Question about Sony Televison & Video
The remote RMT 835 does not work with Sony PJ580V. Battery has been replaced
Posted by Yogesh Saxena on
Tom Chichester
    Top Expert:
  • Sony Master
  • 57,436 Answers
The remote control may have failed.
Posted on Jul 26, 2019
5 Related Answers
Anonymous
SOURCE: new problem with tv and Sony RMT-V202 Remote Control
Samsung makes AVOL you may want to try there codes. Hope this helps.
Posted on Feb 17, 2008
Vista Electronics
  • 1694 Answers
SOURCE: need remote control code for a Sony Dvd RMT-D175A
www.remotecodelist.com ............................................T.
Posted on Mar 22, 2008
Anonymous
SOURCE: how to program remote model # RMT-D130A
Found the manual online, here it is:
http://akamaipix.crutchfield.com/Manuals/158/158DVPN600.PDF
Go to page 60. Basically, just hold the TV Power button down, hit your manufacturer's 2-digit code, and release power button. If the code is right, the TV will power off and then back on again. The manual only shows numbers 01-19 in use, so I guess you only have to trial-and-error a max of 19 codes (which is ultimately faster than downloading and opening the manual)! I hope this helps you out.
Posted on Sep 01, 2008
andy4254
andy williard
  • 226 Answers
SOURCE: How do you program a Sony rmt-d243a remote to a
The RMT-D243A is specifically made for the Sony RDRGX255 and RDRGX355 dvd players and is not programmable to other units.
Posted on Oct 07, 2010
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: SONY RMT-D222P - CHANNEL UP BUTTON
Try to clean contact with contact cleaner spray( radio schack or computer sotre.
If the problem persist Reset with you code in your manual if you do not have the code go to: esupport.sony.com and download free.
After that if the probllem remain, your contact in the remote control is faulty.
Replace it.
Good luck, G-d bless you
Ernesto Cuadra
managua,nicaragua. c.a.
Posted on Dec 13, 2011
We bought a sony svr1000 nd we got the display one minus the remote we bought a tuneable remote will they work on this nd can we by a remote from sony
Buying a remote from Sony will be very expensive - about $90. But you could have bought a generic brand PVR remote on Amazon for about $30. It is hard to know if the tuneable remote that you purchased will support this Sony PVR that you have. If you provide the brand and model number of the remote then I could check and find out if it supports the PVR.
The model number of the Sony remote is rmt-d259.
The generic one from amazon is available at this site.
Replacement Remote Control for Sony RMT D259 batteries included
Aug 23, 2014 | Televison & Video
Rmt d231p
There are no hidden screws. If there is, it should be inside its battery compartment.
May 21, 2013 | Sony RMT-D Remote Control
How do I program my rmt-d301 to work with my Sharp TV?
HI,
Check the bellow link to know about the procedure for using Sony RMT D 301 remote with Sharp TV
Sony RMT- D 301
Mar 14, 2013 | Sony Remote Control RMT-D301 p/n:148907111
Need code for a Direct TV Model H20 Sat Rcvr. using Sony RMT-D206A remote
Sony RMT-D206 remote have no setup code for this sat device.
Nov 27, 2012 | Sony RMT-D206A Remote Control
WILL THE RMT V501A REMOTE WORK WITH SONY RDR VX55
Download the user manual for Sony RMT-V501A remote control, from nt. It will have all details, including setup codes. If there is setup code ofr your RDR VX555, you can synchronise the remote with your device. If there is no setup codes, it can't.
May 19, 2012 | Sony Televison & Video
Cannot open battery compartment on Sony Cybershot rmt-dsc1 remote
@ Frans Bedford-Visser
On the right side of the battery compartment you can see some vertical plastic lines. Pull those towards the compartment. Simultaneously open the compartment as indicated by the arrow. It will open. Took me a while to figure it out but it works.
Jan 08, 2012 | RCA DIRECTV Satellite Remote Control
SONY DVD REMOYTE RMT-187P NOT RESPONDING EVEN AFTER CHANGING THE BATTERY
The remote might be bad or the sensor on the remote or the television is bad. If the metal that holds the sensor light on the remote or the television becomes rusty and breaks off, the remote will not be able to operate the television anymore.
Check the remote and the televisions remote sensor if it is still okay. If they are both okay, then it means the remote is dead and need to be replaced.
Thank you for using fixya.
Caseytech
Sep 05, 2011 | Televison & Video
I do not know the steps to take to program my Sony Video (RMT-V306) remote to my Toshiba television.
To program your Sony RMT-V306 remote:
  1. Set TV_VIDEO switch to TV
  2. Turn on television to be programed
  3. Press & hold the I/O (Power) button
  4. Enter TV code (Toshiba = 07)
  5. Release I/O button
  6. Press I/O to turn off TV
If you have a different brand TV, you can get the code from Sony's e-support site here.
  • Remember, when changing batteries you will need to reprogram remote.
  • The RMT-V306 will not control all functions of your component.
  • Although not common, there may be some components the RMT-V306 cannot control.
Dec 22, 2010 | Sony RMT-V306 Remote Control
Remote for Sony vcr works intermittently.
Sounds like the connections inside the remote are damaged and might need soldering. Check the connections around where the battery terminals are carefully. Has a battery leaked in the remote?
Jan 28, 2010 | Sony SLV-N500 VHS VCR
Replace it.
Ernesto Cuadra
Nov 17, 2009 | Sony RMT-D166P Remote Control
Televison & Video Logo
35 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
