Question about Avanti Refrigerators
My avanti water cooler not working/no power nothing why?
Posted by david Andrade on
ray gallant
    Top Expert:
  • Avanti Master
  • 66,956 Answers
Since we can not test it we would not know .
Posted on Mar 26, 2020
5 Related Answers
Anonymous
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
shaun greyvensteyn
  • 159 Answers
SOURCE: 2 mos old. simply stopped working. no power at all to lights, motor ,etc.
check if you get power by the motor if no power change the thermostat
Posted on May 16, 2009
Anonymous
  • 93 Answers
SOURCE: Avanti EWC16B (wine cooler) got fried by power surge
A lot of time during storms the control boards in appliances get messed up. Try unplugging it and plugging it back in after about 20 seconds. A lot of times that will reset the controls.....if they did not get fried.
Posted on Sep 12, 2009
Testimonial: "I enjoyed the detailed explanation. The fuse was indeed blown, but the diode probably as well. But can anything else be blown??"
shastalaker7
Robert Horton
  • 1515 Answers
SOURCE: Avanti Beverage cooler gets too cold
Hi, sounds to me as though your temperature control is faulty, and the unit is running all the time. This control will have to be replaced. This is something you can do if you take your time and draw a wiring diagram in case you forget. It will have a long coiled up wire with a bulb on the end of it mounted in the evaporator section in the refrigerator section. This all comes out together. This is the only thing that would cause this problem. Get all of the numbers, model, serial, and part numbers when you go to the appliance parts house to get one. You should have no problems in doing this. Please keep me posted as I am sure this unit is worth changing out the stat.
Sincerely,
Shastalaker7
Posted on Feb 02, 2010
Anonymous
SOURCE: My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Posted on Feb 17, 2010
My water cooler not making a cold water, Need to fill the friyon
On a small refrigeration system like that you need very specialized equipment and a ton of experience to make it work...also you will need to find the leak and fix it before filling it will do any good...
You will probably be better off getting a new one...
heatman101
Aug 13, 2010 | Avanti Hot and Cold Water Cooler
Hot water valve stuck
Your problem may re related to the recall of that model due to the child proof hot water handle. Go to:
http://www.cpsc.gov/cpscpub/prerel/prhtml05/05018.html
Jun 28, 2010 | Avanti Hot and Cold Water Cooler
The water isnt cooling in the dispenser and we dont hear the coils running anymore either. what can we do to troublshoot our dispenser
It is oin the refrigeration unit, if it is not the power ie. outlet. Then not much you can cost effectively do. Could be compressor, dirty coils, thermostat or leaking refrigerant.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 26, 2009 | Avanti Hot and Cold Water Cooler
May 13, 2009 | Avanti WCR683DZD Stainless Steel Wine...
Mar 02, 2009 | Avanti Refrigerators
Avanti 12 bottle wine cooler...switch is bad. Electricity going to the switch but not turning on. Where do we get one? Avanti is NO HELP!
There is a circuit board in this that you'll have to replace,and good luck finding the part.Most of these coolers were built as throw aways,meaning when it stops working you, throw it away.
May 29, 2008 | Avanti Refrigerators
Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Dec 31, 2007 | Avanti EWC28 Wine Cooler
Avanti water cooler
check the switch at back if it is working, check the motor compresor touch the top of the motor comp, if working, the possible problem is the freon, touch the condenser at the back of the unit if hot the freon is working, if no hot, load a freon, ok
Sep 28, 2007 | Avanti (WDE79BSS)
Refrigerators Logo
74 people viewed this question
Top Avanti Refrigerators Experts
Marvin
Marvin
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
