Question about The Computers & Internet
Can you guide me on how I use the window media player on my laptop Window 10? Is it easy to use window media player for IPTV subscription?
I use a laptop having window 10 operating system how I use IPTV service on the window media player.
Posted by MIPTV001 on
  • Patrik Parker Jul 24, 2019
    Hi MIPTV001 , I want to help you with your question, but I need more information from you. Please Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7
5 Related Answers
Edric Rojas
  • 126 Answers
SOURCE: window media player installation
Just reinstall the software. You download windows media player by clicking this site http://www.microsoft.com/windows/windowsmedia/download/AllDownloads.aspx?displang=en&qstechnology=&wt_svl=20513a&mg_id=20513b
once page is loaded select from the pull down menu the type of operating system you are using
Posted on Jun 24, 2008
rockitman187
Randy Hough
  • 2559 Answers
SOURCE: Windows Media Player 10
You can not play WMV or ASF media on a website with Internet Explorer's Media Bar turned on. Internet Explorer has its own player for the Media Bar. To get around the c00d11cd error being generated you need to turn the Media Bar off. To disable Internet Explorer's (version 6) Media Bar click the Media button on the main Toolbar, then click "Media Options" in the new pane that opens. Now select "settings", and then un check "Play web media in the bar".
There is no need to restart your machine as this will take effect immediately.
You have a "playlist" on your PC that you are trying to copy to a CD-R. When you hit the copy button it goes straight to the c00d11cd error!
The most likely cause is DRM. Check the songs on your "playlist" to see if any of the content protected. To do this simply "right click" on each song, then select the "license tab". If any of the songs are protected then you can NOT copy them without the appropriate DRM authority. (DRM = Digital Rights Management) You will need to check with the site you purchased from to see the level of DRM used.
You have a "playlist" on your PC that you are trying to copy to another computer. When you try and play on the new computer it goes straight to the c00d11cd error!
The most likely cause is DRM. (DRM = Digital Rights Management)
It is likely you purchased and downloaded from a site Like Walmart.com Online stores like these set restrictions on what you can do with the .WMA files you download. It is likely that the DRM licence for your download restricts you copying to another PC. You will need to check with the site you purchased from to see the level of DRM used.
You can not copy songs from a CD in the CD drive to your hard disk. Windows Media Player generates the c00d11cd error.
The most likely cause is that something has gone wrong with the special file responsible for the "encoding". The name of the file is: wmadmoe.dll
The first thing we need to do is re-register this file with Windows XP To do this go to the "Start Menu" and select "Run". Now type in the following: regsvr32 wmadmoe.dll
If this does not work then the file itself may be corrupt. To fix this go to the "Start Menu" again and select "Run". Now type in the following: sfc /scannow
This will now scan your XP machine to see if there are any corrupt system files. If there are any then XP will prompt you for the XP CD so it can get a new copy... This may help you resolve the c00d11cd error.
This will get you up and running again, however due to some underlying problems with your installation you may actually need to re-install Windows Media Player.
Please rate this fixya
Posted on Jan 25, 2009
Anonymous
  • 837 Answers
SOURCE: Unable to load Easy Media Creator 7.5 to new Windows Vista machin
That is because you need a 64 bit version ..
Posted on Mar 23, 2009
Gomez
  • 253 Answers
SOURCE: error when trying to download MS strrets and trips 2006 w/ GPS lo
I have used every version of streets & Trips since 05, and have never had any issue with Win Media Player, currently using streets 2009 on one machine with Windows 7 RC1, which has WMP 11, and on another PC streets 2008 and Vista with WMP 11. You may need to change your default program settings for media back to WMP if you ever had another media player installed.
Posted on Jun 13, 2009
durtopian
Toby Lee
  • 409 Answers
SOURCE: Audio driver
Go to Asus website.Find product support and/or downloads and put in your model number or serial number and then get only the drivers for XP.If it has a chipset driver among them be sure to install it first in order for all the other drivers to work properly and without problems.
Posted on Jul 31, 2009
Super iptv active code
If your looking for a subscription for IPTV, there are many out there to choose from. With just a simple google search you will find many. If I were you Id suggest RocketStreams Tv. They are a great IPTV Service and I have used them for a while now. Check the link for more info on IPTV subscriptions.
IPTV Subscription For Your Android Box Should buy Subscription
Dec 02, 2017 | Televison & Video
Where can we get info relating to IPTV server?
There are many websites on the internet which are offering information relating to a IPTV server. These are specially made for those people who are looking for quality information relating to a IPTV server.For more information please visit this website:https://www.speedyiptv.com/freeiptvlinks/
Aug 15, 2017 | Computers & Internet
Window media player problem
here is the site to download your media player 9 or 10, www.download.com and in the search mode type windows media player 9 or 10
Jun 19, 2009 | Microsoft Windows Media Player
Screen says I have to synchronize to continue subscription how do i synchronzie my mp3
STEP 1 - Connect the Sansa player to the computer
STEP 2 - Run Windows Media Player
1. Go to Start > Programs > Windows Media Player.
NOTE: If you can not see Windows Media Player on the menu, go to Start > Run then type WMPLAYER then OK.
STEP 3 - Sync files to the Sansa player.
Windows Media Player 10:
1. Click the Library tab.
2. Drag the music files to be transferred on to the right panel.
NOTE: You can also right-click on the title of the song and select Add to sync list.
3. After creating the list, click the Start sync button to sync and transfer music files to your device.
Windows Media Player 11:
1. Click the Sync tab.
2. Drag files to be synced on to the right panel, under Sync list.
3. Once the list is complete, click the Start sync button.
For further reference, go to:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=389&p_created=1225223428&p_sid=YNkfm7tj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0yMTUsMjE1JnBfcHJvZHM9NCZwX2NhdHM9JnBfcHY9MS40JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTI*&p_li=&p_topview=1
Mar 18, 2009 | SanDisk Sansa Clip MP3 Player
Playing synchronized songs
Renew your Rhapsody subscription and resync
Apr 29, 2007 | SanDisk Sansa e260 MP3 Player
Computers & Internet Logo
24 people viewed this question
Top The Computers & Internet Experts
Mike 'H'
Mike 'H'
Level 1 Expert
Dakshinamurthy...
gbob59
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
