Question about The Computers & Internet
I have a mid-2011 27-inch iMac and a new Mac mini. I'd like to use the iMac as a display for the mini. I cannot get the the iMac to get into target display mode.
I have the appropriate Ttbolt 2 cable and a Tbolt 3 to Ttbolt 2 converter. The iMac disks show up on the mini, but the F2 switch does nothing.
Posted by Adam Bell on
  • Patrik Parker Jul 24, 2019
    Hi Adam Bell, I want to help you with your question, but I need more information from you. Please Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: sighting in, clicks don't move where they're supposed to.
Ja, it's 1/4 M.O.A, so at 25 yards/meter it'll be ca 3 inches. You may have gone in the wrong direction. That is, if it was 3' high, and you went another 3 higher then you'd be at the top of the paper. Probably you've got it figured out by now.
The easiest, fastest, cheapest way to zero is with a rifle rest you can clamp your scope into, or alternatively somehow immobilize your rifle some other way. You take a shot, at 25 yards or so. It makes a hole. You now immobilize the rifle, via your rest or heavy sandbags, with the scope pointing exactly where you aimed before. You now, carefully and without moving the rifle/scope off of the point of aim, dial your reticle to point at the actual bullet hole. Your next shot will be at your point of aim now. So you just put it at the right height above your point of aim at 100 yards now.
Posted on Nov 26, 2008
Anonymous
  • 97 Answers
SOURCE: Can't locate the dirve in Target Disk Mode
You are going to need a system install disk for this machine if you want to reinstall it. However, if you just want to run diagnostics, any system install disk for MacOSX should do the trick. You just won't be able to run the installer once you boot from the DVD. The first thing I would do is make sure the eBay seller sold this to you in this condition and without the install disc, because if not, you've got an issue with them.
If you don't have an install disc, your cheapest solution is to call Apple and order a replacement disc for your model computer. You will need your serial number, which you can find on the sticker on your computer. Good luck, and let me know if you need more guidance with this.
Posted on Jan 09, 2009
sys_admin
Milind Shetti
  • 829 Answers
SOURCE: display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
Posted on May 03, 2009
Anonymous
  • 105 Answers
SOURCE: when iturn on my Sony STR-DE325 it goes into protect mode
Try disconnecting all of your speakers, and then turn on you unit. If you have a defective speaker, or a short in your wires, your unit will go into protect mode. If your unit seems ok with the speakers disconnected, then turn unit off, hook up one of the speaker leads and try it. This way you can isolate the problem.......
Good Luck,
Eric
Posted on Jul 09, 2009
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: Panasonic PV-GS35 will not connect to iMac, so
So if it's miniDV and you have a firewire cable, it should work. Have you followed this sequence:
If your battery is sufficiently charged to run the cam for an hour's worth of tape, fine, otherwise connect cam to AC power. With cam OFF, connect Firewire cable to Mac and cam. Open iMovie, name your project and create so that the viewer screen comes up. Turn on the cam. At this point, your Mac should, within moments, say "camera connected". Cam needs to be set on "playback" mode for capture. Then click "import" button and your Mac will control the cam.
If you still get a "no camera connected" you have to consider the possibility that either the firewire cable is bad or the firewire port on cam or Mac is bad. If you have more than one firewire port on your Mac, try switching. An Apple store should be able to help you determine if you have a bad cable or cam port, if you take both in to try on their Mac. Hope this gets you on track.
Posted on Dec 07, 2009
Transferring data/programs from Mac book to iMac using Ethernet cable. All was going well till last minute, and it has been stuck on that for 3+ hours. Don't know what to do. Help please Elise
Assuming the MacBook has FireWire, get a firewire800 cable. PLug it into both Macs FireWire ports. Shut down MacBook, restart and hold T key = target disk mode. MacBook will appear as any other mounted external drive on your desktop. *From there, you can either manually drag files over or open Migration Assistant on the iMac and migrate user/data/ apps.
Jun 04, 2016 | Apple MacBook Pro Laptop Computer with...
