Question about Freezers
No power to my Emerson cf450 freezer chest - Freezers
1 Related Answer
dfbjr
David Black
  • 58 Answers
SOURCE: I have a Emerson model CF450 3.5 cubic feet chest freezer and it quit freezing the food
IS IT RUNNING? HAVE SOMEONE CHECK THE FREON LEVEL.
Chest freezer not working. Light inside chest freezer comes on but green power light doesn't turn on and freezer makes no sound. What could be the problem.
Could be your thermostat is bad and not calling for the compressor to come on. If you are able see if there is power getting to the compressor. If not then back track to where you are loosing power (thermostat) etc.
Nov 04, 2014 | Magic Chef Chest Freezer MCCF5WBX
Chest Freezer Stopped Working 14 years old
The first thing you want to ensure is that power is actually getting into the unit. i suggest that you do that by plugging a night light into the outlet and verify the presence or power. If no power, check your breakers. If power is present note that A chest freezer has only two working parts; the start relay that help the compressor start and a compressor. If you are getting clicking sound, your start relay may be out (inexpensive if you can buy it and install it yourself) or a bad compressor. if you need to call a tech for the repair, you may be able to purchase a new chest freezer that now consume HALF the power and for less than cost of repair.
Mar 02, 2014 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Emerson model cf450
Without getting into too much detail it sounds like ice build up may need defrost its do able but I'd recommend a tech it should be about 120 to 200$ to have jib done right
Dec 07, 2013 | Freezers
Fast freeze light on all the time is this right new belling 100 ltr chest freezer
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
Feb 02, 2013 | Magic Chef Chest Freezer MCCF5WBX
Why is the power light flickering on my Emerson 3.5 cu. Ft. Freezer chest model CF450
Just noticed your question from 2012 - my answer is probably irrelevant by now, but here goes. The power on light is of the neon lamp type, and they will often fail after a year or so, typically by flickering, then getting dimmer and eventually going out. If you feel confident, you can replace this lamp for only a few bucks, but it does require removal and disassembly of the control unit. It would probably cost more than the freezer is worth to have an appliance tech do this. The lamp has no bearing on the compressor function; the freezer will continue to work with or without the lamp. If you're concerned about food loss, you might consider investing 25 or 30 bucks in a freezer alarm. Hope this helps.
Oct 03, 2012 | Freezers
Kenmore chest freezer power problem
Try to unplug the the unit power supply to reset the error. But if the error persist you have to call for a qualified technician,
Dec 26, 2007 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Chest freezer
Make sure you have power going to the unit. Check the thermostat for power on both sides going in and coming out. You need to give me more info. before I can suggest anything else.
Dec 23, 2007 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Freezers Logo
175 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
