Hardware & Accessories Logo
C
Connie Walt Posted on Jul 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We bought automomstic 2 outlet water timer but on,y want to set one zone. Other one doesn’t have hose attached to it. How do I do that
Your Consultant
Level 3:
Master:
  • Master 825 Answers
  • Posted on Oct 04, 2019
Your Consultant
Master
Level 3:
Master:
Answers
825
Questions
Helped
206216
Points
1873
I had a similar unit. The solution is in the programming. Read instructions carefully
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Sep 15, 2009
SOURCE: water is coming from outlet to heater core area. I
the 90 degree elbow is a drain hose, and it sounds like the heater core is clogged or has gone bad. Is the water draining on the inside of the truck too? check your floor board carpet under the dash.
Anonymous
  • 166 Answers
  • Posted on Mar 07, 2010
SOURCE: I have a Husky pressure
Not a solution... seems like it is blocked, mine freeflows at least a little water when you turn on the hose (engin off)... Did it get a big slug of dirt from the hose of fawcett? .... puzzzling....
Anonymous
  • 1116 Answers
  • Posted on Jun 09, 2011
SOURCE: I have a raindrip 2
You can download your instructions here:
R673CT Digital Water Timer Installation Manual
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Anonymous
  • 3301 Answers
  • Posted on Jul 03, 2011
SOURCE: I have a 2 zone
you could have a short in the lines that lead to the manifold and its not opening the valves which is causing feedback to the timer, usually the neutral wire since it hooks to all the solenoids at the manifold set up, since the timer wants to send out the signal,, it finally shuts down , but in the mean time is using up all the battery backup , go to the manifolds, and check the wires there, it may even help if you uncap them, trim off the bad sections, and rehook them up.
Gene Haynes
  • 5391 Answers
  • Posted on Jun 05, 2013
SOURCE: How to set time on Yardworks two zone water timer
Copy following link to access manuals for each brand of water timer on market 2013:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Yardworks does not have website, manuals or warranty claim procedure.
Instead, yardworks repackages other brands of timer, generally water timers, such as orbit or melnor and raindrip. And sometimes repackages other brands of outdoor timers.
Recommend folks stay away from timer-repackagers such as Yardworks, Timex, First Alert, and buy brand names that have clear customer resources.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
My Melnor 4 zone valves all open despite I turn it all to timer and have not even set the timer details.
remove power and then battery , wait 30 min and turn on and reprogram. watch start times, you will only need to set start time for first valve others will follow in sequence.
Sprinkler will not change zones
You mean timer will not change zones? Is it from zone 1 to zone 2? Does the timer say it is watering zone 2 and no water, does it default and shut down on zone 2? Does zone 2 have run time? Can you be a little more specific?
2answers
Yardworks water timer manual
See if there are any accessible screws to open the unit and clean it, or if there are any tiny opennings so you can blow with some compressed air.
Melnor water timer
Melnor is major water timer company, and not off-brand. However, water timers last a couple years, or less, sometimes they last long time but that is not often.
If not drained completely of water, they will break when water freezes.
Copy following link to identify all water timers on market today:
Most timers have 1 year limited warranty for defects in workmanship.
I have a 2 zone water timer and the 'low battery' keeps flashing and the timer is making a sound like it wants to water but it doesn't. I changed the batteries 4 times and even went out and...
Jul 03, 2011 • Garden
The washer will not complete the cycle. It will not drain and spin.
There could be two problems...The drain could be clogged, or the water pump could be bad. Or the belt that runs the pump is slipping or broken.
1 Fill washer with water and wait for the timer to get to the drain mode.
2 Unplug the washer from the electric outlet.
3 Open the case, and disconnect the water hose from the outlet of the water pump.
4 If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.
5 Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.
6 Reassemble hose from step 3.
7 Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
8 Reassemble washing machine case...you're done...
2answers
Purchased ColdTechCommercial Freezer CFD-3F from private seller. Freezer was used for 9 months then sat in a garage for almost two years. Freezer turns on and runs, but doesn't cool at all- in fact,...
Hose underneath is probably for condensation and defrost water. If the compressor is not coming on, there is a good chance it is the thermostat. There is always the possibility that there is a refrigerant leak and it leaked down over the 2 year period. This is where I would start.
Top Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
