be a result of a previous software version on a device or possibly some one changing the settings. If a device does power on with a foreign language that you can not understand it can be corrected by going through the settings to change the text language.
To change the text language:
  1. Touch Wrench icon on the screen with the Magnifying Glass and Map icon
  2. Touch the Gears icon
  3. Touch the down arrow
  4. Touch the second option from the top1
  5. Touch the middle blue box on right
  6. Touch the up arrow until American English appears2
  7. Touch American English
  8. Touch OK
  9. Touch Back
The device should be in selected text language.
Note 1 - In some cases, if there are Custom POIs loaded to the device then it may be the first option at the top.
Note 2 - If American English is not the language needed, please selected the desired language
Posted on Jan 18, 2010
javer821
Javier Gonzalez
  • 207 Answers
SOURCE: No voice recognition
You must have already set up and trained a user with the Dragon NaturallySpeaking software prior to transcription. Make sure that the Digital Voice Editor (DVE) software is not opened prior to starting these steps.
Open the Dragon NaturallySpeaking software.
The Dragon Bar window opens. From the Dragon Bar menu, click the Sound button.
From the Sound button, select the Transcribe Recording menu item.
The Transcribe a Recording dialog box opens.
Click the large square button to the left to start the DVE software.
The Digital Voice Editor window opens.
NOTE: If the file you want to transcribe is still on the Integrated Chip (IC) recorder (which will be reflected on the left side in the IC Recorder window), you will need to connect the IC recorder to the computer using the supplied USB cable, or transfer the file to the computer.
Select the item you want to transcribe from the PC window on the right side.
Click on File from the tool bar.
Select the Voice Recognition menu item.
The Converting.. Dialog box opens.
The Transcription Options dialog box opens.
Click the Transcribe button to continue.
The Transcribing window and Dragon Pad window opens.
The text is displayed while the transcription is in process.
NOTE: Once the transcription is complete, it may be necessary to make grammar, word, punctuation, and formatting adjustments.
To save the text file, click on File from the tool bar.
Select the Save As. Menu item.
The Save As dialog box opens.
Browse to the folder location to which you want to save the text file and double-click on that folder.
The folder you chose should now be showing in the Save in drop-down box near the top.
Type in the desired File name in the File name drop-down box towards the bottom and then select the document type.
Click the Save button.
Click the X (close) button in the upper-right corner to close the Dragon Pad window.
Click the X (close) button in the upper-right corner to close the Digital Voice Editor software.
Posted on Feb 12, 2010
Anonymous
  • 22 Answers
SOURCE: my computer is dell insprion 1525 model. when i
If you are using the Dell Webcam then i know what's wrong. Go to the Dell Webcam Consol click effects. If "Enable Audio Affects" box is checked then uncheck it. This takes away the audio affect you are hearing in speakers.
Hope this helps :)
Posted on Jul 10, 2010
howard_compu
Howard Rubin
  • 211 Answers
SOURCE: Hi there, I've just bought
You may have to disable the onboard microphone to use the connected hardware.
Realtek is very picky, same goes with speakers connected to the back and front at the same time, no sound. Disable the one you are not using.
Posted on Sep 08, 2011
I have a new Alcatel one touch, Fierce 2 cell phone. I bought it last week. When I first used it, the phone had a microphone icon in the texting area. Now it's gone. How do I get it back so I can
If you good down the comma button the setting menu for the keyboard should pop up. If it does not it may not have the standard keyboard installed especially since you may have added an emoji keyboard. You can select the manufacturer default from the same menu by going to phone settings then keyboard. The last option would be to go to the Google playstore and download the keyboard put out by google. To do this do a search for google keyboard make sure that google is listed as the developer. Once downloaded and installed choose the keyboard from the settings, input, keyboard menu.
Dec 02, 2014 | Alcatel Cell Phones
How to add voice search and voice text to apple iPhone
You don\'t say what model of iPhone, and version of iOS, you are using. IPhone models from IPhone 4S, and iOS versions from iOS6, can use Siri to search or send a text.
Tap and hold the home button for a few seconds, then give your command, such as "Search Google for..." or "Send message to xxx saying ..."
Feb 12, 2014 | Cell Phones
I can't change from Japanese to French. Please,show me how . Thank you
To change the language to French;
  • Press TOOLS (The spanner symbol on the bottom right corner of the screen which shows WHERE TO and VIEW MAP) This may take some trial and error if you don't speak Japanese but should be possible)
  • Press SETTINGS (The spanner icon) or LOCALE (the blue icon) on some models that don't have a settings menu)
  • Press LANGUAGE (the lips icon)
This brings you to a screen with 3 items; VOICE, TEXT LANGUAGE and KEYBOARD. Press each one in turn and select Francais. With the VOICE setting you may have to select a name rather than Francais. If so select the name of a person from a French speaking country.
I hope this solves your problem.
Jun 02, 2011 | Garmin nuvi 205W GPS Receiver
New Garmen is in Spanish. Want to change to English. Purchased in Ontario, Ca. at Costco.
