Question about The Computers & Internet
Wheres the delete button - The Computers & Internet
Posted by Errol Heasley on
  • Patrik Parker Jul 24, 2019
    Hi Errol Heasley, I want to help you with your question, but I need more information from you. Please Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7
Where is the delete button on a gateway laptop
It is above he Backspace Key on a standard QWERTY keyboard. It is marked "DEL".
Feb 10, 2015 | Gateway Computers & Internet
How do I delete photos?
With the delete button. I don't know where on your device the button is. On the other hand, it could be there is no button at all, but I don't know where you want to delete the photos.
Please give us more info about where the photos are and what you want to use to delete.
Jan 23, 2015 | Tablets & eReaders
My grandson inserted his name on the icon line along with the icons such as maps, you tube etc - how does one delete it? There are also games he downloaded within this section that I want to delete. The...
If you mean you now have a name at the bottom line on the screen (same line as where your clock and start button appear), then this is the Task Bar. Hold the left mouse button down on the item to be removed, and then drag the item onto the main desktop area. Then release the button, now try to delete it again.
Aug 06, 2013 | Computers & Internet
The delete button is above the LCD monitor on the back of the camera, the second button from the right, marked with a trashcan. While viewing the picture you want to delete, press this button. The camera will prompt to make sure you want to delete the picture.
Apr 19, 2012 | Olympus SP-310 Digital Camera
Where is the delete button on my keyboard.i have model nav70 series aod260
There isn't a "delete" button on many laptops. The backspace button is 2 buttons above the "enter" button.
Apr 14, 2011 | Dell Inspiron 8200 Latitude C840 Laptop...
Do not know the process of deleting pictures from camera!
The delete button deletes images stored on the memory. It is located on the back of the camera and looks like a little garbage can. It is the middle button going vertically down on the right side of the display screen. First hit the button below it that looks like a printer. It will display a picture. Then use the left/right buttons down where the OK button is in the middle. This will take you backwards or forwards in your photos. Next push the delete button it will ask if you want to delete yes or no, use the left/right buttons again to choose yes or no. Then push OK in the middle and it will delete your pic if you chose yes or save it if you chose no.
You can also go in on Play mode [under the /- button where garbage can is] and press the Menu button...go left or right until you find DELETE screen and then follow directions from there. All these directions are on your CD that came with the camera.
Hope this helps. MAKE SURE you have downloaded whatever you want to keep on your computer before deleting.
cls
Oct 18, 2010 | Samsung Digimax D53 Digital Camera
Where is the delete button?
There isn't a 'delete' button like you'd find on the extended keyboard, if you hold function while pressing backspace it will function as a delete key. (My MacBook's backspace is labeled 'delete' but is a standard backspace.)
Answer: Function + Backspace = Delete
I hope this is helpful and works for you. If I didn't fully answer your question, please let me know and I will do my best to add or clarify my response. If this was helpful, please rate my answer with 5 thumbs up.
May 19, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Where is the letter delete button ??
u can find a "C" button on the phone.........thats the letter delete button
Apr 23, 2009 | Sony Ericsson W380i Cellular Phone
Trying to delete current play list on Philips SA 1922 2gb mp3 pla
This solution only applies to the SA178:
  1. Select the track that you would like to delete in play mode.
  2. Briefly press the MENU button.
  3. Select DELETE, press 051104154033_4114.gif to confirm your selection and press 051104154033_4114.gif again to confirm delete. The message DELETED! will show on display.
Mar 18, 2009 | Philips GoGear SA178 MP3 Player
Deleting text messages
Ok, here is what you do to delete your messages in the inbox:
1. First you press your messages button where they are located
2. Now scroll down to where it says Inbox and make sure it is highlighted
3. Next press the button that looks like two pieces of papers one on top of the other...it is next to the OK button in the middle but on the left side.
4. Next you will see something that says Setup...press OK
5. Scroll down to where it says Cleanup press OK and you will see Inbox and Sent Items on there. Choose your Inbox ( you can also do the same for sent items)
6. Now just choose how often or how many messages you want cleaned up...then press the OK button.
7. It will automatically ask you if you want to do this now...choose yes
Now your inbox has fewer or no messages...
Have a blessed Day!
Jan 05, 2009 | Motorola Mobility I335 Cellular Phone
Computers & Internet Logo
16 people viewed this question
Top The Computers & Internet Experts
Mike 'H'
Mike 'H'
Level 1 Expert
myxelpyxel
Dakshinamurthy...
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
