Question about Exercise & Fitness
P6 fault rinnai
What causes
Posted by Andrew Goodwin on
1 Related Answer
adam_mamo84
Adam Mamo
SOURCE: My rinnai displays p6! What does this mean and its not blowing heat?
Have the same thing is there a fix for this
Posted on Jul 15, 2017
Rinnai trouble code 12
Flame failure is code 12 Check flame sensor is clean
Nov 25, 2017 | Rinnai Water Heaters
I have konica minolta bizhub c550,it showing me P21 and P6,what is the causes?and the black is not printing well
P6 : cyan image unit problem. P21 come after P6, and it's also too a cyan unit image problem. replace the cyan image unit.
Nov 18, 2013 | Konica Minolta Bizhub C550 Color...
Our Rinnai convector unflued room heater won't start. Lights just flash heat never comes on.
According the the Owner's Manual for your Rinnai Convector Heater, there are 8 things, than can cause what you described. Two of which can be discounted, unless you just had the heater installed.
I have provided a link to the Owner's Manual, that you can download and print for future reference. Please pay close attention to Page # 6 -Pre-Service Check List and Fault Finding. Each problem listed has a troubleshooting solution.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Portables/Granada252/portable_radiant_convectors.pdf
Hope this helps you to further troubleshoot and solve the problem. Please let me know. Cheers!
Jun 17, 2011 | Heating & Cooling
I Have a rinnai 26 has been working for 3-5 years now, just stoped. looks like the poilet light is out, can any body lend a hand
Firstly this unit has no pilot light, it lights automatically when you turn a tap on. Many reasons for it not working. If it just sits and does nothing when you turn a tap on you need to start with the flow turbine or a electronics fault on the PCB. Really recommend getting an expert in, too many things on these that can cause this fault. Sorry to be blunt.
Nov 27, 2010 | Rinnai Digital Remote Water Heater Control...
Rinnai gas water temperature keep alternating from hot to cold
A fault often found with these units is due to insufficient water flow. Usually this causes specifically the shower to run hot and cold. Try turning on more than one hot supply; if this fixxes the fault you will need to try and increase water flow. Most new tapware/showerware have water flow restictors built in. These are the cause of many problems with continous flow heaters such as the Rinnai. In taps they are usually located in the spout if it unscrews. In showers try the shower hose. Find them and take them out. Also make sure your mains supply to the house is on full.
There are more technical faults but this is something you can easily try first.
Aug 23, 2010 | Bosch & Tankless LP Hot Water Heater
Hi I have a rinnai flame fire royal model ib35etr It keeps going out and flashes number 12 on the screen we are moving and packed the book
I had this same problem last year and went through all the checklist in poshpoms suggestions ( I am on mains Gas ). The issue was caused by the Flame rods. Near the 2 pilots at the front and the back. Those small rods each that 'senses' the flame become inadequate, so they were replaced with a new pilot assembly from Rinnai that had longer rods and better coverage. Issue was fixed. Good Luck.
Aug 23, 2010 | Heating & Cooling
Fault 14 on rinnai energysaver 556ftr
Hi.
Error code 14 is Overheating error.
The error can be caused by the high limit sensing overheating and cutting off. In that case the thermal fuse may not blow. The high limit can be reset tripping circuit breaker and allowing the unit to cool down with power off.
If that does not work , then the thermo fuse has blown
In fact tis unit has a thermo fuse. (refer to manual).The thermal fuse can be tested reading continuity. If thermal fuse has blown, then replace the the thermo fuse. If the thermo fuse blows again, then there is a condition causing overheating. b260351.gif
Here Full service manual.
Unless you are a trained technician call Rinnai support ringing the number in the manual. Some of testing and repair operations described are not suitable for the home user.
Regards.
Ginko.
May 31, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
RINNAI WATER HEATER GIVING A DEFAULT CODE OF 11, WILL NOT ACTIVATE......
Fault Code 11 is "no ignition". Could be cause by 1 of many problems such as defective ignitor, no gas pressure, etc. A full list of possible causes can be found here:
http://www.rinnai.us/documentation/downloads/Error_Codes-Tankless_Water_Heaters.pdf
Sep 09, 2009 | Heating & Cooling
Importing MSP Files into P6
There is a simple solution to import mpp files into P6.
Please contact me.
[email protected]
Oct 22, 2008 | Computers & Internet
Exercise & Fitness Logo
119 people viewed this question
Top Exercise & Fitness Experts
Tom Chichester
ray gallant
Marvin
Marvin
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