  • Press TOOLS (The spanner icon at the bottom right of the screen which shows WHERE TO and VIEW MAP
  • Press SETTINGS (The spanner icon) or LOCALE (The blue icon) on models that don't have a settings icon
  • Press LANGUAGE (The lips icon)
  • This brings you to a screen with 3 items; VOICE, TEXT LANGUAGE and KEYBOARD
  • Press TEXT and change it to AMERICAN ENGLISH
  • Press VOICE and select a voice from an English speaking country
If you don't speak Spanish there may be a bit of trial and error involved but I hope I have given you enough information to solve your problem.
May 22, 2011 | GPS
By mistake the language has been changed, how do I change the language of Garmin back to english?
  • On the page that shows WHERE TO and VIEW MAP press TOOLS (the spanner symbol at the bottom right corner)
  • Press SETTINGS (The spanner symbol) or LOCALE (The blue symbol) on models that don't have a settings icon
  • Press LANGUAGE (the lips symbol)
  • There are 3 items on this screen; VOICE, TEXT LANGUAGE and KEYBOARD
  • To change the voice language to English press VOICE and select an English speaking voice
  • To change the text language press TEXT LANGUAGE and select English, or American English if you're in the USA
If the text language is already in German you probably won't know which is voice, text and keyboard. The German word for German is Deutch so when you see this beside one of the items you'll know this is the one to change the text language. This should solve your problem.
Jan 29, 2011 | GPS
HOW DO I CHANGE FROM THE DEFAULT SETTING OF CHINESE TO ENGLISH
  • Press TOOLS (The spanner Icon in the bottom right corner of the screen which says WHERE TO and VIEW MAP
  • Press SETTINGS, the spanner icon, or (LOCALE the blue icon top right, on some models which don't have a SETTINGS icon)
  • This will take you to a page with 3 items. VOICE, TEXT LANGUAGE and KEYBOARD.
If you need to change the text language press TEXT LANGUAGE and select English
If you need to change the voice language press VOICE and select a voice from an English speaking country. If you need to change the keyboard to english Press KEYBOARD and select English.
I know if the text is in Chinese you won't know which icon is which but by pressing each of them in turn you'll get to select English for each.
Nov 27, 2010 | Garmin nuvi 1300 Car GPS Receiver
How do i get my tomtom to give street names in voice to text?
Not all sound files speak out the street names. If you would like to have the street names spoken, you need to select a voice that ends with computer. For example, the voice file selection: Simon, English UK, Computer will speak street names. But the voice file, Bonnie, English US, will not speak Street names. Dave, English US, computer will give you street names but Lori or Mandy, English US will not. Procedure to get the street names spoken: Tap on main screen. Tap on change preferences. Tap on arrow. Tap on change voices. Tap (select) a voice that ends with computer. Tap select. Tap done till you reach the main screen.
May 09, 2010 | Tomtom XL 340S Car GPS Receiver
Garmin 265 W won't speak street names
Below is the procedures for setting the languages...
Touch tools > settings > language > voice.
Voice- changes the language for voice promts.
Languages noted with a persons name are (tts)
text to speak voices.
which have an extensive vocabulary and pronounce
the street names as you approach turns.
The pre-recoreded voices (those without a persons name)
have a limited vocabulary and (do not speak names of locations or streets)
Text language- change all on-screen text to the selected language,
changing the text language does not change the language of user entered data
or map data, such as street names.
Keyboard- select the keyboard for your language,
you can also change the keyboard language mode from any keyboard
by touching the mode button
Adjusting the volume levels
From the "menu" page touch "volume"
to adjust the volume.
To adjust the volume levels for the media player
and the navigation prompts,
please click.
Tools > settings > Volume > Restore
Restore will, restore to origional volume levels.
Regards
Richard
Apr 26, 2009 | Garmin nuvi 205W GPS Receiver
Garmin 780
please click.
You should be good now
Regards
Richard.
Jan 23, 2009 | Garmin nuvi 780 GPS
Street names
http://iq.garmin.com/eCustomer/KODSelfService/request.do?session={ed995d70-c2e6-11dc-6a6e-000000000000}&event=1&view()=c%7Bf996f590-047f-11dc-e004-000000000000%7D&objectId=&eksObjectId=&objectType=Case&isJumpEnabled=false&isContentJumpEnabled=false&vendorKey=&versionId=1301&objectScore=82&from=search
Question
: My nuvi is supposed to speak street names when giving voice prompts but it doesn't. How can I fix this?
Answer: All of the Garmin automotive GPS units that speak street names are also loaded with basic voice prompts (i.e. 'Turn Right in 500 feet') as well as 'text-to-speech' voices that speak street names. If one of the basic types of voice prompts has been selected, the voice prompts will not speak street names.
In order to change this setting on the nüvi line of products, please follow these steps:
  1. In the Main Menu, tap on the Settings icon.
  2. Tap on "Locale"
  3. The second line on this screen has a picture of a mouth. To the right, the current voice for the GPS device is listed. Tap it to change the voice.
  4. Select a voice that is labeled with (TTS) at the end. These voices will speak street names.
  5. Select "OK". The voice has now been changed.
The device should now speak street names.
Dec 22, 2007 | Garmin Nuvi 660 GPS Receiver
GPS Logo
121 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
