Question about Asko Dryers
How do I locate the humidity sensor on an Asko T702C dryer? I have a service manual for the T700 series but it doesn't include the T702C.
According to my research, when this dryer shows the "maximum time reached" alert it could be due to the humidity sensor. I have located the thermistor, but the humidity sensor is nowhere to be found. I have not been able to locate a service manual for the T702C model specifically.
Posted by Alison Castle on
5 Related Answers
Rotu
Douglas Henry
  • 175 Answers
SOURCE: ASKO t700 dryer thumping sound
usually whin you get one thump (or a quick double thump) you have a dent in the roller surface of the drum itself. Easiest way to check this is to unplug the unit and take the top off by removing the 3 torx screws in the rear, then lifting the top off. Once the top is off look at the very front edge of the drum as you rotate the whole thing by hand. If you see any irregularities on the surface, thats your problem. If you see nothing it could be a bad motor or roller, but its unlikely if its happening in the same place on the rotation evry time. What has usually happened with dents in the surface of the drum is that the unit was set down too hard (or dropped) and the wheels it rests on dented the metal they ride on. If thats the case the only solution is to replace the drum or live with it .Good Luck!
Posted on Mar 25, 2007
Bill Hackett
  • 383 Answers
SOURCE: 1999 Nissan Altima MAP sensor location
The MAP sensor is located on the driver's side of the engine compartment next to the air filter housing and shock tower.
It is a small plastic component with one vacuum hose coming off of it and an electrical connector that has two wires. It might be advantageous to write in and let me and/or other techs know what the symptoms are prior to replacing the sensor. Sometimes just replacing the part is a waste of money. The fact that the code has indicated the problem is the MAP sensor, doesn't mean it is bad. As an example, check to see if the Vacuum hose is secure and not disconnected or split at either end.
Good luck.
Posted on Apr 05, 2009
Anonymous
SOURCE: My ASKO T702C dryer just stopped working
Try opening the bottom vent panel and pulling out the filter box (there are directions and handles)... hold the filter under running hot water for a while and you should see all this nasty stuff come out. Worked for me!
Posted on Aug 20, 2009
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: Asko T700 dryer won't run
Have you checked the 15amp fuses which are located at the back of your Asko dryer ?
That is where I`d start. They are at the back as I said located next to where the power cord exit`s the unit. Look for 2 small round slotted caps ( these are the fuse holders/hubs ) either black or gray in color.
With a flat screwdriver fitted in the slot of the fuse hub, turn it a half turn counter clockwise an it should drop out...though it may need to be pulled out if it`s stuck in the holder part.
Replace with a 15amp "slow blow" ( the only difference is the slow blow are filled with sand and aren`t transparent glass tubes but rather gray or white in color ) if the fuse is blown.
Hope that is helpful. If so please rate the solution accordingly, if not let me know what you find or if you require further assitance.
Thank`s for visiting fixya today and good luck.
macmarkus :)
Posted on Apr 08, 2010
Testimonial: "Very helpful-fuse was bad-I will replace and see if there are additional problems. I will use Fixya again."
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: T700 asko dryer runs if
Welcome to FixYa.
Based on your description I`d direct you to first check the hi-temp cut out at the back...if you haven`t already.
It will look like this on the Asko dryers...
If you push this to reset and the unit works, great. I would keep an eye on it though since the hi-limit typically trips for a reason such as a plugged lint filter, plugged vent ot partially plugged or the heater itself is plugged up with lint.
Take the lint filter and clean it under some warm water and soap as they do become plugged with wax over time due to fabric softener and static sheets...when present/used regularly
If it doesn`t run after-wards or it`s not tripped, you`ll need to investigate for a faulty heater element. This is quite involved, so we`ll cross that bridge when you get there...if necessary.
Keep me posted on your progress or what you find and I'll help in whatever manner I can. Good luck.
Regards,
Macmarkus :)
Posted on Mar 16, 2011
I need a wiring diagram for asko dryer
They usually put the wire diagrams inside the actual console area, they make it to where only services can find it. If it isn't inside the console then try going to asko website to see if they have a PDF file you could download
Jan 31, 2014 | Asko T700 Electric Commercial Dryer
F5 code on Asko 7305, can humidity sensor be bypassed?
I've had luck vacuuming the lint and dust out of the humidity sensor on my Asko. Suggest trying that first. While you're in there you might also exercise the connectors at the circuit board end of the sensor's cable(s). If they're corroded, some simple unplugging and replugging a few times might burnish the connectors. I've observed that our dryer will sometimes run longer than necessary on days when the relative humidity is high. Not very often but enough to suspect a trend. If your environmental air is humid, I would wonder if you're experiencing a similar condition. Every couple of years I take the dryer outside and blow it out with the air compressor: air chamber including heater coils as well as all the innards. This also gives me a chance to keep an eye on the belt!
Dec 23, 2013 | Asko Dryers
Asko T700 overheats and shuts off
replace the timer or temp sensor
Aug 27, 2009 | Asko T721 Electric Dryer
My belt is broken and I can't find a replacement
In your town, a appliance repair shop would have it, on line ...www.repairclinic.com
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 08, 2009 | Asko T780 Dryer
My ASKO T702C dryer just stopped working. It starts but after 5 mins it just turns off. Any suggestions?
Jun 11, 2009 | Asko T711 Electric Dryer
Asko T700 loose belt, access from front?
I think you must replace the belt and the tensionarm. It MUST be done from the backside of the machine... Remove the backpanel, and the drum, change the tensionarm, and put the drum into the machine again. Put on the new belt, and mount it together again. Be careful for sharp edges! Hope this helps :-)
Jan 12, 2008 | Asko T700 Electric Commercial Dryer
Replacement part for Asko Dryer T700
Call Asko and order it there. Cant imagine that it is a expencive part. I only have the Norwegian partnumber.
Dec 24, 2007 | Asko T700 Electric Commercial Dryer
Dryers Logo
169 people viewed this question
Top Asko Dryers Experts
Marvin
Marvin
Paul Carew
peter gittos
peter gittos
Are you an Asko Dryer Expert? Answer questions, earn points and help others
