SOURCE: Roland DP-2 pedal not functioning correctly.
There are two types of damper pedal switches, on that is closed until you press it, and one that closes when your press it. It sounds like your Casio is expecting one type and your Roland pedal is the other type. A quick way to test this is to plug a guitar cable into the Casio pedal input and see if the keyboard sustains. If it does, then your Casio requires an "normally closed" switch.
Some pedals have a small switch near the cord or even on the bottom of the pedal that will reverse the switching operation (BOSS pedals, a division of Roland, have this feature). If you can find that, then change the switch position and you should be OK.
If not, and you feel like digging into your pedal, you could take the bottom off of the pedal and check out the switch itself. Many pedals use a switch that can be used either way. The clue will be on the switch itself. If there is an extra tab on the switch that is unused, then switch the wire that is furthest away from that tab to that tab. This will probably involve soldering, but it is nearly impossible to damage anything.
If moving the wire that is furthest away does not do anything, then try putting that wire back and switching the other one.
If your pedal does NOT have an extra tab, you're SOL, unless you want to buy a replacement switch (unsure of make). If this is the case, you are probably better off getting a different damper pedal - preferably one that is marketed as "universal"
SOURCE: Casio 1600 sustain pedal problem
Not if its like mine, its a completecircuit vs.incomplete circuit problems.
I had the exact same problem with my Casio keyboard and a Yamaha sustain pedal I bought.
I'm not an electrical genius, but I was able to get it to work by opening it up and doing a little modification. Of course I first just tried switching the white wire with the black one but that didn't change anything at all when I tried it. It turns out the Casio wants the circuit completed to sustain, and broken for no sustain, which is the opposite of what the Yamaha pedal does.
I opened it up and mine had three three flat metal strips let's call them Top, Middle and Bottom. The Middle and Bottom ones were joined together on the right side, and the Middle and Top ones were touching on the left side when the pedal was not pressed. These seperated when the pedal was pressed, thereby breaking the circuit because the wires were on the top plate and on the joined Middle/Bottom plate.
So to flip it I:
1. Unsoldered the Bottom wire
2. Cut apart the Bottom and Middle plates on the right.
3. Bent the Middle plate on the right to touch the Top plate instead and soldered those together.
4. Soldered the Bottom wire back on.
That's it! Once I figured it out, it took only a few minutes to fix.
Paul
SOURCE: Casio Privia PX-800: When using the sustain
Check if the cble frm the pedal MIGHT be flexing or pulling on the keyboard case when you use it. Such movement COULD vibrate the power connector causing your problem.
Make sure you have the right power supply for the unit as one with too large a hole for the power pin would be intermittent like this.
SOURCE: When I plug the pedal in and play, the music is
1.Make sure you are plugged in to DAMPER (not FC1 or FC2)
2. Check to see if the notes STOP sustaining when you PRESS the pedal. If that is the case, first try turning off the Roland with the pedal plugged in and restarting with the pedal pressed down.
3. Press the EDIT button and scroll to Damper Polarity. See if it's set to Standard or Reverse.
4. If problem persists after all that, try holding the pedal jack into the Roland at different angles and then try the same with where the cable connects to the pedal. At that point, you can either attempt to repair the pedal or get another one.
Hope this helps,
Stewart
SOURCE: I have a Casio PX-800
If that is one of the ones with a plastic "hinge/spring", breakage is usually fatal... keep cord and plug for junk box.