Download mac osx 10.9
  • iMac (Mid-2007 or later)
  • MacBook (13-inch Aluminum, Late 2008), (13-inch, Early 2009 or later). What model of the computer are you using? To down load go to Software update under the Apple ( black colored icon ) pull down menu
Jul 05, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I can not update my mac to 10.9
Hard to say without knowing exactly what Mac you have and what specs, but most likely reason would be your system doesn't meet the requirements (From Apple support site) - To install Mavericks, you need one of these Macs:
  • MacBook Pro (13-inch, Mid-2009 or later),
  • MacBook Pro (15-inch or 17-inch, Mid/Late 2007 or later)
  • MacBook Air (Late 2008 or later)
  • Mac mini (Early 2009 or later)
  • Mac Pro (Early 2008 or later)
  • Xserve (Early 2009)
Your Mac also needs:
  • OS X Mountain Lion, Lion, or Snow Leopard v10.6.8 already installed
  • 2 GB or more of memory
  • 8 GB or more of available space
Jan 18, 2014 | Apple OS Computers & Internet
I am running OS X 10.4.11 and would like to upgrade my operating system?
Please provide more information.
To what would you like to upgrade it?
Since OSX Mavericks was just announced, I'm going to assume that's what you're wanting to upgrade to.
Not all Macs can run Mavericks.
Mavericks Capable Macs
Mavericks, like its predecessor Mountain Lion, requires one of the following Macs with at least 2 GB of RAM and 8 GB of available hard drive space:
  • iMac (Mid 2007 or newer)
  • MacBook (Late 2008 Aluminum, or Early 2009 or newer)
  • MacBook Air (Late 2008 or newer)
  • MacBook Pro (Mid/Late 2007 or newer)
  • Mac mini (Early 2009 or newer)
  • Mac Pro (Early 2008 or newer)
If your Mac isn't one of the ones listed above, you won't be able to upgrade.
If you have an iMac, MacBook, MacBook Pro, or Mac mini model that was originally released in Early/Mid 2006, the latest version of Mac OS X your system supports is Snow Leopard.
http://store.apple.com/us/product/MC573/mac-os-x-106-snow-leopard
Oct 23, 2013 | Computers & Internet
My imacs screen wont show up what do i do?
get an external monitor and the correct dvi adapter and plug it in to te back and turn it m Make sure that in the >System Preferences>Displays you have mirroring turned on then you should be able to a least use your mac. My sister had the same problem this solved it somewhat She hides the iMAC behind the new screen. Only other solution would be to take the iMAc in and probably have the display board replaced which would cost you more than the new screen. You will still have the new screen to put on a new computer and use it as a second display.
I have two 24 inch displays on my computer
Oct 21, 2012 | Apple iMac G5 Desktop
When i want to use my webcam on chatroullette.com, the website asks me if i would want to Use my webcam or if i dont, however when i click on YES or NO nothing happens. My imac webcam works fine on...
Some websites are windows only. I know, very biased but most are upgrading to be able to use MAC interface(s) as more MACs get out there like Ipads etc. Contact the site for info to verify.
Feb 26, 2011 | Apple iMac (20 inch, Mid 2009) SuperDrive,...
Getting a new flat panel lcd screen to work on my imac 20 inch intel-imac p.c.
And the problem is?
I'm guessing that nothing comes up on the second screen.
Go to system preferences, displays and you should see your second screen there, ready to be configured.
May 20, 2010 | Apple iMAC All-in-one - 2.66GHz Intel Core...
Kensington cable lock
Kensington lock slots are universal. Any Kensington or similarly branded laptop/computer lock will fit any iMac, and Macbook, Macbook Pro, Mac Mini, or Mac Pro.
Apr 16, 2010 | Apple iMac G4 20" Mac Desktop
My imac 0s 10.5.7 goes blank and restarts mid work. I thought maybe a mouse problem so took off the wireless and put on the one that came with the imac. That didn't solve the problem.
It sounds like either a hardware problem that has been shown up when you installed Leopard, or your Leopard install hasn't gone smoothly.
IS it a new install?
Jul 22, 2009 | Apple iMac 24-inch 2.8GHz Intel Core 2 Duo...
Computers & Internet Logo
Top The Computers & Internet Experts
Mike 'H'
Mike 'H'
Level 1 Expert
Dakshinamurthy...
gbob59
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
