Question about LG Refrigerators
LG ice maker not working - LG Refrigerators
Posted by Linda Petersen on
David Spradling
    Top Expert:
  • LG Master
  • 11,347 Answers
Check to see if on if ok check water inlet or filter if all ok possible bad maker
Posted on Oct 10, 2019
5 Related Answers
Anonymous
SOURCE: LG refrigerator model lfx25950tt ice maker not working
I had the same problem and replacing the filter solved the problem for me.
Posted on Mar 22, 2009
Anonymous
  • 255 Answers
SOURCE: My Lg refrigerator ice maker won't work. The arm
ice is stuck in it, take it apart an clean it/defrost
Posted on Sep 07, 2009
SOURCE: water dispenser and ice maker stopped
If they both stopped working at the same time you probably have a blocked water line or bad water valve.
Posted on Nov 22, 2009
co7196
Ned C Cook
  • 3433 Answers
SOURCE: LG LFC23760ST ice maker barely making ice
The making of ice may speed up a bit after the whole unit interior and insulation is cooled down.
Posted on Jan 28, 2010
Anonymous
  • 8 Answers
SOURCE: Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
Posted on Jul 29, 2010
LG french door refrigerator ice maker
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 11, 2010 | LG LFC25770ST (250 cu ft) Bottom Freezer...
My lg refrigerator freezer will not make ice but water function works
heatman101
Aug 29, 2010 | LG Refrigerators
Ice maker won't work
my mum use the same kind of freezer, when it had the problem on the ice maker, we both took it to a lg service center to renew the ice maker engine
May 31, 2010 | LG LRSC-26922 Side by Side Refrigerator
Ice maker stopped working
heatman101
hdghj
May 20, 2010 | LG LRSC26980 Refrigerator
Ice maker not working
heatman101
fkflj
May 19, 2010 | LG LSC26905TT Side by Side Refrigerator
Ice maker doesn't work
Unplug Ice maker from plug on inside wall, remove and let thaw. Don't worry when removed the water will not enter the freezer. Let me know if this works as I get very little support from LG. Thanks, Se Breeze
Jul 30, 2009 | LG LRFD25850 French Door Refrigerator
Mar 16, 2009 | LG Refrigerators
LG LFX 25950SB, the Ice Maker is not working, just hear a click
heatman101
klh
Feb 22, 2009 | LG LFX25960 Bottom Freezer French Door...
LG Ice maker
You may have a broken ice maker and it needs to be replaced. You will need to have a qualified LG technician assist you.
Apr 20, 2008 | LG LRSC-26930 Side by Side Refrigerator
Refrigerators Logo
156 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
